Old 09-12-2008, 03:26 PM   #1 (permalink)
mdg
mdg's Avatar
mdg is on a distinguished road
Default Steering wobble when braking
It feels like one of the front discs is warped, but i changed them about 4 monthe ago. Going to have a look myself on sat/sun. Any ideas?
Red on black, black wheels and fat tyres.
mdg is offline   Reply With Quote
Old 09-12-2008, 06:32 PM   #2 (permalink)
piemaster's Avatar
piemaster has disabled reputation
wheel bearing?
03 XS AT
piemaster is online now   Reply With Quote
Old 09-12-2008, 06:42 PM   #3 (permalink)
Admin
SuperRu's Avatar
SuperRu will become famous soon enough
Did the wobble go away with the new rotors then come back?
Richard
04 XT.... 98S
SuperRu is online now   Reply With Quote
Old 09-12-2008, 06:49 PM   #4 (permalink)
getsomz28 is on a distinguished road
sounds like warped rotors to me. Are they stock replacement rotors or other brand?
'05 FXT - for haulin'
'02 Z28 - for haulin' arse
getsomz28 is offline   Reply With Quote
Old 09-12-2008, 07:57 PM   #5 (permalink)
JM1
JM1's Avatar
JM1 is an unknown quantity at this point
Any pulse through the brake pedal? I recently had some major shaking and decided to replace the front rotors - no fix. The rears were the cause and shaking the wheel and pedal.
MY05 FXT MT Crystal Gray, Stage 1, ghetto wheels
JM1 is offline   Reply With Quote
Old 09-12-2008, 08:28 PM   #6 (permalink)
Rebed your pads. Or get new rotors that aren't "warped".
'08 XT LTD/MT
Old 09-12-2008, 08:33 PM   #7 (permalink)
problemcat13's Avatar
problemcat13 is on a distinguished road
Cliff notes: similar problem, turned out to be my stock steel wheels that caused it.
Well....I had a similar problem on my 99 L. Replaced pads and rotors, shaking came back in about 3 weeks. Turned them again, new pads, came back again.
After putting up with it for nearly a year, I went all out: new pads, new rotors, new calipers (front), new shoes in the rear, had the entire system bled. This fixed the problem, OR SO I THOUGHT! (I also happened to change to a new set of alloys prior to the brake work).
After about 1.5 years rolling on my new brakes and new wheels with no problems, I put my good ole' 15" steel wheels back on one winter and guess what? Within a month the shake was back!
I'm guessing the wheels must have been warped or something. They were definitely the problem, and caused a problem with the rotors/brakes. Even after switching back to the newer wheels I still had the shake until I got the rotors turned.
Don't know how you would go about checking this unless you already have a second set of wheels. Any good wheel shops around that can check them? Also, I'm not saying this is definitively the issue you're having, but sounds a lot like mine!
Good luck!
99 L 5MT (sorely missed)
04 JBP XT 5MT
problemcat13 is offline   Reply With Quote
Old 09-12-2008, 08:34 PM   #8 (permalink)
Graham's Avatar
Graham is on a distinguished road
Other possibilities are uneven tyre wear, unbalanced wheels, worn shocks, worn steering joints, bad alignment, bent wheel(s) and/or incorrect tyre pressures. These are all likely to produce other symptoms, but might pass unnoticed.
Graham is offline   Reply With Quote
Old 09-12-2008, 09:45 PM   #9 (permalink)
Gallery: 8
Pad deposits!
-Silke
04 FXT PP PSM ~ "Subed"
98 Forester S ~ "Slynki"
92 SVX LS-L ~ x2
Old 09-13-2008, 12:05 PM   #10 (permalink)
mdg
mdg's Avatar
Steering wobble came on about 3 weeks ago. Happens when brakes are hot or cold, tyre pressures are correct, wheels are ballanced, i dont know about any worn bushes though
This is what i've done:-
New after market discs and pads, 6 months ago.
New tyres on stock 15" steels, 8 months ago(tyres still like new)
Changed steering fluid, 8 months ago.
New off side rear wheel bearing, 1 month ago.
(Bloke at garage said he had to remove back plate and some sus linkages in order to remove wheel bearing. Could this have done something?)
Old 09-13-2008, 01:16 PM   #11 (permalink)
Gopher XT is on a distinguished road
I had the same problem on my wifes outback. I put on some aftermarket rotors from the autozone (us parts distributor) and they warped in about a month. I took them back under warranty and those warped in about the same time frame. Then I said enough and I shelled out for some Brembo crossdrilled rotors from summit racing and problem has been solved. It sounds like the rotors may have warped again, but it could be the problems that the others have listed.
Gopher XT is offline   Reply With Quote
Old 09-13-2008, 02:36 PM   #12 (permalink)
Barring any mechanical problems like lost wheel weights or bad bearings, I'd rebed the pads before I started dumping more money on the problem. It's free...
'08 XT LTD/MT
Old 09-13-2008, 02:41 PM   #13 (permalink)
Admin
SuperRu's Avatar
X2, that is good advice.
Richard
04 XT.... 98S
Old 09-13-2008, 03:41 PM   #14 (permalink)
dpm
dpm is on a distinguished road
Unless you checked the new discs for runout with a dial-gauge on fitting, I'll go with distorted discs, please.
dpm is online now   Reply With Quote
Old 09-13-2008, 03:42 PM   #15 (permalink)
rofester is on a distinguished road
Usually when Im driving highway speed and I have to brake, it feels like the front of the car wobbles a little, not really left to right, but more back and forth. Is this the same problem?
rofester is offline   Reply With Quote
