Hi, this is my first post on here. I am a new owner of an 13' X. I have done a few minor mods to it since purchasing it such as installing a homelink mirror, upgrading the door speakers and dynomatting the doors, and installing a rear cargo net.
My next two projects are going to be upgrading the head unit to a double din navigation system with powered sub and trying to install one touch window controls.
It currently has one touch down for the drivers window. I would like to add the one touch function for both front windows in the up and down positions. It appears that the window switches are sourced from Nissan. I know that most one touch window switches have four resistance levels, and that tells the window motor which function is being requested. I am thinking that i should just be able to pick up a switch pack for a Nissan and it will probably work. The problem is the switch packs are not cheap and I would like to be sure that it will work before I spend $120. Has anyone ever done this?
Thanks, Dave.
Thanks, Dave.
