('03-'05) How to STOP my trunk from unlocking? - Subaru Forester Owners Forum
Old 01-01-2013, 05:56 PM   #1 (permalink)
Snow drifter's Avatar
Car Year: 03
Transmission: 4 Speed Auto
Default How to STOP my trunk from unlocking?
As the title suggests. Which wire is the wire to the unlock motor for the trunk? where is an easy place to get to it? Would snipping it/putting it on a switch effect anything else?
Snow drifter is offline   Reply With Quote
Old 01-01-2013, 07:10 PM   #2 (permalink)
StealthTL's Avatar
You have a trunk?
StealthTL is offline   Reply With Quote
Old 01-01-2013, 09:25 PM   #3 (permalink)
has awakened!
Feedback Score: 36 reviews
The wiring for the cargo hatch lock motor can be accessed in the cargo area, or in the hatch. Take a look at the wiring diagram below. You don't need the entire wiring diagram to do what you want to do.
Good luck with your project!
The wiring coming down from the right side is the common wiring from the other door locks. You should be able to add a switch (either side) to deactivate the cargo hatch lock motor & it won't affect the other doors. connectors R38/D33 are located back behind the area where the cargo area 12V outlet is located. The other connectors are located in the hatch.
Here's the color code Subaru uses for their wiring.
Old 01-02-2013, 04:06 AM   #4 (permalink)
Car Year: '03
Car Model: Fozzy
Transmission: Eat A Taco
You "might" consider check out the switch that's already there... wouldn't be the first time a mechanical switch has failed, won't be the last I'm sure...
Of course, you could always hack into a system that's likely not been messed with... That's always a good idea..
Old 01-02-2013, 05:16 AM   #5 (permalink)
good dog's Avatar
Car Model: XS
Can you hear the motor assembly click to unlock when it opens? Or is your hatch just randomly opening while you drive?
Based on your location I always think plenty of moisture (rain) so corrosion of some of the connections may be a cause of it, inspect and clean if necessary, use a little dielectric grease in the connections wouldn't hurt either, then test for a few days. And while you've probably done this already but lubing the latch assembly and related parts may also help.
That's all I got.
2008 2.5XS 4EAT
good dog is online now   Reply With Quote
Old 01-02-2013, 05:30 AM   #6 (permalink)
Car Model: XS Premium
I think we need to clarify things a bit. By 'unlocking the trunk' it appears that the member means that he wants to be able to unlock the doors but leave the hatch locked. If this is the case, then Bobby's answer does a fine job addressing the situation. If on the other hand he means that the hatch flies open of its own volition, then this is a totally different matter, probably mechanical rather than electrical.
bbottomley is online now   Reply With Quote
Old 01-02-2013, 05:31 AM   #7 (permalink)
crewzer's Avatar
Exclamation
I'm a little nervous about this.
If you "snip" the lock motor wire when the hatch is closed and locked, then I suspect you won't be able to open the hatch -- even manually from outside -- unless you first reconnect the circuit and send another unlock command to the lock motor.
Similarly, if the hatch is physically open, then the hatch will mechanically close and latch, but I suspect it won't lock without a complete lock motor circuit.
A discreetly located ON/OFF switch sounds like a viable solution.
HTH,
Jim / crewzer
12 Forester 2.5X FB25 5MT Premium AWP PZEV
09 Forester 2.5X EJ25 5MT Premium AWP PZEV (sold 7/2011)
crewzer is offline   Reply With Quote
Old 01-02-2013, 05:42 AM   #8 (permalink)
Yes, a 'user-selectable' snip, i.e. a switch.
Old 01-02-2013, 08:12 AM   #9 (permalink)
The mechanical lock would still work on an '00. If he disconnected the power lock wires from the hatch actuator, it would just keep the power lock switch from unlocking/locking the rear hatch. He would need to use a key any time he wants in the rear.
Example: My driver's door lock actuator is broken. Mechanical lock still works.
ADaughen is offline   Reply With Quote
Old 01-02-2013, 09:54 AM   #10 (permalink)
has awakened!
No key lock on the '03 X hatch.
Old 01-02-2013, 09:58 AM   #11 (permalink)
has awakened!
I'm assuming the need for this MOD has to do with the massive audio system that Snow drifter has in his Forester, so I made a point of not asking why he wanted to do this.
Old 01-02-2013, 10:40 PM   #12 (permalink)
Car Year: 03
Haha yes Bobby, you would be correct.
Where does that mentioned wire run along the car, and where does it end up in the dash/doors? I don't exactly want to snip it inside the trunk latch. That will literally make it impossible to get into with the other stuff I'm doing. And I don't mean hard, I mean physically impossible. Not exactly the one way trip I want to take
And to clarify for everyone: my lock/unlock mechanism works perfectly fine. I just don't want someone to be able to bust my window, hit the unlock switch, then have access to my goodies.
Old 01-03-2013, 08:45 AM   #13 (permalink)
has awakened!
I thought it had to do with your audio gear.
The easiest place to access the wiring, outside of the hatch, is in that area behind the rear 12V outlet. You could cut & splice in wires that run to a switch in a remote, hidden location.
Refer to my previous post for the connectors & wire colors.
