Asphalt Surfers Unlimited
There is a lot of speculation that floats around about Impreza struts and Forester struts and mixing and matching and what works and what doesn't.
I got the hard data from KYB directly, they manufacture the OEM struts themselves in all the variations, and they produce the most common OE replacement and OE fitment sport shocks currently available for the Subaru platform. All measurements are in Millimeters. The Differences: Code:
FRONT
Lower Hole To Spring Seat
Impreza 252
Forester 253
Total Strut Body Length
Impreza 356
Forester 377
Extended Length (Body + Shaft)
Impreza 525
Forester 560 [514]
Compressed Length (Body + Shaft)
Forester 391
REAR
Impreza 315
Forester 330
Impreza 367
Forester 407
Impreza 605
Forester 643 [632]
Forester 455
The second figure on the Forester extended length measurements is due to the internal droop limiting spring that is in the Forester struts. The figure in brackets is the free extension before the spring becomes involved. The total extension is the length when the limiting spring is fully compressed (shaft fully extended under load). I have not touched on the differences in spring length or preload, those are equally important figures... but this chart should illustrate why there are different spring designs between the Impreza and Forester. Enjoy, Porter
-Porter- '04 F-XT Silver I love the smell of brake pads in the morning. Smells like... victory. |
Advertisement |
Developer
Did you by chance get the difference in total stroke w/o the spring (fully compressed to fully extended)? That would be tremendously helpful. I am working on trying to make some sort of adapter to fit the AGX shocks/struts onto Foresters.
Got Boost? |
I believe both struts retract almost fully into the housing, with about an inch of shaft exposed. The "fully extended" measurement is to the top of the chrome shaft surface, not including the threaded area.
Subtracting the strut body length from the total extended measurement should give you a rough idea of the length of total travel. I will call KYB back tomorrow and get a real answer on the total stroke. BTW... I don't think it's going to be easy to "adapt" AGXs to the Forester and keep Forester geometry... the spring perch height and total travel are quite different. My personal solution would be to use a set of Koni inserts sized for the Forester, or a Forester-specific coilover.
#6 (permalink) |
The Modfather
Just a little pic to add since I happen to have one, notice the top of the Foresters strut, it appears the top can be screwed off but I have not tired myself. I'm not sure if it's threaded or not.
#7 (permalink) |
Peaty,
It's not threaded. That is a standard KYB/Showa strut top cap. It is press-fit into place and holds the inner strut cartridge assembly in place. There is a seal system underneath the cap.
#8 (permalink) |
The Modfather
Is there a way to remove the cap, change the insert and put a new cap on?
#9 (permalink) | |
It is however quite ideal for Koni-insert use... though the housing will need to be trimmed down somewhat (slightly) depending on the exact length of the Koni insert. Hmm... lots of Koni interest here. I'll be on the phone with Koni tomorrow.
#10 (permalink) |
EDIT
Added compressed length to the figures. Note that this is total body and strut shaft to the end of the chrome rod area, not including the threaded end.
#12 (permalink) |
I have not gotten a chance to speak with the folks at Koni, work has been crazy. I know the right individual there though, we worked together somewhat on the SVX fitment inserts a few years ago.
#15 (permalink) |
..........Don't know if this will help,but you can try contacting Dave or Barrett at www.allwheelsdriven.com, he might be able to help you out or at least answer your questions.They have been been fabbing up Subaru strut bodies to take Bilstein HD strut inserts(same as Koni I believe) for Impreza rally cars,they have the screw top which you need anyway,H&R springs,Group N top hats
| Thread Tools | |
