Heater blows cold air! - Subaru Forester Owners Forum
post #1 of 60 (permalink) Old 10-09-2010, 02:09 PM Thread Starter
Yesterday my heater stopped working, as did the defroster on my 98 forester. The fan still works but it won't get hot. The ac still works. Anyone have any ideas on what to do? It's getting really cold here in Alaska and I can't afford to take it to a shop to have them tell me what's wrong. Any assistance would be super appreciated. The car has coolant and does not overheat. Just won't blow hot air.
UnderAKskies is offline
post #2 of 60 (permalink) Old 10-09-2010, 04:40 PM
BAC5.2's Avatar
Car Model: Outback XT-B
Check your coolant level. Heat blowing cold is a sign of extremely low coolant and/or blown headgaskets.
BAC5.2 is offline
post #3 of 60 (permalink) Old 10-09-2010, 05:30 PM
jgrote's Avatar
Check coolant level. If that is good, the problem may be in the dash. You will need to make sure coolant is in the heater core lines. How is it running other than the heater?
04 X a/t
jgrote is offline
post #4 of 60 (permalink) Old 10-09-2010, 05:56 PM Thread Starter
Just changed the thermostat and put new coolant into it. Ran it around the block and then let it sit and idle for about 10 minutes. Still no heat! Could it be a fuse or something like that?
post #5 of 60 (permalink) Old 10-09-2010, 06:03 PM Thread Starter
Also it runs fine except for being cold. No check engine light, no smoke from tailpipe, nothing out of the ordinary.
post #6 of 60 (permalink) Old 10-09-2010, 06:50 PM
Car Model: Mitsubishi Pajero
Transmission: 5spd Automatic
Heater core maybe......
Not sure what happens if that part is defective
Edit: other thoughts would be if you have done anything to your center console. If so you could have accidently disconnected the temp switch from the wire.
07 Mitsubishi Pajero 3.2 5EAT
99 Forester: Sold
Elmy is offline
post #7 of 60 (permalink) Old 10-09-2010, 06:56 PM
FPT_RAIDER's Avatar
i would say more along the lines of an air pocket in the heater core, thats why i love my radkit, it draws a vacuum then sucks all the new coolant in!!!!!! its overkill for a DIY, but for someone who works on cars for a living its great
FPT_RAIDER is offline
post #8 of 60 (permalink) Old 10-09-2010, 07:17 PM
jgrote's Avatar
Air in core is possible. Is the car coming up to temp normally?
04 X a/t
jgrote is offline
post #9 of 60 (permalink) Old 10-09-2010, 07:20 PM
good dog's Avatar
Car Model: XS
Are you leaving the rad cap off when idling? Maybe on a slight incline front higher than the rear. Does the heat dial feel like there is any resistance when you turn it? If a cable clip has come undone, they can be a PITA to get at.
I'll assume you could check the heater lines both feed and return and see if they are warm indicating flow through the heater core.
2008 Forester XS 4EAT
Next TBD?
good dog is online now
post #10 of 60 (permalink) Old 10-09-2010, 07:27 PM Thread Starter
the car temp comes up normally. i am not leaving the rad cap off while it idles, is that something i should do? If there is air in it, how the heck can I get it out? I really dont know much about cars, so i sure appreciate yall offering suggestions and taking the time to reply!
post #11 of 60 (permalink) Old 10-09-2010, 07:28 PM
jgrote's Avatar
I can't believe I didn't think of that. If the lines are warm, your problem is in the dash. Did you change the radio recently?
04 X a/t
jgrote is offline
post #12 of 60 (permalink) Old 10-09-2010, 07:40 PM
good dog's Avatar
Car Model: XS
You would have thought of that See I never thought about a recent radio change, which would likely require the fascia to be removed and those clips are a pain to get at and can unclip if not careful. In an attempt to see if my controls were getting the maximum (Canadian XS's still have the manual knobs ) the dealer (warranty) needed to remove the glovebox to get at them.
Next TBD?
post #13 of 60 (permalink) Old 10-09-2010, 07:56 PM Thread Starter
i have not done anything to the dash, except maybe hit it while in the midst of an epic air drum solo while rockin out! Just went out and took rad cap off to let it idle, but coolant rose above and started to spill and so i turned it off. Also found the fuses and checked them, they are all in tact. Is there too much coolant in it and would that effect it? Do I need to let it run for like an hour or something? I felt the hose that was coming off the rad, its warm after it runs for a bit. Not sure where the return is. I noticed to metal hoses one with an H and one with an L, are those related?
Thanks again for your time folks.
post #14 of 60 (permalink) Old 10-09-2010, 08:15 PM
If it spilled over you got air in the system
I think......
99 Forester: Sold
Elmy is offline
post #15 of 60 (permalink) Old 10-09-2010, 08:53 PM
good dog's Avatar
Car Model: XS
Let it idle for a few minutes with the rad cap off. Usually the fans will cycle on and off a couple of times. I'm going to agree with Elmy, there is still air in the system. How it got there? Has it ever been low on coolant, remember there is evaporation through the reservoir tank over time. If an air bubble is trapped somewhere, changing the elevation of the front end could help displace the air. Even driving up on a couple of 2X4's placed incrementally on top of each other could help, kind of like DIY ramps.
Next TBD?
