Longevity - Subaru Forester Owners Forum
post #1 of 12 (permalink) Old 03-05-2009, 10:30 AM Thread Starter
machman's Avatar
Car Model: Forester 2.5XT
Longevity
I'm new to this forum and I have a couple questions.
I recently bought a 2009 Forester 2.5XT and I was wondering what modifications can I make to the engine and/or exhaust to increase longevity of the vehicle?
I am mainly concerned about longevity and not necessarily horse power.
Friends have suggested for starters, boost control and a turbo timer.
Any advice would be greatly appreciated. Thanks.
machman is offline
post #2 of 12 (permalink) Old 03-05-2009, 10:34 AM
Galager's Avatar
Car Year: 13
Feedback Score: 12 reviews
^^You don't need a turbo timer or any kind of boost control for longevity. If you are strictly looking for longevity, don't change anything!
Good maintenance is the only thing you need to worry about. If you are really concerned, frequent fluid changes and synthetic fluids would be your best mod. Turbo timers are a concern of the past. The new systems have some kind of design where after you shut off, coolant still circulates through the turbo. That being said, don't floor it and then turn our car off. A minute of normal driving should be enough. Nobody here that I've seen uses a turbo timer anymore.
Maybe look into a catch can, but I don't really think that matters for reliability.
'05 XT 5 spd VF - SOLD
'13 XT Touring
Galager is offline
post #3 of 12 (permalink) Old 03-05-2009, 10:37 AM
Hot09XT's Avatar
Welcome to the forum and congrats with the new FOZ. Lots of great info here. I have heard about both although I believe the turbo timer isn't necessary unless you run your vehicle hard. If not just wait 15 -30 seconds before you shut the vehicle off, at least thats what the manual says. Someone will chime in I'm sure.
MY09 XT Limited AT
Satin White Pearl
Hot09XT is offline
post #4 of 12 (permalink) Old 03-05-2009, 10:38 AM
guroove's Avatar
Feedback Score: 13 reviews
For longevity, just do the regular maintenance and forget about the mods. You have a good start living somewhere where you don't get snow so you don't have to worry about road salt. Change your oil when you're supposed to, and make sure to use the right coolant. The turbo timer isn't really needed because the turbo bearing cartridge is water cooled. I don't see how boost control would help longevity unless you want to limit boost. I don't know why you would buy a turbo car and limit boost though. Other things to consider might be synthetic oil, atf, and gear oil.
guroove is offline
post #5 of 12 (permalink) Old 03-05-2009, 10:40 AM
Galager's Avatar
Car Year: 13
Maybe a transmission cooler and an oil cooler. But I really don't think either of those things are necessary unless you are towing.
'13 XT Touring
Galager is offline
post #6 of 12 (permalink) Old 03-05-2009, 11:17 AM
guroove's Avatar
Agreed. A transmission cooler will also help the whole cooling system to cool better. I had made a post about the oil cooler, but adding one also opens up other concerns, such as oil pressure, and where to run the lines. The oil filter is very close to the exhaust manifold, so running lines from that location might not be a great idea.
guroove is offline
post #7 of 12 (permalink) Old 03-05-2009, 12:33 PM
Feedback Score: 53 reviews
Keep good maintenance habits. Buy good quality oil & filter, change oil religiously, have oil analyzed every 10k or so to monitor engine health.
Forget about mods.
~ Silke ~
'04 FXT 4EAT PSM - "Subed Up"
'98 S 4EAT DBP - "Slynki"
pleiad7 is offline
post #8 of 12 (permalink) Old 03-05-2009, 02:14 PM
funkymonkey1002's Avatar
Car Model: 2.5 XT
Possibly a protune, some of the newer turbo subarus seem to not have the greatest programming from the factory. Otherwise just keep up to date on maintenance. Stay away from jiffy lube :-P. Stock, the 2.5 seems to last 200,000+ no problem with normal driving.
funkymonkey1002 is offline
post #9 of 12 (permalink) Old 03-05-2009, 02:40 PM
Galager's Avatar
Car Year: 13
^^Funny you say that. I trust Jiffy lube more than my dealer!
'13 XT Touring
Galager is offline
post #10 of 12 (permalink) Old 03-05-2009, 03:27 PM
BAC5.2's Avatar
Car Model: Outback XT-B
Subaru has been using a gravity-siphon cooling system since the 1989 Legacy Turbo. No Subaru has ever "NEEDED" a Turbo Timer.
I had one on my old car simply for cold mornings. I had it wired so it would only work when the car was in neutral, the e-brake up, and the brake pedal left untouched. Push in the clutch, tap the brake, or put down the e-brake, and the car would shut off.
BAC5.2 is offline
post #11 of 12 (permalink) Old 03-14-2009, 06:19 PM Thread Starter
machman's Avatar
Thankyou so much to all of you that replied. I appreciate it.
machman is offline
post #12 of 12 (permalink) Old 03-15-2009, 05:59 AM
Car Year: 2013
Car Model: WRX Limited
I have one other piece of advice for longevity. Stay out of the engine/exhaust forum. You have the potential to read about astronomical power levels and then go on the quest to attain such power levels--> which could lead to engine blowup...
Just messing around. Welcome to the forum. There are a ton of really knowledgeable members here who can/will help with any issues.
2005 XT Cayenne Red. Some mods, looking for more.
Gopher XT is offline
