How often rotate tires for 09? - Subaru Forester Owners Forum
post #1 of 13 (permalink) Old 10-06-2008, 12:18 PM Thread Starter
Hi!
I noticed that my owners manual for my 2009 says that I should rotate the tires every time I get an oil change (at every 3000 miles or so). Is this truly necessary or could I get away with every other oil change? I'm new to AWD, but am on a budget.....
Fishy159 is offline
post #2 of 13 (permalink) Old 10-06-2008, 12:20 PM
The Sub kit guy
sea-scooby's Avatar
Feedback Score: 79 reviews
I personally do it every oil change on the XT since i drive it harder, but I do it every other oil change on the X since my wife takes it easy. Buy a $50 2.5 ton floor jack and a set of jackstands and you can rotate them very quickly. It worth it to spend a few buckst to get the most out of your tires which cost a lot more.
05 Forester X A/T (hers)
sea-scooby is offline
post #3 of 13 (permalink) Old 10-06-2008, 01:12 PM
johnsora's Avatar
Car Model: Forester X Prem
If I remember correctly, the official oil change interval on the 09s is 7500. Only the first oil change is at 3000. I just had my 7500 service done, which was an oil change and tire rotation. Although the dealer put a sticker on my window to come back in 3000. That was my last free service, so perform my own maintenance now. So you are fine rotating every 7500.
johnsora is offline
post #4 of 13 (permalink) Old 10-06-2008, 01:13 PM
neoshi's Avatar
Car Model: XSsss..
Feedback Score: 32 reviews
^^what sea-scooby said. ANY car should follow pretty much that plan, AWD or not if you want to get the most out of your tires. Else, 25k down the line on spirited driving, 30k-ish on regular driving, Geolanders go bald on one side or the other, usually on the outer edge. DIY is the best and cheapest! Oh, besides the jack and jackstand, get a torque wrench for the lugs.
05 XS
neoshi is offline
post #5 of 13 (permalink) Old 10-06-2008, 01:58 PM
El Sid's Avatar
Car Model: Forester Sport XT
I rotate every oil change (3000) and need to as the fronts are a fair bit different by then. If you are a smooth and calm commuter type, you could go the 7500 - but as always - Your Milage May Vary.
My 626 was hard on tires and I couldn't wait that long - 3000 was the total life of the tire. At least I got to try lots of different brands!
El Sid is offline
post #6 of 13 (permalink) Old 10-08-2008, 08:02 AM
DOHC_Holiday's Avatar
You were only getting 3k TOTAL from your tires? Damn, what is that like a 100 tread wear rating?
"Wa qad u'thira man anthar."
DOHC_Holiday is offline
post #7 of 13 (permalink) Old 10-08-2008, 08:26 AM
El Sid's Avatar
I don't remember - Yoko A008, A001 were among the worst. The 3000 total was when I didn't rotate them and the whole 3k was on the front.
I wondered why I couldn't keep them in balance on a set of Comp T/As and made marks on the tire by the stem. Found out they were moving around the rim under braking.
I ended up rotating every other week when I washed the wheels.
El Sid
El Sid is offline
post #8 of 13 (permalink) Old 10-08-2008, 09:01 AM
El Sid
Do they make beadlock rims in our size? lol
post #9 of 13 (permalink) Old 10-08-2008, 02:02 PM
vintage42's Avatar
Car Model: LL Bean (4EAT)
Originally Posted by Fishy159 View Post
... I noticed that my owners manual for my 2009 says that I should rotate the tires every time I get an oil change (at every 3000 miles or so). ....
I think you have misunderstood the interval. The manual says to rotate the tires in conjunction with Subaru's recommended oil change interval. Not your own preferred interval.
The manual was written before the bulletin that reduced the turbo oil change interval to 1/2 that of the NA.
2008 LL Bean
vintage42 is online now
post #10 of 13 (permalink) Old 10-08-2008, 02:07 PM
Car Year: '09
Car Model: STI
Rotate when the difference in tread depth exceeds 1/32".
The A008Rs were the worst for me. UTG of 60 IIRC. On a 911 with the staggered sizes it was about 3k or so per rear set. Good thing was back then R compounds were actually cheaper than normal tires.
'09 STI
The Black Box is offline
post #11 of 13 (permalink) Old 10-09-2008, 02:09 PM
YoGeorge's Avatar
Yup, just rotated at 7500...
I just rotated the Duelers on my '09 FX today, at 7485 miles. They're wearing quite well, with a tiny scallop on the outer tread blocks, more pronounced on the fronts. Went fronts to rear, crisscrossed rears to front.
I keep wanting to get some more macho tires, mostly for looks, but the Dueler 687's are so decently even-tempered that I can't bring myself to do that. (Plus new tires, especially Michelins, are so expensive these days...) I'd love something like Michelin ATX M/S's on the Foz, but besides the cost going in, I'm a bit concerned about gas mileage--I would have to move to a 215/70x16, a bit taller, so it would give me a bit longer gearing, but they weigh about 30 lbs per compared to 23-24 for the Duelers.
George
'09 FX non-premium, 5MT
119k miles (bought new)
YoGeorge is offline
post #12 of 13 (permalink) Old 11-18-2011, 12:54 PM
Do it every 7500 miles....like the manual says.
Front and rears wear differently and Discount Tire/America's Tire will do it for free......even if you didn't buy tires from them!
I usually tip the guy $5.00.
Phil C.
(SOLD) 2005 FXS LLB
philbytx is offline
post #13 of 13 (permalink) Old 11-18-2011, 05:00 PM
rusty jake 11's Avatar
Transmission: 4eat ss
I rotate in the spring and in the fall. Did I mention I do the 3 season/winter tire switch over at the same time? Works for me ;-).
2010 Forester Touring/Newport blue/4eat ss
rusty jake 11 is offline
