Hi all
I am fitting spotlights to my 2011 Forester and wondering if anyone knows which wire at the back of the headlight assembly is the one that goes to earth through the switch for high beam.
I am assuming that that they are neg switched headlights and I should be able to run the switch wire from the relay through the switch and back to the right wire at the back of the headlight assembly so that it earths the relay and pulls the relay on with high beam.
Have looked for this info all over the web but to no avail so far.
Just not sure which wire to use. Would be very grateful for any onfo on this.
Thanks
Cheers, Hugh
Thanks
Cheers, Hugh
