Go Back   Subaru Forester Owners Forum > General Forums > Motorsports
Old 01-12-2006, 10:12 AM   #16 (permalink)
Eclipse's Avatar
Eclipse has disabled reputation
Originally Posted by SnowMan
Who will hit 12's 1st? :D
Subaruman from Puerto Rico almost had 11's
Eclipse is offline   Reply With Quote
Old 01-12-2006, 10:13 AM   #17 (permalink)
Mexican Lorider
SnowMan's Avatar
SnowMan has disabled reputation
I know with a 20G...I meant between he and I on our current setups.
When funds allow, I'll be shooting for 11.501 @ 124.99
2004 FXT 5MT
SnowMan is offline   Reply With Quote
Old 01-12-2006, 10:16 AM   #18 (permalink)
Ze flying Russian
Aleksey's Avatar
Gallery: 5
Aleksey is on a distinguished road
Originally Posted by Aleksey
Aleksey - 1.92 60', 13.224 @ 106.15mph ('04 FXT, 5MT, silver) BDEISTUV
Done 8)
whoever switches to the full 3" exhaust first.
Aleksey is offline   Reply With Quote
Old 01-12-2006, 10:17 AM   #19 (permalink)
Eclipse's Avatar
Ahh.
Minutely better 60' and you would be there.
Do you still have stock wheels and Geo's laying around?
Old 01-12-2006, 10:37 AM   #20 (permalink)
Mexican Lorider
SnowMan's Avatar
I win then...Since I've had one since June. :P
What are you running, a stealth back?
2004 FXT 5MT
Old 01-12-2006, 10:41 AM   #21 (permalink)
Ze flying Russian
Aleksey's Avatar
Gallery: 5
Yes, and 2.5" Prodrive axel.
Old 01-12-2006, 10:50 AM   #22 (permalink)
Mexican Lorider
SnowMan's Avatar
Ahh.
Tell me about it... :roll:
I smoked the stock clutch 1st time at the track with the VF30 setup. With the SPEC stage 2 and 100 more whp/wtq, I can't get a 60' as low as I could when I was bone stock. I don't know if its the CDV or something else but, it just doesnt bite hard on engagement but holds the power in the upper gears. Sort of a tranny saver until I can afford the PPG's
Yep, but 2 of them are flat. Next time out, I'm pulling the mirrors in. That should do the trick.
2004 FXT 5MT
Old 01-16-2006, 06:59 AM   #23 (permalink)
vortmax's Avatar
vortmax is an unknown quantity at this point
vortmax - 1.75 60', 13.14 @104.1 (04 XT, 5MT, OBP) D,E,O,T,%
Jamie
'04 XT
John 3:3
vortmax is offline   Reply With Quote
Old 01-16-2006, 08:39 AM   #24 (permalink)
Mexican Lorider
SnowMan's Avatar
Done 8)
2004 FXT 5MT
Old 01-16-2006, 03:41 PM   #25 (permalink)
Rx
Rx's Avatar
Rx is an unknown quantity at this point
damn you guys are FAST !!!!!!!!!!
Trinbago Subaru Owners Club
www.scoobytnt.com
Rx is offline   Reply With Quote
Old 01-16-2006, 04:05 PM   #26 (permalink)
Eclipse's Avatar
Sweet 60.
Old 01-17-2006, 09:50 PM   #27 (permalink)
dads_cruizzzer's Avatar
dads_cruizzzer is an unknown quantity at this point
Here's mine:
D - Maddad DP
E - 04 STI muffler
H - 05 STI header
I - 04 STI IC
K - 02-03 STI
O - Cobb SS
S - Apex'i N1 c/o
T - Ecutek / I-Speed
U - TXS cast iron
V - VF22 self ported
self ported/installed TGV deletes - you guys gotta do this...
1.92 60', 13.59@104.56, 04FXT, 5MT, PSM
Ran at Los Angeles County Raceway - 2700 ft. elevation, with a little headwind.
Sea Level corrected times:
1.92 x .97 = 1.86
13.59 x .97 = 13.18
104.56 x 1.03 = 107.70
Launched around 4000 rpm with soft drop. A little harder launch and I can be in the 12 sec. club...
dads_cruizzzer is offline   Reply With Quote
Old 01-17-2006, 10:01 PM   #28 (permalink)
Jackhammerhb
Posts: n/a
Nice run Mo, good to see you back.
Old 01-17-2006, 11:23 PM   #29 (permalink)
Mexican Lorider
SnowMan's Avatar
Originally Posted by dads_cruizzzer
Here's mine:
D - Maddad DP
E - 04 STI muffler
H - 05 STI header
I - 04 STI IC
K - 02-03 STI
O - Cobb SS
S - Apex'i N1 c/o
U - TXS cast iron
1.92 60', 13.59 @ 104.56 (04FXT, 5MT, PSM) D,E,H,I,K,O,S,T,U,V,+
1.92 x .97 = 1.86
13.59 x .97 = 13.18
Added TGV Delete to the mod list directory. Thanks for pointing it out, I knew I forgot some things. I'm sure there will be others down the road as well.
Done 8)
dads_cruizzzer - 1.92 60', 13.59 @ 104.56 (04FXT, 5MT, PSM) D,E,H,I,K,O,S,T,U,V,+
FWIW(w/ no affront towards dads_cruizzzer): Using Density Altitude is a better method for correction. Taking into account temp/humidity/baro pressure as well as the actual altitude to determine the correction factor. This gives you a better # for which to compare against (vs Altitude alone). Trust me, weather has a huge impact on times. For us West Coast Floridians, most of the year our DA's are above 2200' ASL when our track is only at 26' ASL. Luckily, altitude doesnt have quite the same effect on forced induction cars as it does on NA cars. For that reason, the NHRA recommends that 1/2 correction factors be used on SC'd and Turbo cars. With that being said most of the time it leaves the DA (on a turbo car) at such a point that correction factors arent even provided for the given DA (ie < 1200' ASL).
Using your time and information from the slip (in addition to www.wunderground.com), I came up with a DA of 2222' ASL at the time of your run. Using 1/2 rule for FI, this leaves you at 1111' ASL and below any NHRA correction factor.
2004 FXT 5MT
Old 01-18-2006, 02:59 PM   #30 (permalink)
No offense taken - I'm learning as I go...
So you mean, it's going to take more than a harder launch to get me 1/2 sec. - into the 12's.
I guess I'm not done modding :D or :x ...
