Hey guys sorry for the delay. I was not able to get pictures of the install.
Its not too hard
You are going to need to remove the bumper. Its not hard
Pop the hood, take out the clips with a flat head that hold the bumper on to the car.
Each fender has 2 plastic clips use a flat head to remove. Underneath the front bumper are more clips some are hidden. you do not need to remove the middle 2 that are separate it is the air duct.
If you remove it its fine you can easily put it back on.
Set the bumper on soft surface you may scratch it if you leave it on the pavement.
The lights go in pretty easy just follow the picture put them in with the metal bracket.
It goes led light > bumper >metal bracket> open washer > closed washer > nut
ORIGINAL PDF IN JAPANESE INCLUDED BELOW
Its not too hard
