so ive been having some idle troubles,
o2 was bad so replaced it and fixed exhaust leak still however sometimes when i go to start it it starts then stalls straight away, or idles really low or idles at 2000rpm -.- spark plugs are due have replaced the passenger side as they were easy to get to today. I have 2 amps one powering hte sub the other the front speakers i also noted that my main ground line from the engine is a aqua colour will be upgrading this soon but in the mean time i added another ground from the battery to the body i have hids but the idle issue still occurs when there not on. when i turn the a/c off the revs raise about 150rpm and when i turn my stereo off the idle increases very minimally the other things im thinking might be the issue PCV valve? spark plug leads? the drivers side spark plugs? i should note that theres no CEL on and i have checked it with the obd reader. after changing the 2 plugs today it seems a bit calmer idles around 500rpm except after moving if i put it into neutral or i put the clutch in before i take off again the revs rise to 1500 then drop slowly does this sound like a neutral switch? |
Car Year: '03
Car Model: Fozzy
Transmission: Eat A Taco
finish the plugs and wires first...
When did the problem start, after you did something or just out of the blue... |
#6 (permalink) |
Car Model: Forester XS
This was my tune up i performed on a rough running forester xs with a rough idle, it now runs like a dream!
Anyways this is what i did and it cost me in the region of $400 for all parts and fluids etc, i got nearly everything on ebay as part prices in Canada suck, elbow grease is free though... Also I know its contrary to a lot of members beliefs but i have been starting to use premium fuel and the car no longer pings/knocks at low revs. the owners manual said at least octane 87 and Ive been using 91. For the difference of 5 cents per liter i am happy and the performance IS noticeable. You also want to check all of your Vacuum lines, any leaks will cause a bad idle. I had a bad throttle body gasket that happened to be causing mine, but check all the lines too. If you spray carb cleaner at the vaccum lines and gaskets you can tell you have a leak if the engine note changes as its inhaling the carb cleaner from somewhere. Its not an exact science but it works. Also if you mist water at your ignition coil when the engine is running and the revs change, you know your ignition coil is buggered. Last edited by Jarvace; 11-25-2012 at 04:53 PM. |
