This is what I have bought so far
Engine/Drivetrain Modifications:
RCM Thermostat
Cosworth Panel Filter
STI Genome Exhaust
Double wrapped turbo blanket
Walbro RCM Fuel Pump
Beatrush Radiator Shroud
Forester Genuine STi 1.3 Bar Rad Radiator Cap
Genuine STi Red Embossed STI Intercooler Hose
vf23 Turbo
Samco Intercooler Y pipe kit
Suspension Modifications:
Whiteline ALK Motorsport Bushing
Whiteline Roll Centre Kit
Whiteline Steering Rack Bushes
STi Alloy Wishbones
SF5 Pink Lateral Arm Kit
S202 Pink Trailing Arm Kit
Whiteline Subframe Lock Bolts
Whiteline H-Brace / Subframe Kit
Whiteline Front Anti-Roll Bar 22mm Adjustable
Whiteline Rear Anti-Roll Bar 24mm Adjustable
Whiteline Rear Drop Link Set (Alloy)
Whiteline HD Rear Sway Bar Mount Kit
Whiteline Rear Strut Brace
Whiteline Front and Rear Camber Bolts
Group N Gearbox Mount
Beatrush Gearbox Craddle Bushes
Beatrush Linkage Bushes
Beatrush Subframe Brace
Beatrush Diff Outrigger Bushes
Beatrush Pitchstop
Beatrush Rear Diff Brace
Beatrush Solid Prop Bushes
Group N Engine Mounts
Tein Strut Brace Front
5 Speed ICP Gearlever Rebuild Kit
Wheels/Tires Modifications:
STi Limited Wheels
234/40/18 Federal RSR
Interior Modifications:
KS3 Knock Monitor
New OEM Gearknob
New OEM Gear Lever Boot
Kenwood DVD Double Din
SF5 OEM Boot Liner
SF5 OEM Cargo Net
V2 WRX Sti Seats purchased but might not fit
Exterior Modifications:
Front Brembo Brakes
Rear Brembo Brakes
Front and Rear Discs
DEPO Smoked Side Repeaters
Front Fog Grill
Replacement Engine Sump Cover
Uprated Bulbs Front and Side
Servicing:
Motul 90PA - 2ltr
Motul 300v 15/50
Motul Inugel Optimal- 5ltr x2
Black Oil Filter & Washer £8.99
Redline LWSP Gear Oil
Motul 600
