#16 (permalink) |
Car Model: Acura TSX SE
Transmission: 6MT
Feedback Score: 12 reviews
You still have your stock Forester struts? Measure distance from bottom of strut to lower spring perch. Forester perches will be higher than WRX. Using Forester rear struts with WRX springs would result in exactly what you have.
Disconnect the rear sway bar to make sure it's not binding, though I doubt it could support that much weight. Stan
Shocks > struts. |
#17 (permalink) |
I'm not really sure what you mean by this. I'm fairly certain that the end links have not been touched since the car rolled off the production line in 2004. Most of the suspension items looked to be about 95K miles old from the looks of it.
#18 (permalink) | |
![]() Raise the car, disconnect swaybar, lower car, reconnect, re-evaluate ride height? Last edited by Beep_09; 12-10-2012 at 07:05 AM. Reason: addition |
#19 (permalink) |
Car Year: SG9
Transmission: Stick Shift
The end link have the tendency to over extend and flipped the other way when you disconnect the strut. Then basically it jammed itseft to the lateral link and prevent the suspension to cycle properly.
#20 (permalink) | |
Transmission: 6MT
Stan
Shocks > struts. |
#21 (permalink) | |
#23 (permalink) |
After getting the rear back in the air it did not appear that the swaybar had flipped whatsoever.
We also measured the struts and the new ones are a full inch shorter from bottom to lower perch.... At this point all I can hope for is that the struts are so cold and having been uncompressed for awhile in the cold are having a hard time settling down. Maybe once we finish and go for a quick drive it will settle in. ![]() At this point hope is my strategy. |
#24 (permalink) |
Car Model: 04 FXT, 61 Stude
Stand on the rear bumper and jump up and down. That's what I always do lol
Giant 29er - 04 FXT MT - 61 Studebaker Lark |
#26 (permalink) |
Transmission: 6MT
Dampers cannot support the weight of the car. Having shorter springs in rear than front will result in rear sagging as we all know. You can do the fronts to see what happens, but your problem will still exsist IMO.
Stan
Shocks > struts. |
#27 (permalink) | |
The only issue I'm aware of from lowering the car is changing th geometry of the suspension and added pressure on the end links. If I'm running on an impreza chassis and the weight of my car is not much different than an impreza why would putting impreza suspension on my car end in this result? |
#28 (permalink) |
Should be able to by tonight. I had to get the lower ball joint pressed into the hub on the front left, which my neighbor should be doing for me today. Once that is complete I can finish it up and put it on the floor...so many problems but you know 8 yr old car so what do you expect.
#29 (permalink) |
Car sitting high after jacking up... FIXED - Page 2 - NASIOC
I found this thread over on Nabisco...this guy had water in his strut which didn't allow it to compress to the right height. Hydrolocked strut...unlikely but possible give that I bought them from a wrecked car off of CL. |
#30 (permalink) | |
Car Model: Forester S
I'm not jumping to any conclusions saying that that will fix anything... (so it would be nice if people would stop insinuating that) but having the car settled on all fours will give a better synopsis of what's going on. After that then everyone can jump forward and give you better direction on how to fix it if it's still an issue. |
