Old 06-16-2008, 01:52 AM   #31 (permalink)
iMod
BAC5.2's Avatar
BAC5.2 will become famous soon enough
Plainsman is correct.
To do this upgrade you need the following:
-The RB kit (brackets)
-Rotors (Be it RB or whatever your choice in 290x18mm. If you are getting the 316 kit, only the RB rotors work)
-1991-1994 Legacy Turbo calipers (I'll get you part numbers later)
This, of course, will work for the SF as well as the SG. I did the calculations based on FXT/WRX front brakes. It would be awful to use them with stock SF front brakes.
These brackets JUST got released, though I've had my kits for quite some time.
The Aggressive™ -- You don't know about it.
1998 Forester S - Big brakes, Big Tires, 5-gears.
Old 06-16-2008, 11:50 PM   #32 (permalink)
Vendor
Mann Engineering's Avatar
Mann Engineering is an unknown quantity at this point
Big rear brakes? I got BIG rear brakes for you.
AP Racing 330mmx25mm rotor with a 4-piston caliper. 2008 Impreza WRX Hatch.
http://www.mann-engineering.com/imag...ap_caliper.jpg
Enjoy :)
Gary
Mann Engineering
Mann Engineering is offline   Reply With Quote
Old 06-17-2008, 04:20 AM   #33 (permalink)
BLUE WASABI
(#2 Info Provider)
sirwilliam's Avatar
Enjoy :)
Gary
I will give you $600 for the set!
BLUE WASABI
sirwilliam is online now   Reply With Quote
Old 06-17-2008, 01:43 PM   #34 (permalink)
Supporting Vendor
Integrity Performance's Avatar
Integrity Performance is on a distinguished road
you actually dont even need the RB brackets. Just get the legacy rear brackets, rotors, and pads for that year legacy.
Integrity Performance is offline   Reply With Quote
Old 06-18-2008, 04:43 AM   #35 (permalink)
iMod
BAC5.2's Avatar
I'm not sure I follow what your talking about. If you want 266x18mm rear rotors, that's true you can just get the rotors, calipers, brackets, and pads for an early legacy. This is to upgrade to 290x18 and 316x18mm rear rotors. For those upgrades, you'd need the RB brackets. To do the 290x18 upgrade, you'd need either LGT take-off's or the RB kit.
And, of course, your stock caliper won't work. It was designed around a 266x10mm rotor. Even swapping to vented, the stock caliper won't do the trick.
Old 06-20-2008, 01:43 AM   #36 (permalink)
Supporting Vendor
I was talking about the "H6" rb kit.
Old 06-20-2008, 04:36 AM   #37 (permalink)
iMod
BAC5.2's Avatar
Oh. Yea, for the 290x10 upgrade you can use OEM parts. Last I checked, going with OEM stuff cost almost as much as the RB kit and you were stuck with stock rotors?
I'd rather have vented rear brakes. Guess I'm partial :)
Old 06-27-2008, 09:04 AM   #38 (permalink)
Gallery: 8
So if I want to match my front Brembos with the 316x18mm kit, I'll need this kit and 91-94 turbo Legacy calipers? Or 05-08 LGT calipers?
-Silke
04 FXT PP PSM ~ "Subed"
98 Forester S ~ "Slynki"
92 SVX LS-L ~ x2
Old 06-27-2008, 01:01 PM   #39 (permalink)
Groovologist
guroove's Avatar
guroove is on a distinguished road
I can't seem to find any links to the 316mm front brake upgrade kits. And the rear ventilated kits require different calipers, correct?
guroove is online now   Reply With Quote
Old 06-27-2008, 02:07 PM   #40 (permalink)
El Sid's Avatar
Gallery: 1
El Sid is on a distinguished road
I think the 316mm is a rear brake upsize for the Legacy. It would require the use of the Legacy caliper and the bracket designed to adapt it to the larger rotor.
If this is to upgrade the Forester - I don't think it has made it to the website as a kit yet and may not ever as it requires the use of parts not supplied and not factory installed on that vehicle.
Here is the link to RB's upgrade for the rear 316mm upgrade. Performance Brake Parts, Rotors, Calipers, Discs & more! - RacingBrake.com
El Sid is online now   Reply With Quote
Old 07-03-2008, 04:11 PM   #41 (permalink)
Gallery: 8
Well crap... I'm out - for now. I was planning on ordering this kit to upgrade from my current rear H6 Legacy setup in the coming weeks and was hoping to take it easy on my car/brakes until then, but I had LIC check them out last night because we're going on a trip this weekend.
Fronts - nothing left on the pads... zip, zilch, metal to metal. Pistons fully extended. Rears - 2% on the outside, nothing on the inside. Needless to say, I left my car there for a brake job (fluid flush, new pads & rotors all around) and will have to wait with this upgrade until such time as I can justify the expense.
At least I won't have to listen to that annoying wear indicator screech anymore... :unamused:
-Silke
92 SVX LS-L ~ x2
Old 08-23-2008, 07:30 AM   #42 (permalink)
Adios STI's Avatar
Adios STI is on a distinguished road
why didn't you get the rotors turned and use the savings to get the upgrade later?
<<<< My navigator.
2007 FXT Ltd. M/T, Urban Gray
Adios STI is offline   Reply With Quote
Old 08-24-2008, 07:07 AM   #43 (permalink)
Adios STI's Avatar
Default So it seems the consensus is 4-2 WRX '06/07 are not worth it
My investigation after reading countless posts leads to conclude this is a mediocre upgrade:
1. Less clamping force on front
2. More rear bias
3. Heavier unsprung mass and gyroscopic effect due to larger, thicker rotors.
Do the larger rear and vented rotors justify the expense, rear bias, and higher unsprung mass?
I found '07 WRX front/rear calipers/rotors/ (pads 50% life) for $700. Well, actually $900 including the KB rotor rear adapters.
I am looking for performance over looks (although I love those red WRX calipers)
<<<< My navigator.
Old 08-24-2008, 09:38 AM   #44 (permalink)
Gallery: 8
The rotors were at the end of their intended lifespan... there was nothing left on there to be turned!
-Silke
92 SVX LS-L ~ x2
Old 08-24-2008, 09:44 AM   #45 (permalink)
2. More rear bias
Does the larger rear and vented rotors justify the expense, rear bias, and higher unsprung mass?
You did your homework! Credit for not just going for the "racer look" like most. LOL.
Most upgrades beyond better pads are for increased thermal capacity and to a lesser degree pedal feel. If you aren't experiencing fade at the track then all BBKs are bling plain and simple.
'08 XT LTD/MT
