('01-'02) A question about coolant mixing... - Subaru Forester Owners Forum
post #1 of 9 (permalink) Old 05-19-2017, 03:35 PM Thread Starter
Car Model: Forester S full load
Hello everyone,
I've recently noticed that the coolant level in the reservoir is below the "Low" mark, so I went to the local store (Canadian Tire) and bought the OEM vehicle specific Coolant (it says on the bottle "Recommended for Acura, Subaru, Honda).
And this is what I've done, the coolant originally in the radiator and reservoir is green in color, the one I used for topping up is blue (used about 0.5 L).
My question is, should I be draining everything out ASAP and filling it up with either the green or the blue only? (because it says in the owner's manual "Never mix different kinds of coolants", I know I'm an idiot and should've read that before doing anything..)
Thanks a bunch in advance for any info/suggestions.
IawM is offline
post #2 of 9 (permalink) Old 05-19-2017, 03:56 PM
Your coolant shouldn't be low unless it's not doing it's job and needs to be changed. Thermal breakdown occurs which makes it less effective at heating up and cooling your engine.
How do you know it was low? By the radiator? Was the reservoir full?
Sent from my SAMSUNG-SM-G891A using Tapatalk
03 Forester XS
Sgtdic is offline
post #3 of 9 (permalink) Old 05-19-2017, 03:58 PM
Transmission: 4 speed auto
Universal type
Usually the coolant in Subarus is Blue. The green coolant found in your car could be a universal type. That is, no silicates, no phosphates, no nitrates. So adding the correct blue coolant would not do any harm.
Easy Fixer is offline
post #4 of 9 (permalink) Old 05-19-2017, 04:01 PM
Feedback Score: 53 reviews
The one thing to be careful about is that the blue coolant (at least the OEM stuff from Subaru) is already pre-mixed 50/50. Green coolant is usually not - you'll have to add distilled water.
~ Silke ~
'04 FXT 4EAT PSM - "Subed Up"
'98 S 4EAT DBP - "Slynki"
pleiad7 is offline
post #5 of 9 (permalink) Old 05-19-2017, 04:02 PM
Hi,
I would 2nd the comment that you do need to determine why it's low on coolant. Hopefully you're aware of the Head Gasket issues w/most Subarus of your vintage.
GL,
TD
'98 S
'04 FXT
'93 SS
'02 GG
'96 GD
wtdash is offline
post #6 of 9 (permalink) Old 05-19-2017, 05:55 PM Thread Starter
Sorry for the confusion, by "reservoir", I was actually referring to the expansion container, the white plastic one with two lines marked "Low" and "Full" on it, the coolant level was just a tad below the Low mark. I just checked the coolant level today, and it dropped by about half an inch from the Full mark which was where I topped it up to with the blue stuff, that's from driving the car about 300 km.
Considering the cross sectional area of the container around the Full mark level, it is not really that much but I'd still like to figure out why.., I've heard of the head gasket problem with older Subaru, I'll check underneath the vehicle tomorrow..
IawM is offline
post #7 of 9 (permalink) Old 05-20-2017, 05:59 AM
If it is disappearing, then it's one of three things. You have a leak, the coolant is now in your oil, or it needs to be flushed and changed.
03 Forester XS
Sgtdic is offline
post #8 of 9 (permalink) Old 05-20-2017, 06:45 AM
vintage42's Avatar
Car Model: LL Bean (4EAT)
My Forester is a 2008 made in July 2007. It came with Subaru's green "Long Life Coolant" good for 30 months/30,000 miles. It must be mixed 50/50.
In late 2008/ early 2009 Subaru switched over to blue "Long Life Super Coolant" good for 11 years/137,500 miles on the factory fill, and 6 years/75,000 miles on the second fill. It is premixed.
Subaru then put out an email saying: "Going forward we are recommending that when adding, replacing, or servicing the cooling system, the blue Genuine Subaru Long Life Coolant should always be used."
That sounds like the green and blue can be combined, and that is what happened at my 30K service. The dealer drained the radiator which removed about half the green coolant in the system, and added blue.
I recently had the head gaskets preemptively replaced by an independent while they were doing the timing belt, and they filled the system with green coolant, because it was "original".
Based on Subaru's email, I don't think the color of the Subaru coolant matters when adding or changing, but the coolant should be Subaru.
2008 LL Bean
vintage42 is offline
post #9 of 9 (permalink) Old 05-20-2017, 06:54 AM
Fate's Avatar
Car Model: SBM FXT-T ES
Transmission: TR690GBYCA
Here is something that is VERY important to be aware of, and perform if applicable:
https://www.carmd.com/Tsb/Download/33838/238283
That said, periodic topping off of coolant in Subaru overflow reservoirs is normal as it is not a closed system and coolant/water slowly escapes into the atmosphere.
Good read here:
http://www.subaruoutback.org/forums/...-too-long.html
Fate is offline
