Car Model: xt
Transmission: magic wand
58
Just seeing how everyone does there brakes? ive got my brembos to go on this weekend weather permitting. ive got some goodridge hoses too but im scared about knackering the top union up! has anyone tried these force bleeders or vac bleeders? and can someone recommend one!
thanks in advance Simon
New and Improved 341bhp/355lb ![]() 富士重工業株式会社
Car Model: S Turbo
My sealy vacuum bleeder works really well, but it does need an air compressor.
MY00 Forester S Turbo My03 Impreza GX |
Car Model: Was XT now WRX STi
Transmission: Man stick
I got a 10 quid bleeder kit from Halfords. Its easy peesy. Just pop it on, crack the nipple and press the peddle to new juice comes through. The one way valve (ball bearing in a rubber pipe) does the hard part. You then check levels etc and move to next nipple in te right sequence.
My XT brakes felt way better after the bleed. |
#4 (permalink) | |
Car Model: Impreza WRX
...this is the one: Halfords | Europat Vizibleed Bleed Aid
Was MY03 FXT (262bhp) MY03 WRX (271bhp) Now MY05 MCS, Z3 2.8, X3 3.0d, Vespa ET4 & BMW F700GS |
Car Year: MY11
Car Model: WRX STi Sedan
Transmission: 6MT
Have been fitting speedbleeders to most of my recent cars.
Went with stainless for the WRX STi Total one man job. About Speed Bleeder Products, Inc
Was a MY03 FXT 5MT (280bhp/290Lbsft) Now a MY11 WRX STi 4door (342bhp/360Lbsft) |
#6 (permalink) |
Car Model: EDM FXT 4EAT ST3
What model / size of Speedbleeders did you get for the Brembos?
Cheers, Patrick
07 FXT 400+ ? |
#7 (permalink) |
Car Model: xt
58
brembos are m10x1
#9 (permalink) | |
Car Year: MY11
Transmission: 6MT
Short version SB1010S-SS Speed Bleeder Longer version SB1010-SS Speed Bleeder Prices are each for stainless. This is the longer version in the rear Alcons (same thread size as Brembos) ![]() I used the shorter ones in the fronts.
#10 (permalink) |
Thank you! I think I just may make an order. ;)
edit: whoopsie expensive! $15 each, 2 longer ones for each rear caliper and 2 shorter ones for each front: $120! ![]() Then 2 bleeder bags, $6, then shipping and then vat on top of that... Half price to go with the non-stainless... Difficult choices in life. ;)
07 FXT 400+ ? Last edited by Patrick P931; 02-15-2013 at 12:49 AM. |
#11 (permalink) |
Car Year: MY11
Transmission: 6MT
The only reason for the different lengths used is that I purchased the bleed nipples for the front brakes thinking that the shorts would be OK.
They are, but leave very little clearance between hex and brake casting. When I fitted the new rear brakes decided on the longer ones which are maybe a bit too long ?? Before buying, maybe worth removing an existing bleed nipple and measuring.
#12 (permalink) |
I would also recommend the cheap halfords one-way valve kits, worked a treat, very clean, took me about 5mins to bleed the front end on my own.
I've used one of the kits with a pressurised bottle on my old Clio (pressurised by connecting it to your tyre valve). It was neat but no where near as clean or fast, quite a bit more expensive I think as well. I also ended up having one of the pistons pop out as I forgot to remove the pressure before removing the caliper (D'OH). |
#13 (permalink) | |
#14 (permalink) |
I'd avoid the pressure kits that use the spare tyre as they can be messy. The one way valve (or speed bleeders) are the way to go.
Also, top tip is always gently release the brake pedal as you can get splash back from the reservoir which will go everywhere. |
#15 (permalink) | |
Now an Outback.
Car Year: 00
Car Model: Outback
160bhp 4EAT Outback.....
