AC Compressor Clutch Question - '95 Olds Ciera V6 - Subaru Forester Owners Forum
post #1 of 2 (permalink) Old 12-11-2011, 09:29 AM Thread Starter
Buddur's Avatar
My wife's car is a 1995 Olds Cutlass Ciera SL with a 3.1L V6 engine having ~160K miles.
The AC compressor clutch recently died as it was screaching and giving off metal shavings. A few days ago I replaced the whole clutch assembly. The clutch will NOT engage now when the AC is turned on, and after a few minutes with the engine on it starts squealing like there is rubbing between the clutch and pulley. I'm beginning to believe the original clutch going bad was a symptom of a larger issue and am now afraid I will ruin the new clutch if left as is.
In order to drive the car, I'm inclined to either disconnect the comp's wire harness or remove just the clutch (only running the pulley) to save the new clutch and pulley from being worn down until I can get the larger issue taken care of. I can't see how removing just the clutch would affect anything other than save it from further wear. The pulley is secured to the comp housing with a C-clip, so it's not going anywhere.
Anywho... As an interim measure, is removing the clutch a good idea for now, or will it affect the system somehow that I can't think of? Would it be better to simply disconnect the wire harness to the AC compressor for now?
Any other ideas?
Buddur
2006 2.5X AT N/A
Buddur is offline
post #2 of 2 (permalink) Old 12-12-2011, 06:39 AM Thread Starter
Buddur's Avatar
For now...I simply disconnected the AC compressor wire harness for now. Gooped the terminals with dielectric grease and taped them up to keep out crud.
UPDATE: I had to re-gap the clutch/pulley to stop them from rubbing. Apparently, when I tested the AC after replacing the parts the garage was too cold and the AC would not kick on. Temperature sensor? Today I drove into town and ran the heater to get the passenger compartment purdy darn hot, then when I got home turned on the AC and observed the clutch had kicked in and cold air blowing through the vents. Hopefully this completes this repair </finger's crossed>.
2006 2.5X AT N/A
Buddur is offline
  Subaru Forester Owners Forum > Miscellaneous > Off-Topic
