Old 07-24-2008, 06:16 AM   #1 (permalink)
coopster's Avatar
coopster is on a distinguished road
Default very strange!! is yours the same?
ok i brought a Sigma M30 alarm for my04 sg5 xt
i had some time off work today so i decided to identafi the wires
how ever under the steering colum i found a green one way plug (unpuged)
its a single green plug with a blue wire witch plugs in to a orange wire.
so i plug it in and turned the key to on (not start) and the engine fans came on and ecu warning light started to flash on and off
can some one else check and see if they have the same plug (unpluged)
please.
also there is a second plug the same in the drivers side foot well below the hood pull under the plastic mold that runs along the bottom of the door.
its all a bit mad . make me wonder if there was or is a fault with the foz befor i brought it 5 weeks ago!!!!!
coopster is offline   Reply With Quote
Old 07-24-2008, 06:33 AM   #2 (permalink)
ian0's Avatar
ian0 is on a distinguished road
There are two sets of disconnected plugs in Foresters under the dash. A green set and a black set. They are used for ECU diagnostics when connected. They should normally be left disconnected. The green ones are for the diagnosis, and I think the black set are for resetting error codes or the ECU itself or something like that.
99 Forester S-Turbo 5MT OBP
ian0 is offline   Reply With Quote
Old 07-24-2008, 06:55 AM   #3 (permalink)
coopster's Avatar
sound .....was just look around the interweb and got the same find.
i was just going to drive up to the dealer and give out for a bit>>>>> still might i got the day off and nothing else to do :)
thanks for the quick reply
Old 07-24-2008, 10:09 AM   #4 (permalink)
NorthDownsScooby's Avatar
NorthDownsScooby is on a distinguished road
It's the self destruct - DO NOT connect the green wires... or is it the black ones, I forget
NorthDownsScooby is offline   Reply With Quote
Old 07-24-2008, 12:11 PM   #5 (permalink)
coopster's Avatar
do not go over 50 or is it 60 i forget!!!
Old 07-24-2008, 01:08 PM   #6 (permalink)
stevem's Avatar
stevem is on a distinguished road
88mph , those are the connectors to enable the flux capacitor...
MY01 JDM S/tb VF35, decat, ecutek and other stuff
stevem is offline   Reply With Quote
Old 07-24-2008, 01:25 PM   #7 (permalink)
coopster's Avatar
lol rofl thats good i like that.
mmmmmmmm smile on face you have
Old 07-24-2008, 10:52 PM   #8 (permalink)
deLux is on a distinguished road
in fact you have entered diagnostics mode by connecting green wires
you're sure you didn't try to flash the ECU?
deLux is offline   Reply With Quote
