strut life - Subaru Forester Owners Forum
post #1 of 19 (permalink) Old 01-16-2011, 03:16 AM Thread Starter
urabusasnwonatas's Avatar
Car Model: FAXT
Transmission: 5mt
strut life
what should the average life span of a oem strut be/ 06 fxt? . i have a clunk going on in left front wheel area , but nothing i have checked is loose. has antbody came across this and can shed some light on the problem?
urabusasnwonatas is offline
post #2 of 19 (permalink) Old 01-16-2011, 06:15 AM
plazaxt's Avatar
Car Model: forester xt
Transmission: 5speed
im at 73k miles of hard driving n lots of off roading still going strong.
2006 XT5spd
1995 GST 6bolt
79 RX7
94 fzj80
plazaxt is offline
post #3 of 19 (permalink) Old 01-16-2011, 07:58 AM
MoxoM's Avatar
Car Model: X Premium
I had a similar issue and it turned out to be a worn end-link for the front sway bar.
2006 Forester 2.5X Premium
4EAT
MoxoM is offline
post #4 of 19 (permalink) Old 01-16-2011, 08:32 AM
stan_t's Avatar
Car Model: VW Golf SportWagen
Feedback Score: 12 reviews
Average, maybe 60K. I'd say, it really depends on the road conditions and your driving style, if you attack speedbumps without stopping they won't last too long. Some can probably still work at 100K, and some will be blown at 40K.
I am betting most people with blown struts don't really know it until something really goes wrong, like clunking. Only way I know to check is to take them off the car, remove tophat and spring and try compressing the damper shaft in/out. It should have resistance going down and should come back up on it's own.
Stan
Shocks > struts.
stan_t is offline
post #5 of 19 (permalink) Old 01-16-2011, 09:04 AM
Snoshado's Avatar
Car Model: STI
Transmission: 6MT (2005)
Yeah I have '04 WRX struts that have been blown for a long time. Definitely depends on your driving style..
@Stan, is it bad to drive with blown struts? I've been told no but am a bit concerned and could drop money on some new ones if necessary.. thanks!
Snoshado is offline
post #6 of 19 (permalink) Old 01-16-2011, 04:52 PM
stan_t's Avatar
My Miata and Passat were both on original struts/shocks. Both were shot when I was replacing them. Both cars still worked fine, Miata actually did quite well on blown shocks (they were 170K old, Miata shocks are considered blown at 40K). Passat had 100K on it, and I could definitely tell those things were gone. My LS400 has original shocks and 185K on the clock, but I ain't touching it.
If it ain't clunkin and you are fine with the handling and ride, just keep going I wouldn't install blown OEM dampers back on though if they were removed, GR2s are cheap enough.
Stan
Shocks > struts.
stan_t is offline
post #7 of 19 (permalink) Old 01-16-2011, 05:38 PM Thread Starter
Car Model: FAXT
Transmission: 5mt
right on , thanks for the feed back i have came to the conclusion that the struts fine. it seems to be coming from that area. and only when i'm at crusing speed 30 to 40. when i have a good load on the throttle no clunk. possible drive shaft bearing.?
post #8 of 19 (permalink) Old 01-16-2011, 05:38 PM
Snoshado's Avatar
Car Model: STI
Stan
Good to know My struts are super noisy and clunky and my mechanic even said they needed to be replaced.. I guess in two weeks the foz gets some GR2's.. finally!
Snoshado is offline
post #9 of 19 (permalink) Old 01-16-2011, 05:41 PM Thread Starter
Car Model: FAXT
Transmission: 5mt
going to check sway bar end link. sounds feasible but .
post #10 of 19 (permalink) Old 01-16-2011, 05:45 PM
stan_t's Avatar
GR2s should be fine if you are sticking with OEM WRX springs, which isn't bad at all.
Bearing.. I don't know, I'd imagine a failed bearing would make a grinding noise at all times. Maybe worth taking it to the shop to have them check it out, or maybe just showing up at a local Subaru meet to have someone knowledgeable drive your car and give you an opinion.
Stan
Shocks > struts.
stan_t is offline
post #11 of 19 (permalink) Old 01-16-2011, 05:59 PM
Snoshado's Avatar
Car Model: STI
What's a failed bearing? Wheel bearing?
I took mine to my trusted Subie / Saab shop and the owner told me it was my struts. and he's a genius.
Snoshado is offline
post #12 of 19 (permalink) Old 01-16-2011, 10:50 PM
zymmer4's Avatar
Car Model: ForesterXT premeium
struts
My 2005xtp has 73000 miles on it..The struts will need to be replaced very soon.
2005 XT-P...bone stock..
zymmer4 is offline
post #13 of 19 (permalink) Old 01-17-2011, 06:43 AM
The Rookie's Avatar
Car Year: 99
Car Model: UK S-turbo
Independant testing has show struts that still appear 'good' can increase stopping distances under hard braking by as much as 10%, 'blown struts' nearer 20%.
Simon
The Rookie is offline
post #14 of 19 (permalink) Old 01-21-2011, 04:08 AM Thread Starter
Car Model: FAXT
Transmission: 5mt
when i say bad bearing i was referring to the bearings in the top hat.
post #15 of 19 (permalink) Old 01-21-2011, 05:09 AM
sooblover's Avatar
Transmission: 6MT DCCD (helical)
What mods do you think Satan has done to the Subaru he owns? And what model?
...anywaaaay, maybe you can check for tophat bearing play by pulling the strut and playing with the top hat? Or maybe the play will only come about with the weight of the car on it? Dunno...
my build journal:
sooblover is offline
