#17 (permalink) |
Scatter Brain
Updated my setup post in GREEN. :drive:
what's on Moose |
#18 (permalink) |
Scatter Brain
Ploney,
How did the spring swap turn out? Aren't the front and rear springs on the Megans different lengths? I have heard of suby owners running a higher spring rate in the rear and getting positive results. Do you have pics of the STi seats and the harnesses?
what's on Moose |
#19 (permalink) | |
Check the Interior forum thread for seat pictures. Search on "more grip" No pictures of the harness install, yet, stay tuned.
Former SF.org junkie...... Visits for the good company though... |
#20 (permalink) |
I did my swap. I now have Front at 7K, rear at 8K.
I am getting very close to a podium in my class now. Only .7 out of first with street tires versus R comps. Not bad. See my other thread for actual race results. I can control the rear very well now when I want to trail brake into a 90 degree corner. I also went to the STI rear bar instead of the whiteline 24 mm. This combination feels very tossable and predictable. Some of my teammates said I looked very good on course. No pictures at this point though.:tempertantrum Running in the morning is bad for photos. Next time.
#23 (permalink) | |
Scatter Brain
I no longer Auto-X, I just thought this information should be shared.
what's on Moose |
#24 (permalink) |
Some weekend testing and tuning is in order.
Sat. is a practice Auto-X, Sun, and Championship event. BTW, 4 points out of first place in ESP Cal Club Region!! Just upgraded, last night, my front Springs from 7K(380 lb) to 9.5K(525 lb). So far, a few on/off ramps feel incedible on my Falken 615's. Seems like endless front end grip. Now hopefully with the 8K springs in the rear I can still get some mid-corner rotation still. I will be evaluating going to a lesser front bar as well. I'll bring my OE 20mm bar with me to the practice on Sat. just in case. Currently, I have a Cobb FSB, 25mm hollow. Which might be For Sale if I end up changing it to stock. Pray for no rain for me on Sat. Forecast is looking bad. Stay tuned.. no pun intended........
#25 (permalink) |
Good update Plooney. More spring, less bar is understandable. Still on Rs?
I've solo'd three times (STU) and ran two DE's since finishing the "no drop" Megan Racing CO's and getting a good alignment. I'm giving up some CG but the ride is tight and in control. I've way to much front bar (strano) and might be in the market for a Cobb FSB to match my Cobb RSB on stiff. I find the front tire wheelspin on leaving a corner a bummer, not much I can do right??? I think less FSB would help??? This weekend is solo in the Texas Motor Speedway infield, should rain hard all day. I might disconnect my FSB just to keep it between the cones I'll finish out the solo season dialing in. I feel I'm not to far off but only time will tell. Oh. At Texas World Speedway DE I cooked my Falken 615's bad. Sad to see the "new this year" set drip off rubber after the session. First 15 minutes were great then it was slippy city and I came right in. My old style azenies never did turn to mush like this.
Jeff 06'FXT |
#26 (permalink) | |
Oh Yeah, the tires(bimmerworld) are 235-40-17's a little smaller than stock. You'll loose a little top end speed, but they do lower the car about 1/4 inch.
#27 (permalink) |
2004 FXT 5MT
Class: Street Modified Engine - Cobb Stage 2 reflash Injen TBE Injen up-pipe Injen CAI USDM STi TMIC Suspension/Brakes- BC Racing 8k/6k coilovers Whiteline rear strut bar Stock front and rear rotors Porterfield R4-S front pads Hawk HPS pads (rear only) Technafit Stainless Steel brake lines ATE Superblue Dot4 fluid STi 20mm rear sway bar Mo_Boost LLWS Wheels - 5Zigen FN01RC 17x8 wrapped in 245/45/17 Falken Azenis RT615's Interior- CG lock w/ stock seats Megan Racing boost gauge
What's in your wagon? Last edited by ne0stai2dust : 09-01-2007 at 11:45 PM. Reason: updated |
#28 (permalink) | ||
Scatter Brain
The MX's were pretty good to me at autox. Having a co-driver will help keep their temp (and grip) higher than if you drive alone. 41 psi hot is a good pressure to start; I lost grip if I let the pressure get too high.
what's on Moose |
#29 (permalink) |
I'm not going to be using insane springs on the FXT. they will more likely be Swift STi springs or even JDM STi pinks. I dont want to get to aggressive because my car is still somewhat of a daily driver. so using a front strut bar and h-brace shouldnt kill me. but thats just my honest opinion. what's your input?
about the tires, I was thinking about 40psi up front and 35-38psi in the rear to start. what tire pressures were you using with the MX's?
What's in your wagon? |
#30 (permalink) |
When you get tires with better traction you will notice that the abs is then again usable. I started Auto-xing on Falken ST115s. I had to pull the ABS fuse with them. Once I went to Falken 615's all was better, fuse stayed in.
Tire traction in braking is a big factor on the effeciency of the ABS system. BTW, with R compound Kumho 710's, I data logged a 1.06 G braking event at the end of a course once. That's with Hawk HPS pads, SS lines, and OE everything else. Not bad for a pretty much stock setup. I saw that Wagn likes to swap his front pads for track and auto-x days to Hawk HP+ pads. Great idea. I think I will steal that one :)
| Thread Tools | |
