Leaking Speed Bleeder - Subaru Forester Owners Forum
Old 06-18-2007, 11:20 AM   #1 (permalink)
CraigB's Avatar
Car Model: FXT MT Cobb Stage 2
Default Leaking Speed Bleeder
I just installed my Speed Bleeders and flushed the fluid out. The left front bleeder is leaking slightly. I bled the brakes a couple of years ago, using the OEM screws and had no problems/leaks. I haven't pulled the wheel off again to check it, so I'm not sure if it's seeping up through the threads or leaking at the nipple itself. I can only assume that the seat is messed up somehow, causing it to not seal completely.
Has anyone had this problem before? Is there anything I can do/check, other than replace the bleeder screw?
CraigB
04 FXT
CraigB is offline   Reply With Quote
Old 06-18-2007, 11:34 AM   #2 (permalink)
ferret's Avatar
Car Model: Forester XS PP 5sp
I did on my previous Forester. So when I put them on my current one, I checked them daily for a few weeks. The leaky one will have to be replaced, either under warranty or buying another set.
Your 04 requires the longer speed bleeder for the fronts. There are shorter 1010's out there. But they will try to seal at the top on the caliper and bottom of the hex head. The shorter ones will surely leak.
Once torqued down, there should be no flow thru the center, as that is sealed by the pintle ( conical shaped tip )on the bottom of the bleeder ( speed bleeder ) screw
04XSPP, 98S (8 Subaru's since 1978, 7 were 5 sp) ILuvSubaru's
ferret is online now   Reply With Quote
Old 06-18-2007, 11:51 AM   #3 (permalink)
CraigB's Avatar
Thanks for the info. I definitely have the long ones. The nut portion did not bottom out against the caliper.
CraigB
04 FXT
Old 06-18-2007, 02:06 PM   #4 (permalink)
Registered User
paulxt66's Avatar
Car Model: Forester XT 5MT
One of mine leaked when I installed them. I suspected some dirt or rust got in there and was keeping the bleeder from seating properly, so I removed it and flushed the area out with brake cleaner. This seemed to work as it stopped leaking.
-Paul
04 F-XT 5MT
paulxt66 is offline   Reply With Quote
Old 06-18-2007, 02:53 PM   #5 (permalink)
Registered User
Car Model: XS MT
People have has speed bleeders leak before. No idea if this had anything to do with them being speed bleeders, or if it could have happened with any bleeder screw.
gman is offline   Reply With Quote
Old 06-19-2007, 03:55 PM   #6 (permalink)
CraigB's Avatar
That's certainly a possibility or I just may not have tightened it enough, when I was bleeding the other corners. That corner dumped some fluid when I was swapping the bleeders and it ran down the caliper. When I got back from the test drive, I noticed some drips inside the wheel, so that's why I thought it was still leaking. I pulled the wheel and cleaned it up. I had the wife pump the pedal hard and saw no leak. I guess there was just some fluid left on the outside of the caliper that dripped down. Still looks dry today after a drive, so I guess I'm ok.
Thanks everybody!
CraigB
04 FXT
