Tire pressure for 225/55R17 new tires (Hankook Ventus ST) - Subaru Forester Owners Forum
post #1 of 26 (permalink) Old 08-05-2008, 09:04 AM Thread Starter
Car Model: 2.5XT
Question Tire pressure for 225/55R17 new tires (Hankook Ventus ST)
Hello there,
I'm replacing the nice and beautiful Geolandars with a set of 225/55R17 Hankook Ventus ST, and was wondering what pressure I should put into them...
The max. air specified for them is 51psi. Their max. load is 2094 lbs.
What should I run, then?? The Geolandars where using 36/35 front and rear... I want performance. Good driving. Why am I getting these Ventus if not....? ;)
I would appreciate your input, guys!
Cheers,
MO
mvorchard is offline
post #2 of 26 (permalink) Old 08-05-2008, 09:15 AM
kamil212's Avatar
Car Model: Sexually Trans infec
Transmission: 6MT
I would run the same 36/35
kamil212 is offline
post #3 of 26 (permalink) Old 08-05-2008, 09:30 AM
Galager's Avatar
Car Year: 13
Feedback Score: 12 reviews
^^+1. That's what I run in my Yoko's.
'05 XT 5 spd VF - SOLD
'13 XT Touring
Galager is offline
post #4 of 26 (permalink) Old 08-05-2008, 09:42 AM
The Sub kit guy
sea-scooby's Avatar
Feedback Score: 79 reviews
I ran 36/35 with my 225/55/17 RE92s.
05 Forester X A/T (hers)
sea-scooby is offline
post #5 of 26 (permalink) Old 08-05-2008, 09:46 AM Thread Starter
Car Model: 2.5XT
Thanks, guys........
Just found that Hankook recommends about 90% of tire's max. air... and that would be 46psi for these Ventus..... sounds high.... but given that their maximum is 51, which is among the highest I've seen............ I thought it'd be necessary a much higher pressure than ~35...
What do you think?
post #6 of 26 (permalink) Old 08-05-2008, 09:49 AM
kamil212's Avatar
Transmission: 6MT
Tire pressure should be what the car's spec is, not the tire's.
Just stick to 36/35 unless you're doing crazy hard-breaking turns that could roll your tires off. (I run about 40 upfront when AutoXing)
kamil212 is offline
post #7 of 26 (permalink) Old 08-05-2008, 10:04 AM Thread Starter
Car Model: 2.5XT
Completely agreed with you, and this is what I've done with every car that I've owned...... but it is simply not the case for my Forester..... the one recommended is WAY TOO low.....
Is there anything like a "rule-of-three-calculation" given that you have max. load capacity available as well?? What should be the minimum tire pressure?
Cheers,
MO
post #8 of 26 (permalink) Old 08-05-2008, 10:42 AM
ArcadeTom's Avatar
As a former owner of a Ford Exploder, I would suggest running what the sticker says on your door post unless you are racing, autocrossing..etc.
2009 XT, Camillia Red Pearl
ArcadeTom is offline
post #9 of 26 (permalink) Old 08-05-2008, 10:46 AM
Feedback Score: 41 reviews
IMO the tire pressure posted on the door is a compromise between a ride comfort & reasonable rolling resistance (gas mileage), with the scale tilted towards comfort, hence the low pressure recommendation. I don't think the factory really cares about tire life or performace on the Forester...
The tire pressure will vary between tire brands. I'd suggest starting with the pressure that felt right on your previous tires. I'm running Toyo Proxes 4, 235/50-17, 36/34 (front/rear pressure). After playing around with different pressure combinations, this is what feels right on my ride. A higher tire pressure makes my ride susceptible to bump steering on rought roads & too low pressure makes my side walls roll too much...
2.5x_sleeper is offline
post #10 of 26 (permalink) Old 08-05-2008, 11:11 AM Thread Starter
Car Model: 2.5XT
Hopefully, they will be on tonight. Will report back with experiences...
Many thanks!
MO
post #11 of 26 (permalink) Old 08-05-2008, 11:44 AM
IIRC, the Exploder's recommended pressure "pre tire fiasco" was under 30 psi's. 28 or 26 seems to ring a bell.
I run 34/33 on summer 225/55/17's for everyday driving and bump it up for more spirited driving.
-Dennis
2004 PSM FXT
bluesubie is offline
post #12 of 26 (permalink) Old 08-05-2008, 12:51 PM Thread Starter
Car Model: 2.5XT
Actually, it is much worse to run the tires underinflated than it is running them overinflated... I'm looking for the right pressure.
What I don't get though is why would you be in a overinflated situation using anything below the actual max. air determined by the tire.
I did run a small "rule-of-three" calculation (don't know the name in English, don't blame me... ;) ), and using 35psi as the minimum value and 46 (51x90%) as the maximum, 55/45 as the weight distribution, and the tire max. load capacity I've gotten 40/39. I will use that as the starting point.
Please don't be too sarcastic - it is just that I can't avoid being an engineer all the time... :p
Cheers,
MO
post #13 of 26 (permalink) Old 08-05-2008, 01:20 PM
ArcadeTom's Avatar
-Dennis
Sorry for the misunderstanding, but what I meant was that on the next generation Exploders (and the resulting education that came out after the designers and NHTSA people all met and cussed and discussed all the issues) they seemed to make it clear that what is posted on the door/vehicle is what is reccomended for daily use in the majority of driving situations. It was supposed to be based on the suspension, spring rates and weight of the vehicle. The first generation Exploder was listed with incorrect and low pressure stickers. Anytime that you switch tires sizes, wheel diameter, etc you will have to find something that works, but if you are running the same size tire with the same load rating, I would think you're probably going to stay in that same pressure range.
All other things considered...you could always ask the tire store owner / manager or get it in writing from them as to what pressures you shoudl run with a certain tire. If it blows out at least you have someone to sue. LOL
post #14 of 26 (permalink) Old 08-05-2008, 04:59 PM
Aluma's Avatar
Car Model: WRX
PLUS, dont forget to buy more than one tire pressure gauge! I have two, and they are about 7 psi different! :P Now my concern is...which one is right? :O
Aluma is offline
post #15 of 26 (permalink) Old 08-05-2008, 10:58 PM
John XT's Avatar
I would use 34 on the front and 31 on the rear. 34 goes easily to 40 when you are hard cornering at summer and 31 is OK to avoid oversteering when you lift your foot of the gaz pedal to enter in a turn. 31 is also OK to have some ride confort. If you have perfect condition roads where you live, you can use more, in order to also have some fuel economy IMHO...
thre are some tires like all toyos who likes high pressures, I don't know why.
Keep in mind that with normal air (not azote) the pressure at high tire temperature ie70 degrees celcius (wich is normal after hard cornering) maybe more than 20% greater than when the tire is cold. (tested a lot of times)
FXT 2.0 '04 MT
270Bhp, 40BNm@3200 tuned by "moi"
John XT is offline
