Alternator wiring - Subaru Forester Owners Forum
post #1 of 23 (permalink) Old 04-15-2012, 05:28 AM Thread Starter
Alternator wiring
Hi,
Upgraded my stereo yet again, have some 0 and 2 AWG cables left and was thinking about upgrading wiring from alternator and battery.
Question is:
1. Can i reuse the original connectors or do i have to get new? Which will i need?
2. Was thinking about 0 AWG from battery negative to chassis
Alternator to battery positive 0AWG
Engine to chassis ground 0AWG
Any thing else? It's an MY06 2.0 NA, i think alternator is std issue here in Norway 110Amps.
Was searching forum, but didn't find any info.
buffv1 is offline
post #2 of 23 (permalink) Old 04-15-2012, 12:46 PM Thread Starter
Ok let me clarify some more.
Alternator is Mitsubishi 23700 AA521 A3TG0491 5X05. It is either 100 or 110A.
Dealer said it was 110A, but it's most likely 100A.
1. I will run 0 AWG from Alternator + to battery +, with a fuse, question 1 how big fuse do i need. 100A? or less.
Mounting on the alternator is 8mm, i think, is that correct
2. I will run 0 AWG from Alternator ground to Engine ground. Do any one have any pictures og good grounding spot there? How is the mounting?
3. I will run 0 AWG from Battery - to chassis (strut housing) and i think that is 10mm.
Do i need to do anything else? Engine to transmission, if so there are those connection.
I live far from any autoshops, and i have to order most stuff to be delivered. Thats why I have all those questions.
Reason for "upgrade" is that i upgraded my audio system and now my lights are dimming than i crank up the volume I have 0 AWG going from battery to fuse/distribution block and 2 AWG to amps from there.
Thx in advance
buffv1 is offline
post #3 of 23 (permalink) Old 04-15-2012, 01:09 PM
Feedback Score: 41 reviews
Do you have an audio capacitor installed to prevent your lights from dimming?
2.5x_sleeper is offline
post #4 of 23 (permalink) Old 04-15-2012, 01:32 PM Thread Starter
Yeah, got 2 actually.
0,8F and 1,3F mounted close to each amp. approx 20 cm
for RF T400.2 and T600.2
Same happening without capasitors. I thought at first it was caused by them (during charge)
I only have like 8 awg from battery to ground, so i think this may cause it. So i'm planning on doing big 3 upgrade. Will it help?
Rgds
buffv1 is offline
post #5 of 23 (permalink) Old 04-15-2012, 07:28 PM
It sounds like you need major power, so your only option may be to install a higher output alternator & the largest capacity battery that you can fit in your Forester.
Of course cleaning all the connections & adding additional grounding couldn't hurt.
post #6 of 23 (permalink) Old 04-15-2012, 11:52 PM Thread Starter
Ok, before i go that way. New alternator and battery (both are 2-3 months old)
I was thinking of giving Big 3 upgrade a shot first.
Biggest question is the size of the fuse between alternator and battery, what size should i put there?
buffv1 is offline
post #7 of 23 (permalink) Old 04-16-2012, 08:19 AM Thread Starter
Any1? 100A, less or more?
buffv1 is offline
post #8 of 23 (permalink) Old 04-16-2012, 08:47 AM Thread Starter
I think I figuered it out, i will use 300A fuse between Alt and Battery, since I'm using 0AWG wire
buffv1 is offline
post #9 of 23 (permalink) Old 04-16-2012, 11:05 AM
No real problems if you're just adding more grounding, but before you start removing & rerouting the 12V power (alternator to battery), I'd suggest you get the wiring diagram, so you know how the existing 12V power is routed.
As to the fusing of the alternator. Unlike the battery, even if you increase the wire size from the alternator, it can only provide the power it's rated at. If the alternator is rated at 100A, that's all you're going to get out of that alternator. As to the fuse, check fuse SBF-1 in the engine compartment fuse box. On my '07 FSXT it's a 120A fuse.
post #10 of 23 (permalink) Old 04-17-2012, 02:32 AM Thread Starter
Ok,
Got a new alternator from Maniac HO 160 AMP, but now a have a different problem.
Then i'm running new ALT output is only 14.05-14.2, My CEL is on and CRUISE is blinking. ODB returns error P2503.
But everything works without any problems (14.05 is lowest with EVERYTHING on). I did not add any extra wiring except extra grounding.
With my old alternator which is actually 110AMP, I read constrant 14.4-14.5, no CEL. But as soon as i turn everything on (light, fans,seat heaters, stereo) It drops to 13.2, no CEL or anything, but my lights dim and start flickering.
Than i changed alternator i did the following
1. disconect bat -
2. disconnect bat +
3. disconnected alt controll plug (3 pin on the alternator)
4. disconected powerwire from alt
5. changed alternator
6. powerwire on
7. controll plug
8. bat +
9. bat -
Did I do something wrong?
Any tips before I go to stealership? Or before i put in old alt?
PS. I tried resetting codes, but they return after 5-10 seconds.
buffv1 is offline
post #11 of 23 (permalink) Old 05-20-2012, 06:30 AM Thread Starter
any1?
buffv1 is offline
post #12 of 23 (permalink) Old 05-20-2012, 06:11 PM
Did you buy the Maniac HO 160 AMP alternator new? If so, I'd also run your problem past them.
Looking over their website, they say you need to run a new cable, 4 gauge (or better), between battery + & alternator charge post is needed as an additional path for current to the battery. They also recommend a 100A in-line fuse.
Any chance you removed the old alternator wiring? From what I'm reading, the old wiring stays.
post #13 of 23 (permalink) Old 05-21-2012, 08:40 AM Thread Starter
Old wiring is still in place. I haven't added new. But i will try and do it in couple of days time, since I didn't have a "small" fuse holder :D
I'll report back then I tried it out.
Just a quick question regarding ODB2, im using ScanXL. When do you reset CEL errors? While engine is running og when ignition is on (just before starting engine mark)?
Cause I'm not able to read any data until engine is started.
Rgrds
buffv1 is offline
post #14 of 23 (permalink) Old 05-21-2012, 09:43 AM
It may be different in your Country, but here in the States, but my Scan Tool will connect to the ECM with the key in the run position without having the engine running... the position just before start or crank.
You can reset CEL when the engine is running, but normally you want reset the CEL before you start the engine. After the CEL is cleared, turn the key to run, but don't start. This gives the ECM time to boot properly after a reset.
post #15 of 23 (permalink) Old 05-21-2012, 10:06 AM
If you're running the old wiring, my guess would be that it should be working. From what I read, the extra wiring was to provide an additional current path to the battery under heavy load.
