Car Model: Forester 2.5XT
Per the supplied link and write-up by Peaty, http://www.scoobymods.com/tsb-02-97-...2.html?p=20694, I decided to remove the mesh screens from my oil lines this morning. What I found was pretty scary. The car has always had rough idle and loud valves. By removing the screens it solved both problems.
Here is a pic of what I found.... ![]() Passenger side was the more crushed one and also the side that had the most valve noise. The driver side "only" had a torn screen and minor crushing. I HIGHLY RECOMMEND CHECKING YOUR 2.5L FOR THIS!
2004 Forester XT Premium 4EAT |
Car Model: Forester XT MT
I'm picking up an '04 FXT that i bought tomorrow - mechanic who inspected it mentioned that the oil screens were either clogged or damaged - I imagine a similar problem to what you've shown/described... he said it's definitely something to take care of or risk damaging the turbo, and is quoting $200 to take them out.
How easy would it be do take care of this myself - I've gotta think this is doable despite being very novice when it comes to mechanics... not quite sure how to get after them. Is it just a matter of pulling them out and replacing the lines - having no screen doesn't hurt i take it? thanks for any advice you can offer- |
#3 (permalink) | |
Registered User
Car Model: FXT, hopefully
If you dont buy the screws and new washers it wont cost you anything but time. I just did this today about a few hours ago(I bought new screws and washers)
04FXT 4EAT,StageII VF39 |
thanks, i thought $200 was a bit much as well.
so can you just take the screens out completely without causing any harm or reducing mileage/performance or do you need them in? I'd really like to take care of this myself if i can get to it confidently without screwing anything up... i've read a few posts with mixed results, some say it's easy and quick to get to and others think it's a lot of work, removing uppipes etc. to get to it... |
#5 (permalink) | |
Registered User
Only thing you actually need to remove is the screws(to get the screens out), you can get to them easy. Passengers side needs the intake tube from the turbo inlet to the filter hosing removed(two clamps) then you can get right to the screw on that side. The drivers side is right next to the Oil fill tube, fairly easy to get to also. Take the two screws out and remove the screens and then just reinstall screws. You should replace both copper gaskets(on each side) while you there but you could probably get by without doing so with no problems.
#7 (permalink) |
Car Model: forester xt
very easy to do. i havent done the one in the turbo banjo bolt yet, i beleive its the harder one to do. i reused my gaskets with no problems
#8 (permalink) |
Registered User
Does anyone know if this affects the 05's too?
05 Mod Journal |
#9 (permalink) | |
Registered User
Is that a third screen? I wasn't aware of that, A screen in the turbo banjo bolt.
#10 (permalink) |
Car Model: 2.5 XT 4EAT
Yep there are 3 screens.
The 2 in the banjo bolts on the heads for AVCS which should definitely be removed. Theres also the one on the back of the passenger side head in the hardline that goes between the head, turbo and pass side AVCS. Its quite a bit more difficult to get to as it will require removing the turbo (and possibly one of the uppipe brackets, depending on the tools you have)
#11 (permalink) | |
Registered User
Well I have my turbo off now as I am swapping it out for a VF39 now. I guess I will remove that while I am in there. So I guess downtown your mechanics price might not be that bad then if he's doing all three screens. Moving the turbo and associated parts is pretty time consuming and has a certain degree of difficulty. So you might wanna ask him if that's what the $200 covers?
#12 (permalink) |
Can you tell if the service bulletin has been applied? (Do the new bolts look different than the old ones from the outside?)
I assume if this was done under warranty Subaru has a record? (I bought my 05 used and have no idea if it still has the screens...) |
#13 (permalink) | |
Registered User
I would guess they would be bright aluminum but they are the exact same size.
#14 (permalink) |
Car Model: 04 FXT, 61 Stude
So let's just say, hypothetically, that if one was to strip the threads that the nut goes into, is it the head itself? What kind of repairs would it take to get the car running again. Oh, and this isn't a hypothetical question. FML.
Giant 29er - 04 FXT MT - 61 Studebaker Lark |
#15 (permalink) |
Which one?
The turbo supply one is right into the head (or maybe its the block, not sure off the top of my head). The avcs ones go into the avcs solenoids, which can be replaced. However it shouldn't be too terrible to fix that, a good mechanic should be able to install a helicoil there.
