Go Back   Subaru Forester Owners Forum > Technical Forums and Vehicle Assistance > Engine and Exhaust > Turbocharged
Old 09-05-2008, 08:15 AM   #1 (permalink)
President of MarkyD fan club
toddlamp's Avatar
Default I'm getting my head gasket replaced, whatelse should I get done?
So it's time to bite the bullet and i'm going to get my engine torn down to figure out why/where i'm losing coolant. The head gasket is the prime suspect. Now, while the engine is out and in pieces i'd like to get some opinion as to whatelse I should get done. I don't have a tone of money, and the HG by itself is going to be an easy $2000. One of the suggestion I have is an EJ257 short block with some forged pistons and new connecting rods. That right there will bring me up to $4000.
What else can you guys think of that should/could get done while the engine is out? I already know that when they put it all back together my STi intake manifold will go on as will my GrpN engine mounts.
Let's hear your suggestions! And please include part pricing so I know where to go. Just note that i'm not looking to dump a truck load of cash. I'm just looking for some things to do so I don't have to pay twice for the labor.
Old 09-05-2008, 08:26 AM   #2 (permalink)
Gallery: 8
How many miles on your car?
-Silke
04 FXT PP PSM ~ "Subed"
98 Forester S ~ "Slynki"
92 SVX LS-L ~ x2
Old 09-05-2008, 08:27 AM   #3 (permalink)
toddlamp's Avatar
Just over 57,000. To add, all seals are going to be replaced in addition to the head gasket. Spark plugs too.
Old 09-05-2008, 08:32 AM   #4 (permalink)
Gallery: 8
You could have them do the timing belt service early... replace the water pump, etc. Another thing that we did on Subed with the TB service was to replace each and every fluid-carrying hose in the engine bay. Probably overkill, but we figured it would be good insurance.
-Silke
92 SVX LS-L ~ x2
Old 09-05-2008, 08:37 AM   #5 (permalink)
Engineer
bbottomley will become famous soon enough
Sorry for you, friend. Been there before with head gaskets (but not on Subaru). Only good thing I can say is that an impending head gasket failure once made my engine run so hot that I absolutely tore through the emissions test! It ate up all that bad stuff before it got to the tailpipe. That was back before they started looking at the temperature gauge.
2003 XS Premium MT - 2005 Impreza 2.5 RS MT
Old 09-05-2008, 08:42 AM   #6 (permalink)
Groovologist
guroove's Avatar
guroove is on a distinguished road
TGV deletes? Ported/polished exhaust manifolds?
guroove is offline   Reply With Quote
Old 09-05-2008, 11:32 AM   #7 (permalink)
toddlamp's Avatar
Hmmm, TGV deletes I might do. I'm curious if there are really benefits to doing that.
Exhaust manifold is already ported.
Old 09-05-2008, 11:41 AM   #8 (permalink)
scubadoober's Avatar
scubadoober is on a distinguished road
Tgv deletes will probably not make much of a difference unless your makin BIG horsepower. It'll make your idle rougher than it already is if that is possible.
scubadoober is offline   Reply With Quote
Old 09-05-2008, 12:22 PM   #9 (permalink)
AK SloPok's Avatar
AK SloPok is on a distinguished road
Why change the block? Unless it's damaged.. I would do a slight bore and a set of forged 100mm pistons. Maybe rods if you can find a deal on them. Otherwise keep our block, I haven't seen enough evidence our block is any worse than the STI.
04XT, VF39, APS top mount, AP v.2, Exhaust, stereo
AK SloPok is offline   Reply With Quote
Old 09-05-2008, 12:29 PM   #10 (permalink)
toddlamp's Avatar
Thanks, i'll bring that up with them.
Old 09-05-2008, 01:43 PM   #11 (permalink)
BLUE WASABI
(#2 Info Provider)
sirwilliam's Avatar
You could have them do the timing belt service early... replace the water pump...
Forgot that I had the belts done, the water pump, and replace the existing thermostat w/ a crucial racing one. Don't forget the ARP head studs.
BLUE WASABI
Old 09-05-2008, 02:10 PM   #12 (permalink)
toddlamp's Avatar
I'll look in thoe other maintenance parts. DO you remember what they cost?
I'm probably not going to bother with studs. I don't expect to take the engine apart again for a while.
Old 09-05-2008, 02:12 PM   #13 (permalink)
BLUE WASABI
(#2 Info Provider)
sirwilliam's Avatar
Unfortunately, no. It was over 2 years ago. I got most of the maintenance stuff from Jackie at Annapolis subaru and just had her ship it over to AndrewTech since there was a working account between the two. I paid a little extra to get a new OEM water pump vs. a re-manufactured one.
BLUE WASABI
Old 09-06-2008, 03:33 AM   #14 (permalink)
iMod
BAC5.2's Avatar
BAC5.2 will become famous soon enough
You should not be using 100mm pistons in stock sleeves. It'll split one of the sleeves. I've seen it more than a few times.
$2000 is about right for the labor, but $2000 is not going to buy you a built shortblock. $4000 will though. Make sure the motor builder is clear. Are they saying $4000 for the short block and $2000 for the labor to R&I the engine? If it IS $2000 for the built shortblock, I wouldn't trust it. For that price it would probably be a used core, with no machine work at all (unless they are doing the build labor for free).
TGV deletes are kind of pointless. On BIG power cars, we have seen them force the butterfly closed and then bend the butterfly so it sticks closed. It's not as easy as "oh we'll just snap those out!" You have to remove the TGV housings from the manifold (which means new gaskets there), drill out the screws and then pull them out.
Normal things I recommend are clutch, flywheel, all fluids, engine mounts, and doing the job right.
The Aggressive™ -- You don't know about it.
1998 Forester S - Big brakes, Big Tires, 5-gears.
Old 09-06-2008, 09:42 AM   #15 (permalink)
toddlamp's Avatar
What exactly is the difference between the EJ255 and EJ257 shortblock?
I would really like to get the pistons and rods replaced. What has to be done in order to get the to work in my stock block?
Clutch and flywheel are pretty new.
