('01-'02) Slamming a Forester - Subaru Forester Owners Forum
Go Back   Subaru Forester Owners Forum > Technical Forums and Vehicle Assistance > Suspension and Handling
Old 08-28-2012, 08:02 AM   #1 (permalink)
naCAnItihS's Avatar
Car Model: Forester L
Default Slamming a Forester
More Pix at posts #7, #15, #55 and #63 (new)
Ok so I just recently bought a 2001 Forester L and there was no way in hell I was driving it stock haha
So I decided to slam the crap out of it!
I went ahead and did some research on here as well as use my vast subaru knowlege ;) (was a subaru tech at ajw performance for a year and a half)
I sourced most of the parts at the local pick and pull from a 90s Impreza wagon (except the actual suspension)
Parts:
-06 WRX Sedan Shocks and Struts (70k) with Eibach Sportlines (no spacers)
-Engine cradle bolt brackets (2)
-Trans cross member bolts (2)
-LCA Mounts (2)
-Shifter linkage and bushings
-Rear Sway Bar mounts (brackets) (L&R)
(I am also unsure why the flash made all the light rust look completely horrible...)
I didnt take pictures of everything but this is how I did it:
**SPRAY EVERYTHING WITH PB BLASTER FIRST**
I also used an impact gun for the majority of things to make it easier.
First off put the car on 4 jack stands (high enough so you can crawl under the car). I started with the rear suspension because there was less things to do.
Idk why subaru decided to do this on the older subarus but in order to remove the shocks you have to disconnect the brake lines... I was not about to do that and have to bleed the entire system. So I just removed the retainer clips, pulled the line as far out of the way as possible and used a cut off wheel to cut the bracket. Then I took a hammer and bent it out of the way. (and YES you have to do this to all 4)
Next I Removed the two bolts 19mm bolts that hold the shock to the knuckle. Next go into the hatch and pop the rear shock tower covers off (flat head screwdriver) and then remove the 3 12mm nuts holding the shock in. The shock will probably fall onto the ground or just slide down a bit. (it helps to have someone to help you but i did not). Do this to both sides.
Next I removed the 12mm bolt holding the rear sway bar to the mounting bracket on both sides and wiggled the bar free. Then there is just two 12mm bolts holding the bracket onto the frame. As you can see the Impreza ones are much shorter.
Then just reverse these steps (using the Impreza items) and you are done with the rears. (Use a jack to jack up the knuckle to hold the shock in place to get the bolts on)
And now for the front
First loosen/remove the the 12mm bolt that clamps the steering linkage to the steering column. Spray it with PB Blaster. This is so when the body lift is removed the linkage can slide up the shaft.
Remove the front struts by again cutting the small bracket holding the brake line in, removing the 12mm bolt holding the ABS line, removing the two 19mm bolts holding the strut to the knuckle and finally the 3 12mm nuts for the top-hat. (dont install the wrx stuff yet)
Next I decided to tackle the LCA Mounts. First remove the two 19mm Bolts holding the mount to the frame. You can then pull the lca down to access the 7/8" nut holding the mount to the LCA. Remove that and wiggle the mount off. Then replace it with the one from the Impreza (or wrx) using the factory Forester bolts. Do the same to the other side.
The next step was the removal of the trans cross member spacers. You just have to remove the front cross brace, not the entire support. There is 4 17mm bolts/nuts (2 of each) holding this on. Once it is out I used a cut off wheel and cut the two spot welds holding the spacers on, then using a hammer to knock them off. Once they were off i cleaned it up a bit and threw a coat of truck bedliner spray on it (thats all i had lol). Still wet, I put it back on using the shorter impreza bolts on the outside.
Now for the hardest part. The engine cradle spacer removal. Now when I say hard I mean aligning the holes was a PITA!
Remove the intake piping 12mm bolt and a 10mm bolt and the coolant reservoir 2 10mm bolts and some wire connectors.
Now you can see the cradle bracket bolts. Place a jack under the motor to support it (on the cross member NOT the oil pan). Remove the 2 17mm Nuts on each side than hold the cradle in place. Now the brackets can be pulled up. (there is a stupid Phillips head screw that holds the bracket down). Once the bracket bolts are pulled up lower the motor about an 3/4". The spacers should now be able to move. They are held in with a plastic clip but of you smack the spacer with a hammer the clips should break. Remove the spacers and then insert the new bracket bolts (I ordered these from subaru). Aligning the holes to get the new bolts trough the cradle was a PITA. I used various prying and jacking points (with a 2nd jack) to do it. Good luck haha
Once you have the bracket bolts in place, tighten them up with the factory nuts. Also make sure the steering linkage is in good working order and then re-tighten the bolt.
Next thing is replacing the shifter stop bushing. You could just use the factory shifter and linkage but you have to remove the entire linkage to get the stop bushing off.. This is why I just snagged the whole linkage from the impreza. I now also with have a slightly shorter shifter anyway, which is good.
You can remove the linkage with the shifter still attached without having to take anything else off. Remove the shift knob, take the shifter surround out, and remove the 12mm bolt holding the shifter to the shifting rod. Next go under the car and remove the 13mm nut holding the round part of the linkage to the trans. Then using a ratchet and a 6" extension remove the two 12mm bolts holding the stay bushing to the body. (not much room but it can be done). Then just snake everything down and out. (pull the shifter itself through the rubber surround). Then snake the Impreza linkage, shifter and stay bushing back up in there (all as one unit) and reinstall everything.
After that is done reinstall your front Struts and you are DONE! (get an alignment)
This took me about 8hrs total including, a front brake job (pads and rotors) and drilling a tapping a snapped bolt for the rear sway brackets.. oh and eating some pizza
And you can go from:
This
to THIS:
Ill get some better pix when it stops raining...
naCAnItihS is offline   Reply With Quote
Old 08-28-2012, 08:05 AM   #2 (permalink)
bkbajan's Avatar
Car Model: Forester xt
looks good!
bkbajan is online now   Reply With Quote
Old 08-28-2012, 02:59 PM   #3 (permalink)
Do you need all those parts or can you just get the struts and springs?
dustinkinard is offline   Reply With Quote
Old 08-28-2012, 04:48 PM   #4 (permalink)
4Cyl'erThriller's Avatar
Gallery: 1
Very nice! I like the overall drop.
-----______
____/_ /__\_]
[_O_____O_/= -=#
4Cyl'erThriller is offline   Reply With Quote
Old 08-28-2012, 07:04 PM   #5 (permalink)
forester06x's Avatar
Car Model: FXB
Nice stance!
3 Pedals and Blower Whine (WIP)-The GolfBall
forester06x is online now   Reply With Quote
Old 08-29-2012, 04:47 AM   #6 (permalink)
naCAnItihS's Avatar
I guess you could get away with just the struts and springs but it will handle like crap.. The reason for removing the factory body lift is to obtain proper suspension geometry. Otherwise your control arms and tie rods wont be in the down position like / \. They could be horizontal - - or up like \ / which are bad.
Old 08-29-2012, 05:11 AM   #7 (permalink)
naCAnItihS's Avatar
Doing a photo shoot this weekend with my two cars, my two roommates' wrxs and my buddys BRZ
But these I took yesterday
Before and after
My 01 FOZ and 05 LGT
Old 08-29-2012, 05:42 AM   #8 (permalink)
tallazzPilipino's Avatar
Car Year: 01MY
Car Model: SF6
Gallery: 1
Feedback Score: 15 reviews
are you still on the stock rsb?
(Sent from my Android using Tapatalk)
romidontplaythat! ouiiiii...
- two USDM SF6s
tallazzPilipino is online now   Reply With Quote
Old 08-29-2012, 05:53 AM   #9 (permalink)
ctsquid's Avatar
Nice rides. That legacy looks great.
ctsquid is offline   Reply With Quote
Old 08-29-2012, 10:44 AM   #10 (permalink)
naCAnItihS's Avatar
thanks ctsquid
and yes I am still using the the stock RSB. On the hunt for an STI one for cheap
Old 08-29-2012, 10:51 AM   #11 (permalink)
91Yota's Avatar
Transmission: mt
Dang it! I want those wheels too! I've been trying to find a set for sale haha. Love the way it looks.
facebook.com/MCampbellPhoto
91Yota is online now   Reply With Quote
Old 08-29-2012, 11:34 AM   #12 (permalink)
Car Year: 01MY
Car Model: SF6
Gallery: 1
Originally Posted by naCAnItihS View Post
thanks ctsquid
which control arms are you using again? the ones that use the dog bone end links or the c-shaped links? if c-shaped, you can't use the STi bar. but luckily for you, the 02-03 wrx sedan rsb is the same diameter as the factory STi rsb which i have for sale. lol
PM me if you're interested.
- two USDM SF6s
Old 08-30-2012, 04:12 AM   #13 (permalink)
naCAnItihS's Avatar
Thanks! I had a set for sale that were silver but i sold them to a local guy with a forester on stock wrx wagon suspension.
These came of my LGT, as you can see, that now has BBS VZ wheels on it!
haha well thank you for the offer. If that is the case my friend Andrew (owner of AJW) is going to be parting out a bunch of WRXs for the 818 Factory five project as donor kits. So i can just grab one from him.
Old 08-30-2012, 06:53 AM   #14 (permalink)
Car Year: 01MY
Car Model: SF6
Gallery: 1
haha. there you go. well, looks like you're all set then. don't forget to grease those bushings!
- two USDM SF6s
Old 09-13-2012, 11:04 AM   #15 (permalink)
naCAnItihS's Avatar
More pic whoring :)
