Check Engine Light - Won't Go Away! - Subaru Forester Owners Forum
post #1 of 29 (permalink) Old 04-10-2008, 11:02 AM Thread Starter
I have a 2001 Subaru but bought in (Sept. 2000) , it's an automatic, Basic L version.. For the past year I've had the check engine light on.. I've had driviblitity issues where the car sometimes seems to stall, but you hear this popping sound.. My mechanic was able to get it off to pass inspection however we tried within a year to fix it.. I've replaced sensors out the wazoo and have spent probably over $2000 trying and so for nothing.. The sensors that were replaced were brand new sensors and when the mechanic tested again the codes would come back and say "bad sensors" when they weren't.. I've even called Subaru to see if my car was on list of the recalls in Year 2000 for a system update, they keep saying "NO".. The only thing my mechanic is thinking of is that performing a "smoke" test to see where this air leak is in hoses or wires.. What do you think ?? Any other ideas ?? .. However I seem to get the drivablilty popping issue when it gets colder outside and or raining so I don't know if that has anything to do with it.. I've never had a problem this bad , and from what I've hearing that Subaru cars are suppose to last a good time.. Well any other suggestions or opinions would be great..
Thanks,
Dxtra
P. S. - And "NO" I can not afford a new car... LOL
Dxtra30 is offline
post #2 of 29 (permalink) Old 04-10-2008, 11:07 AM
ferret's Avatar
Car Model: Impreza Ltd
What's the code?
ferret is offline
post #3 of 29 (permalink) Old 04-10-2008, 11:14 AM Thread Starter
Originally Posted by ferret View Post
What's the code?
I don't know off by hand I'd have to ask the mechanic again.. When I've been there he said he was "puzzled" as to why the codes would come up bad sensor.. He would clear the codes and check engine light would go away, but again after 10 minutes of driving the check engine light comes right back on..
Dxtra30 is offline
post #4 of 29 (permalink) Old 04-10-2008, 11:17 AM
ferret's Avatar
There are many sensors and causes for them to post a code. The code is important to diagnosing your problem.
What part of the Keystone state are you in, I was raised in NE Pa.
ferret is offline
post #5 of 29 (permalink) Old 04-10-2008, 11:23 AM Thread Starter
I'm the burbs of philly in Montgomry County..
I'll have to get the codes and put them on here.. But like I said I've replace all oxygen sensors and the knock sensor so far ...
Dxtra30 is offline
post #6 of 29 (permalink) Old 04-10-2008, 12:47 PM
live4snow's Avatar
Car Year: 99
Car Model: Forester S
Mine is on for "inefficient catalytic converter" and "high idle"
I ignore mine. Electrical tape works well to cover the light though.
Yeah I drive a wagon
live4snow is offline
post #7 of 29 (permalink) Old 04-10-2008, 02:08 PM Thread Starter
LOL nice :)
Dxtra30 is offline
post #8 of 29 (permalink) Old 04-10-2008, 02:25 PM
The Sub kit guy
sea-scooby's Avatar
Feedback Score: 79 reviews
The good ol' P0420 code seems to be a common issue with the SFs. My friend is goign thru the same issue right now with is 01 Auto.
05 Forester X A/T (hers)
sea-scooby is offline
post #9 of 29 (permalink) Old 04-10-2008, 05:46 PM
huck_this's Avatar
Car Model: SOLD!
I am getting that p0420 code myself. Many times its the gas cap that is the problem. I just haven't had the time to really check it out yet.
OK so if you change the sensor, what tells you that there is maybe a cut in the wire system. Meaning that there is break between the sensor and the ECU.
I would check out what sensor is involved and look in between. If the ECU is not getting a signal, well it flags it and throws a CEL. The sensor could be good after all.
huck_this is offline
post #10 of 29 (permalink) Old 04-11-2008, 06:15 AM
AutoZone Accolade
For those who haven't read this on other posts: Most AutoZone stores will read your code for free. I've had a constant Check Engine light lit the past couple of days so I took it to AutoZone and they diagnosed the problem as a knock sensor malfunction within minutes and handed me a full printed report for free. What you do with their advice is up to you but at least you know what your car is trying to tell you. Oh, I'm in Lawrence, KS.
Update: The codes were: P0325; P1325.
Last edited by jayhawkrockdoc; 04-13-2008 at 09:00 AM. Reason: Adding pertinent info
jayhawkrockdoc is offline
post #11 of 29 (permalink) Old 04-11-2008, 01:56 PM Thread Starter
YES this is the code that I'm talking about.. Has your friend resolved this issue yet ? What was his solution ???
Originally Posted by huck_this View Post
I am getting that p0420 code myself. Many times its the gas cap that is the problem. I just haven't had the time to really check it out yet. I would check out what sensor is involved and look in between. If the ECU is not getting a signal, well it flags it and throws a CEL. The sensor could be good after all.
I've replaced the gas cap on my 1st try and that wasn't it.. All the sensors I got were tested and all are in good if not great conditon... Thanks for the suggestion tho..
Like i said in above posts, I've already replaced the Knock sensor with a new one .. I don't think Autozone will tell me anything different then my mechanic did but if it's free I guess I should try it.. Thanks!
Dxtra30 is offline
post #12 of 29 (permalink) Old 04-11-2008, 02:37 PM
Feedback Score: 41 reviews
Was the front & rear O2 sensors replaced? Other then the CEL, does your '01 seem to be operating normally?
IMO, a failing "front" O2 (A/F, air/fuel) sensor will cause hesitation, back fire & sooty exhaust pipe (running rich). The rear O2 sensor is used to monitor the operation of the CAT. It won't cause your engine to operate poorly. It does tell you (CEL code P0420) if the CAT is going south, or something further upstream is not right.
My 2 cents worth.
2.5x_sleeper is offline
post #13 of 29 (permalink) Old 04-11-2008, 06:17 PM
dwmoss's Avatar
Car Year: 07
Car Model: FXT sport
Feedback Score: 10 reviews
+1 on heading to autozone and get the code / codes read.
post up the pxxxx numbers here
dm
USDM 07 WRB FXT 4EAT
USDM 04 Gold FXT 5MT
dwmoss is offline
post #14 of 29 (permalink) Old 04-27-2008, 08:54 PM
SHOguy's Avatar
Car Model: Forester L
I had the same problem and seen the problem quite a few times on other subies. If the O2 sensors didn't fix it, the next step was a cat. i have used the one from autopartswarehouse.com a couple times with no issues. I have been running mine for 2 years and it is still good. Haven't had any customers cars with issues either. Much less expensive than a factory cat from the dealer.
01 Forester L-
Lots of suspension mods, no real engine mods
"Its more fun to drive a slow car fast than to drive a fast car slow"
SHOguy is offline
post #15 of 29 (permalink) Old 04-29-2008, 02:13 PM
[QUOTE=SHOguy;385440]If the O2 sensors didn't fix it, the next step was a cat.
My 99 Forester would code for a faulty cat. I'd clear the code and it would come back. The dealers wanted to replace both cats and/or O2 sensors. I was using some oil (1qt/1000mi). The car had 150K miles. When the engine went south (spun crank bearings) I found that all 8 exhaust valves were loosing oil through the guides. Since I did the rebuild I've had no codes so my theory is the CATS and stream sensors could not threshold the polluted air I was feeding them hence the coding. If the car is old and worn I'd look to engine components for failure.
uchytil is offline
