How to replace upstream O2 sensor - Subaru Forester Owners Forum
post #1 of 25 (permalink) Old 01-03-2010, 05:14 PM Thread Starter
Car Model: L
I need to replace upstream O2 sensor on my Subaru Forester L 1999. Do I need to remove the shield under the catalitic converter or it's possible to unscrew the sersor with some kind of "socket" wrench ? All the bolts which hold the shield are very rusty and I'm not sure if it's possible to unscrew them. So far I have managed to unscrew 1 and destroy 1 bolt.
tlknv is offline
post #2 of 25 (permalink) Old 01-03-2010, 06:30 PM
The Modfather
Peaty's Avatar
Transmission: 6 Speed Manual
Feedback Score: 10 reviews
First off welcome to the forum, if you look here:
http://www.scoobymods.com/oxygen_sen...64.html?t=5464
I have info with pics, there is a pic of the 99 system and it will show you where it is. It's a shot of my 99 Impreza RS but it will be similar. You should not need to remove the heat shield to do the front (or rear for that matter) but having the proper tool helps. Most automotive stores will lend them out when you leave a deposit.
Peaty
Peaty is offline
post #3 of 25 (permalink) Old 01-03-2010, 07:25 PM Thread Starter
Car Model: L
Peaty,
Thanks a lot for the comprehensive answer !
tlknv is offline
post #4 of 25 (permalink) Old 01-03-2010, 08:07 PM
The Modfather
Peaty's Avatar
Happy to help :) Just a quick word about a replacement sensor. You can get a universal one (where you need to cut off the old harness plug from the sensor and attach to the new one) or one that will plug directly into the OEM harness w/o any splicing. Universal ones will work but I've read of spotty results and sometimes people have issues. I think it may be due to the splicing, the wire is stainless steel and they use a special plug contraption to do the splicing. If you haven't gotten one yet I'd encourage you to get one that you won't need to splice. Either an OEM one from Subaru or other place. Just to avoid any problems. They are more expensive though but IMHO worth it. If you look in the vendor section on this site you will find some vendors that supply OEM parts at a discount. Just a heads up. Good luck!
Peaty
Peaty is offline
post #5 of 25 (permalink) Old 01-04-2010, 06:42 PM Thread Starter
Car Model: L
Peaty,
Thanks for the info.
Fortunately I have bought the "exact fit".
tlknv is offline
post #6 of 25 (permalink) Old 01-04-2010, 06:54 PM
The Modfather
Peaty's Avatar
good deal let us know how things turn out.
(where in NJ are you? I'm from there originally - Born in Jersey City but lived over the state at one time or another)
Peaty
Peaty is offline
post #7 of 25 (permalink) Old 01-06-2010, 05:37 PM Thread Starter
Car Model: L
Peaty,
Crows foot style tool worked perfectly.
I borrowed it in the nearest "Advance Auto Parts" and replaced the sensor in about 20 minutes. I didn't try to experiment with a simplier "slotted socket" tool because it's not allowed to repair the car at my appartment complex and I wanted to finish everything quickly.
P.S. I've been living in East Windsor (NJ) for 8 years since I came to US.
tlknv is offline
post #8 of 25 (permalink) Old 01-06-2010, 06:11 PM
frogstar7055's Avatar
Car Model: Xterra SE 4x4
Transmission: Slushbox
Originally Posted by tlknv View Post
Peaty,
Welcome aboard and where you from originally?
(this forums great ain't it,so much info)
Frogstar7055
01 Foz GONE
04 Xterra Ivan
02 Foz
frogstar7055 is offline
post #9 of 25 (permalink) Old 01-06-2010, 08:46 PM
The Modfather
Peaty's Avatar
Glad you got it sorted out. I have both types of O2 removal tools. Depending on where and how the sensor is situated, one usually works better than the other.
I actually lived in East Windsor for a few years myself. I worked in Cranberry at General Foods back in the Early 80's then moved over to Heights Town for a little while.
Peaty
Peaty is offline
post #10 of 25 (permalink) Old 01-07-2010, 06:39 PM Thread Starter
Car Model: L
Originaly I'm from Russia.
I have more questions but I guess that I should open a new thread(s).
tlknv is offline
post #11 of 25 (permalink) Old 01-07-2010, 06:48 PM
The Modfather
Peaty's Avatar
Do a search and if you come up empty just start a new one in the appropriate forum. I'm sure someone will help out :)
Peaty
Peaty is offline
post #12 of 25 (permalink) Old 01-08-2010, 01:36 PM
huck_this's Avatar
Car Model: SOLD!
Gotta do mine tomorrow!!! BOSCH one crapped out!!! NGK one is going in. I use a 22mm wrench for this and it works great!!!
huck_this is offline
post #13 of 25 (permalink) Old 09-10-2010, 01:57 PM
Question Can't get it out - no leverage!
I also need to change the front Air Flow sensor on our 2003 Forester with the 2.5 NA. So I looked at the pics and great explanation by Peaty, and also got the crow's foot socket. But when I crawled under there and got the socket on the sensor, there was literally no room for the breaker bar to move to loosen it. One of the heat shield's "ears" that stick out for the bolt to go through is directly in the path of the socket movement (I will try to take some pics and post them). I tried every way I could fit my hands up in there, even tried the flair wrench that was suggested, but I cannot get it on the sensor at any angle that allows any movement.
I am at a loss for what to do next. Any suggestions will be greatly appreciated.
2003 Forester X 2.5 NA, 5-spd MT
Metro ATL, GA
ppalimia is offline
post #14 of 25 (permalink) Old 09-10-2010, 02:07 PM
Car Model: Mitsubishi Pajero
Transmission: 5spd Automatic
Stupid question. What sensor sits on top of the heat shield pointing against the IC?
07 Mitsubishi Pajero 3.2 5EAT
99 Forester: Sold
Elmy is offline
post #15 of 25 (permalink) Old 09-10-2010, 02:39 PM Thread Starter
Car Model: L
I'm not sure if your car has the same design around upstream O2 sensor. Try to put "crows foot" on the sensor at different angles/rotations and rotate and move the breaker bar differently. The space is very limited, but there should be some combination of those positions/rotations that allow some limited movement to unscrew the sensor a little bit. After that you might be needed to repeat everything again.
tlknv is offline
