Old 08-15-2007, 12:45 PM   #61 (permalink)
President of MarkyD fan club
toddlamp's Avatar
Why can't someone out east do this and then help me!!!?
Old 08-15-2007, 01:19 PM   #62 (permalink)
The Sub kit guy
sea-scooby's Avatar
When I do my next install I'm thinking I might try to make some very accurate templates and put together a DIY kit. The kit would include the precut MDF, RAAMmat and all that. Screw it in, seal it up and your good to go.
05 Forester X A/T (hers)
My Journal page
Old 08-15-2007, 01:32 PM   #63 (permalink)
toddlamp's Avatar
Thats a good plan. I still haven't figured out how to get the damn siding off.
Old 08-15-2007, 02:43 PM   #64 (permalink)
AwaySooner is on a distinguished road
That's a great idea. Make a kit to replace stock location, and another for the other side. With panel removal instruction. I'll buy it. :)
AwaySooner is offline   Reply With Quote
Old 08-15-2007, 02:54 PM   #65 (permalink)
You probably need to re-enforce the fiberglass with some Bondo maybe. It's a lot of pressure. My single 8" Image Dynamic with 300Watt would move the body panel. You can see it from the outside!
Originally Posted by rok3479 View Post
hahaha.... i'm in san bernardino. i wouldn't mind helping you out, but it was really a huge pita... especially with the fiberglass. if you went without the fiberglass like the other guys with just the raamat.. it won't be nearly as bad. i was just concerned with the stuff flexing with the sub, but i think i made the fiberglass with some leaks anyway, so i guess so much for that solution! where are you located?
Old 08-15-2007, 03:14 PM   #66 (permalink)
sr20dehauler is an unknown quantity at this point
A mass production enclosure will not fit the needs for all subwoofers. Therefore, the enclosure should come with a list of recommended subwoofers. Also, a good rigid fiberglass enclosure will have 4-5 layers of fiberglass mat, which is important if you do not use bracing.
'05 XT 5MT - Daily sleeper
'92 SE-R - Dead
sr20dehauler is offline   Reply With Quote
Old 08-15-2007, 03:33 PM   #67 (permalink)
The Sub kit guy
sea-scooby's Avatar
An MDF/RAAMmat kit would allow for some various in area size and would be very cheap to put together. Most 8" subs require .3-.5 Cu. ft of airspace, so it is rather easy to adjust things to fit that range. A good fiberglass enclosure is just too expensive and time comsuming to produce.
The MDF/RAAMmat option might not be the most ideal enclosure, but when working with such an odd location it is the cheapest and easiest to do. Plus the results are rather good IMO.
My Journal page
Old 08-15-2007, 04:20 PM   #68 (permalink)
rok3479's Avatar
rok3479 is on a distinguished road
excellent idea! i never thought of that! i've always read about people using bondo to smooth out the exterior of it to make it nice and smooth before they paint it, but didn't ever think of using it on the inside! i'll have to try it out... see if it makes a difference. thanks.
rok3479 is offline   Reply With Quote
Old 09-06-2007, 02:10 AM   #69 (permalink)
drrice is on a distinguished road
I am doing this but with my Kicker L7S12" (square kickers but 12") And will be fiberglassing these. I'm probably gonna have to make it protrude alittle out of the trim and reupholster the sucker but I don't mind as long as it looks clean. Todd I'd be willing to help you sometime.
drrice is offline   Reply With Quote
Old 04-21-2008, 12:46 PM   #70 (permalink)
singincanary's Avatar
singincanary is on a distinguished road
Finally got mine buttoned up, thought that I'd share some pics.
For me, it's not a hobby, it's an addiction!!!
singincanary is offline   Reply With Quote
Old 04-21-2008, 02:35 PM   #71 (permalink)
toddlamp's Avatar
That second shot looks weird. Is that of the passenger's side?
Can anyone please tell me the depth from the grill to the metal on the passenger side? I want to install my STi intercooler sprayer there.
Thanks.
Old 04-21-2008, 04:26 PM   #72 (permalink)
The Sub kit guy
sea-scooby's Avatar
He did both sides. I was curious as to what he would do for the passenger side grill.
The passenger side is REALLY tight. I doubt the sprayer would fit. You have about 5.5" to work with and that would be pushing it.
What are the exact dimensions of the sprayer bottle? What I would consider doing is sealing up the pocket and using it as the sprayer bottle. You could have the fill cap right there where the opeing use to be.
My Journal page
Old 04-23-2008, 09:10 AM   #73 (permalink)
Thanks.
Yep, that's the passenger side. Had to figure out how to get a cover to cover it. Ended up using the oem grille sideways to get it to fit. Thought that it looked better than cloth covering and still showed of the sub behind it.
Old 06-03-2008, 04:58 AM   #74 (permalink)
SpaceMonkey's Avatar
SpaceMonkey is on a distinguished road
Got my sub kit (left side only) in a couple of weeks ago. Very well put together kit (thanks Sea-Scooby!) and sounds excellent, although I think I'll have to pull the window trim off at some point and RAAMat it as it does rattle that window a bit when it's cranked up! A second sub would be cool but I probably won;t go there to be honest as I find the pocket pretty handy for storinging a few tools that I want easy access to.
This is the JBL GTO804 Sub that I used:
And here's the finished install:
SpaceMonkey is offline   Reply With Quote
Old 06-03-2008, 07:19 AM   #75 (permalink)
The Sub kit guy
sea-scooby's Avatar
Nice! Looks great!
My Journal page
