('06-'08) DIY LED trunk strip - Subaru Forester Owners Forum
Old 10-25-2012, 12:19 AM   #1 (permalink)
Car Year: 07
Car Model: XT Type U-nicorn
Default DIY LED trunk strip
Hey guys so I just tackled this project with my great buddy .he is an electrician genius and helps me (which means I watch) with all the electrical ninja things.
We saw this mod on nasioc and he did it to his wagon so it was my turn after bugging him so much haha.
First I picked 5meters of led strip from eBay. It was 17 bucks shipped.
Tools and things you ll need :
Drill and bits
Glue
Tape
Exacto knife
Solder and a some wire
Screw driver and trim remover tool
Marker
So then the install started :
Remove the plastic trim from the trunk (right ib front of the hatch.)use a plastic tool and pry it out. Pretty easy part
Let the part sit and now remove the Light switch where you will be tapping into . At this point just for safety disconnect your battery
Line up the amount of LEDs you want to use and be sure to place them in a straight line and mark it .
Place the led strip and DRILL for alignment purposes into the plastic with a bit big enough that the light will be seen but small enough for it to sit tight . This drilling have to be done ONE by one and slowly to be sure that the LEDs will be matching . Every other hole you drill check for accuracy .you only have one chance to drill
The way the strip gets attached to the plastic is up to you. We used hot glue .carefully between each led hole place some hot glue ,press down and let it dry. Do this on a flat surface.after the whole strip is attached add some additional glue or tape on top of the whole thing just to help it sit there
Go back to the car and sodder the newly installed led negavite and positive wires to your dome light .this way it will mimic its behavior and will shut off when needed . Do this with the battery disconnected for safety .
Tuck the wires in ,reinstall ,clean up ,plug the battery again and you will have something like this .
Enjoy your bright as heaven trunk !
Sent from my SGH-T999 using Tapatalk 2
DIY LED trunk strip-uploadfromtaptalk1351152131313.jpg   DIY LED trunk strip-uploadfromtaptalk1351152201428.jpg   DIY LED trunk strip-uploadfromtaptalk1351152263021.jpg   DIY LED trunk strip-uploadfromtaptalk1351152318547.jpg   DIY LED trunk strip-uploadfromtaptalk1351152437765.jpg
DIY LED trunk strip-uploadfromtaptalk1351152564157.jpg   DIY LED trunk strip-uploadfromtaptalk1351152663978.jpg
rault18 is offline   Reply With Quote
Old 12-07-2012, 03:39 AM   #2 (permalink)
jredd27's Avatar
Car Model: ForesterMY02 Limited
Transmission: 5sp Manual
Lightbulb
This is an awesome idea! I'll defiantly be doing this to mine, thanks mate
jredd27 is offline   Reply With Quote
Old 12-07-2012, 05:34 AM   #3 (permalink)
forester06x's Avatar
Car Model: FXB
Wow, very nice and clean mod! This should be added to the How-To section...
'06 FXB AWP- The GolfBall
forester06x is offline   Reply With Quote
Old 12-07-2012, 06:46 AM   #4 (permalink)
Subiciv's Avatar
Car Model: Forester Premium
Genius! This will definitely help me on my fishing trips. I may have to try this. Thanks
07 GRP Foz
09 SWP Foz
Subiciv is offline   Reply With Quote
Old 12-07-2012, 09:56 AM   #5 (permalink)
Pmund's Avatar
You just spliced in to the dome light and kept the dome light functional as well?
Sent from my iPhone using AutoGuide.com Free App
Pmund is offline   Reply With Quote
Old 12-07-2012, 10:40 AM   #6 (permalink)
Transmission: manual
Pretty cool!
jblewis is offline   Reply With Quote
Old 01-02-2013, 01:40 PM   #7 (permalink)
Car Model: Forester S Turbo
Thanks. This inspired me to do the same in my SF5, as I always use the LED strips in my cars and think they are great
Got it all drilled and fixed up, but its not as simple as connecting to the dome light in and SF5. If you connect before the switch, its a permanent live, so always illuminated. Connecting to the switch, I couldn't seem to find a solution either, as its a 3 ways switch. So its either Dome light on (door open), Dome light off (but LED's on) or Dome light on without LED.
If you have more details on the wire, it would be a great help. thanks
joey_turbo is offline   Reply With Quote
