('98-'00) 2000 Forester headlight issue - Subaru Forester Owners Forum
post #1 of 3 (permalink) Old 02-09-2013, 03:32 AM Thread Starter
Matt Harris's Avatar
Hi all, I see there are a number of threads related to headlights, but I'm not sure if any of them answer my question.
One of the headlights on my (new to me) 00 Forester is very dim. When I look at the headlight assembly, only the small lamp in the bottom outside corner is on. Is that the low-beam, and the main lamp in the centre is high-beam?
The dim headlight (left-hand side, which is passenger side as I'm in Australia) comes on, but it's either not putting out enough light or not in its socket far enough to bounce off the reflectors. Both high beams work, so if I understand what I read in the other threads, that means it's not fuse-related.
Any advice on where to start looking for the problem?
Matt Harris is offline
post #2 of 3 (permalink) Old 02-09-2013, 08:08 AM
Loscaldazar's Avatar
Car Year: 03
Transmission: 5 MT
Feedback Score: 11 reviews
That center bulb is both your hi and your low beams. If the hi beams are both working, but one low beam is not working, the bulb needs to be replaced. The low beam part of the bulb has burnt out. It is generally suggested that you replace both bulbs at the same time, as when one goes, the other is usually close behind.
Make sure you aren't hitting the parking light button on top of the steering column to turn on your low beams or turning the twist part of the light stick one click forward, those are just parking lights (low battery drain, but required in some countries when parked). Low beams turn on with the twist part of the light stick turned all the way forward, and then hi beams you push the light stick forward.
Loscaldazar is offline
post #3 of 3 (permalink) Old 02-09-2013, 08:19 AM Thread Starter
Thanks, I'll replace the bulb tomorrow and hopefully that will do it. Is the bottom corner the park light?
