Fault codes - Subaru Forester Owners Forum
post #1 of 21 (permalink) Old 12-04-2009, 09:11 AM Thread Starter
agkq62's Avatar
Car Model: XTEn
Fault codes
The engine light has been on for a couple of days and is showing the following codes:-
P1410, P2441.
What are they please.
Thanks Max.
2005 UK XTEn 4EAT sports shift
agkq62 is offline
post #2 of 21 (permalink) Old 12-04-2009, 09:22 AM
Mad Englishman.
NorthDownsScooby's Avatar
Car Year: MY06
Car Model: Forester STi
Transmission: 6MT
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
Although your codes aren't there !! Strange.#
Try this one - you have to enter in the codes manually:
http://www.equus.com/support/obd2_definitions.php
ex Black 2006 Forester STI
360 bhp / 398 FtLbs
NorthDownsScooby is offline
post #3 of 21 (permalink) Old 12-04-2009, 09:25 AM
FPT_RAIDER's Avatar
both seem to related to the Secondary Air Injection System, try searching the forum, i found, one post related to those codes
P1410=Secondary Air Injection System switching valve stuck open
P2441=Secondary Air Injection Switching Valve Stuck Closed (Bank 2)
Last edited by FPT_RAIDER; 12-04-2009 at 09:28 AM. Reason: found codes, cus im just that nice
FPT_RAIDER is offline
post #4 of 21 (permalink) Old 12-04-2009, 09:34 AM
Mark CSC's Avatar
Car Year: 97
Car Model: JDM S/tb
Done some googling becasue I'm bored
The list of Subaru codes is here Scoobypedia | Trusted knowledge for everything Subaru | Knowledge / OBDII Trouble Code Definitions
However yours are not on it.
P1410 - EGR Valve Position Sensor Circuit Malfunction (odd because I didn't think turbo cars had them)
P2441 - Secondary air injection relay "B" switching valve stuck closed bank 2
{edit
Oh arse, beaten to it while Googling.
97 JDM S/tb with a proper gearbox ;)
Mark CSC is offline
post #5 of 21 (permalink) Old 12-04-2009, 09:45 AM
FPT_RAIDER's Avatar
im not likeing that the codes are coming up as diff things, ill check it at school today
post #6 of 21 (permalink) Old 12-04-2009, 11:08 AM Thread Starter
agkq62's Avatar
Car Model: XTEn
Trust me to come up with something strange. I think only 06 2.5 Turbos have auxilary air injection. It will be interesting to see if the warning light returns.
Incidentally why on earth does it flash the CRUISE and put on the ESP light at the same time? The flashing CRUISE is most annoying.
Max.
agkq62 is offline
post #7 of 21 (permalink) Old 12-04-2009, 12:09 PM
don1952's Avatar
Car Year: MY11
Car Model: WRX STi Sedan
Transmission: 6MT
Max.
A similar incident here............................ post6 may be significant
Check engine light on and cruise flashing - ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
don1952 is online now
post #8 of 21 (permalink) Old 12-04-2009, 01:15 PM
vuk
vuk's Avatar
Car Year: MY08
Car Model: 2.5XT Turbo
It got to be this:
Five days ago I was shocked to see Cruise Light on flashing, Engine Light on and skid light on on my MY08 2.5XT with just 33.000km. After some 4 starts the lights on the dashboard pointing to some failure disappeared but I took my Foz today for an inspection at the Subaru Service Centre in Belgrade (Serbia) and what they found was P1410 code - secondary air valve failure!
It took two guys just an hour and 20 minutes to take out the valve, disassemble it and to put it back - they complained how difficult is to access the valve within the engine bay and I saw it my eyes... That valve - when opened was pretty wet and dirty - guys just cleaned the parts using cloth and sanding paper! They also claim that this problem is very common on turbos specially when driving in pretty rainy or snowy conditions and that it might have happened even before. They checked the engine status with the computer and no problems found.
I paid not money as my car is under 3 year warranty! Sincerely, I'm not sure if this problem would not surface again... Stay out of water!
Good luck!
Subaru Forester 2.5XT MY2008
vuk is offline
post #9 of 21 (permalink) Old 12-04-2009, 05:12 PM
FPT_RAIDER's Avatar
i said i would check at school and i did! anyway the codes are manufacturer specific and as such i was unable to pull them up on the software we use at school (alldata) as it seems subaru felt it didnt need to release them, but it seems i was right from the searching i did online, Secondary Air Injection System, during my search i found that P1410 is a toyota code for their EGR system which is where im thinking mark CSC went wrong, just a guess, your best bet is to go to a dealer tho
PS dont let the fact that im stateside turn you off, all the teachers i have talked to agree that the codes should be the no matter where you are
post #10 of 21 (permalink) Old 12-07-2009, 12:56 AM Thread Starter
agkq62's Avatar
Car Model: XTEn
Thanks all the your input, it looks like something on the auxilary air injection is favourite. I had an engine light quite a few months ago which went out of its own accord, possibly that could be the first code.(how long does the computer keep codes?)
Both times the light has come on I have turned the engine off at quarter warm and then restarted.
I can't quite understand how the cutoff valves could get water in, the air pump is very high up and only runs for a short time. Although I have just done a very wet journey to Manchester and the ford just outside my village is quite deep at the moment.
I see from the parts diagram there are two cutoff valves, one for each bank. Would each have aa different code?
Max.
agkq62 is offline
post #11 of 21 (permalink) Old 12-07-2009, 01:41 AM
don1952's Avatar
Car Year: MY11
Transmission: 6MT
Ma,
Just to clarify, the secondary air system is fitted from MY06 onwards, so your 2005 registered UK XTEn 4EAT sports shift is actually a MY06.
MY06 usually arrive in the UK around about Nov of the preceding year.
post #12 of 21 (permalink) Old 12-10-2009, 02:10 AM
don1952's Avatar
Car Year: MY11
Transmission: 6MT
Max,
A bit more info into possible problem.....
2006 Forester C/C Blinking - Subaru Forum | Subaru Impreza | Subaru Parts | WRX STI
post #13 of 21 (permalink) Old 12-10-2009, 04:20 AM Thread Starter
agkq62's Avatar
Car Model: XTEn
Thanks for that Don. Now to really test your metal, which is "bank 1"?
Thanks,
Max.
agkq62 is offline
post #14 of 21 (permalink) Old 12-10-2009, 04:32 AM
The Rookie's Avatar
Car Year: 99
Car Model: UK S-turbo
Left hand bank as you look into then engine bay is the international standard for Bank1.
Simon
The Rookie is offline
post #15 of 21 (permalink) Old 12-10-2009, 04:48 AM
don1952's Avatar
Car Year: MY11
Transmission: 6MT
Thanks,
Max.
At a complete guess, I would think "Bank1", in this case, is the Right hand bank of cylinders looking forward, supplied by the front secondary air suction valve.(marked 14864A-red) on attached........
14864-green supplies the second bank (OBD code P2443)
Have just found this, click on the answer pictures for the test procedure pages.
It relates to P2243 unfortunately.
I have a P2443 code, 2007 WRX "Sec air inj. syst... - JustAnswer
