FSTI Intercooler and duct onto my XT - Subaru Forester Owners Forum
Old 11-26-2012, 09:43 AM   #1 (permalink)
Scc28's Avatar
Car Model: xt
Transmission: magic wand
Gallery: 58
Default FSTI Intercooler and duct onto my XT
Ok guys just seeking info before i start!!
My FSTI intercooler arrived today complete with tray(thanks Ben)
is there anything i need to get prep before install ?
im going to make my own gaskets and also im going to flush the ic with degreaser first to make sure nothing lurks inside.
any pointers welcome
New and Improved 341bhp/355lb
富士重工業株式会社
Scc28 is offline   Reply With Quote
Old 11-26-2012, 11:14 AM   #2 (permalink)
Pindie's Avatar
Car Model: Was XT now WRX STi
Transmission: Man stick
You can flush the IC with isopropyl alcohol for super clean. Just let it dry for 12 hrs before fitting. You can get it very cheap on eBay from Lincoln bio fuels. It also makes amazing screen wash.
Pindie is offline   Reply With Quote
Old 11-28-2012, 08:39 AM   #3 (permalink)
Scc28's Avatar
Car Model: xt
Gallery: 58
is there any chance some one with an fsti can take some pics of there intercooler and the fixings?
cheers guys
富士重工業株式会社
Old 11-28-2012, 09:07 AM   #4 (permalink)
DanFSTI's Avatar
Car Model: Forester STI
these any good
If its larger than the normal one just loosten the bolts on the mounting bars they may then give you enough play to fit the intercooler then retighten them up.
The only fixings as sucah are the two bolts one each end, or are you talking about the turbo connection y pipe on the underside?
DanFSTI is offline   Reply With Quote
Old 11-28-2012, 09:23 AM   #5 (permalink)
Scc28's Avatar
Car Model: xt
Gallery: 58
its shorter than the xt one by a good couple of inches but taller. just trying to figure out which brackets i need. Cheers fella
富士重工業株式会社
Old 11-28-2012, 09:51 AM   #6 (permalink)
DanFSTI's Avatar
If you look at the middle picture looking at the intercooler from drivers side the bracket its secured to has 2 bolt holes and its bolted into the closest one, prehaps yours may be bolted in the outer one, have you removed it to see if thers a closer hole to account for the shorted intercooler.
Old 11-28-2012, 10:18 AM   #7 (permalink)
don1952's Avatar
Car Year: MY11
Car Model: WRX STi Sedan
Transmission: 6MT
Gallery: 3
You won't need any brackets, should bolt straight on as it did on mine before I sold it on to Ben..................
There are two bolt holes on the driver/turbo side - outer hole std XT intercooler; inner hole FSTi size intercooler.
EDIT: Probably easiest to remove the passenger side bracket whilst fitting.
don1952 is offline   Reply With Quote
Old 11-28-2012, 11:35 AM   #8 (permalink)
don1952's Avatar
Car Year: MY11
Transmission: 6MT
Gallery: 3
Some more possibly useful pics....................
Old 11-28-2012, 11:55 AM   #9 (permalink)
Scc28's Avatar
Car Model: xt
Gallery: 58
Don your the man! i found the other hole when i removed mine.
Most of the fins on my xt one were knackered so was a good way to go, also it has the duct that actually fits the scoop rand intercooler
富士重工業株式会社
Old 11-28-2012, 12:15 PM   #10 (permalink)
Banstead Stig's Avatar
Car Model: STI
So you have inherited Don's intercooler... small world this Forester community!
Banstead Stig is offline   Reply With Quote
Old 11-28-2012, 01:07 PM   #11 (permalink)
don1952's Avatar
Car Year: MY11
Transmission: 6MT
Gallery: 3
Came off Marky's FXTi originally
and my bonnet undertray and moulded rubber skirt
Looks like he sold you the samco Y pipe as well
Old 11-28-2012, 01:39 PM   #12 (permalink)
Scc28's Avatar
Car Model: xt
Gallery: 58
There was a blue hose on it, but it was too short as I'm still running the td04 so I was very naughty and chopped up my pro drive y piece to suit!!!!
Also the alloy pipe on the back is slightly different to the one in your pic as its solid alloy y to a short 45 degree. Silicone pipe.
富士重工業株式会社
Old 11-28-2012, 10:25 PM   #13 (permalink)
don1952's Avatar
Car Year: MY11
Transmission: 6MT
Gallery: 3
Ah, I remember, had forgotten the FSTi has the cast Y pipe..........must be going
Old 11-28-2012, 10:45 PM   #14 (permalink)
Scc28's Avatar
Car Model: xt
Gallery: 58
im a little embarrassed when i look at you engine pics vs mine and the general cleanliness of your bay vs mine!!
Theres usually a black trim covering all the gubbins up, but was removed for the work and so i can just keep my eye on things for the next few days!
Need to swap the breather pipes over as mines in better condition, and im not happy re: the fit of the turbo flexible- may have to buy a 45 deg. silicone pipe and cut too suit.
Seems good though, no leaks as i hit 18.5 psi this morning on my commute into work!!
富士重工業株式会社
Old 11-28-2012, 11:43 PM   #15 (permalink)
Car Model: STI
Don't feel bad... most of us mere mortals are unable to keep our engine bays looking like Don's.
