Hello to all
I have a Subaru Forester 2004 XT
I just put in some new CV joints in the front and i am now getting some weird knocking sound when i accelerate,
Is not happening on right hand side so they are the correct CV joints.
Pedders suspension believe its the wheel hub but they will need to take it apart to look into, but i have taken that apart and see nothing out of the ordinary.
Pedders suspension said that they could not see anything wrong with the suspension or CV joints. They have the right amount of play
So far from my troubleshooting i have worked out
Has anyone got any ideas.
I wish to do as much troubleshooting as possible before i pay pedders.
Thanks you
- Only when Accelerating
- Only going forward not backwards
- From left hand side
- Does not happen when in park or neutral and i rev engine
- Knocking sound speeds up when car speeds up
- Doesn't happen when im just coasting at any speed
- seems worse when car is Cold, Goes away after a while
- turning corner doesn't make a difference in sound
- taken wheel hub apart and cannot see anything strange or worn away
- Braking does not change the sound
Thanks you
