('03-'05) Grounding Kit installed - Subaru Forester Owners Forum
Go Back   Subaru Forester Owners Forum > Technical Forums and Vehicle Assistance > Engine and Exhaust > EJ25 - 2.5L Non-Turbo (1998-2010)
Old 11-25-2012, 05:30 PM   #1 (permalink)
Car Model: Forester XS
Default Grounding Kit installed
I installed a grounding kit to my Forester and couldn't find much information on previous installs to a 2003 - 2005 XS so here are some pics and instructions.
It has made my car idle better, smoother acceleration, electrical stuff doesn't dim any more when you use the car windows etc. It has also made my sound system sound better, in a nut shell i thoroughly recommend doing this as the OEM grounding kit is pretty piss poor.
I believe the improvement to the engine running smoother is down to properly and directly grounding the throttle body and giving all the sensors ie MAP, IACV etc a really good connection rather than just going through the bolts to the manifold.
So here is the route i took:
Battery Negative -> Drivers side Intake Manifold
Drivers side Intake Manifold -> Alternator
Alternator -> Throttle body bolt
Throttle Body bolt -> Passenger side Intake Manifold
Passenger side Intake Manifold -> Chassis or strut nut.
All of the new ground wires were installed with dielectric grease and i made sure all the bolts connections etc was clean and shiny using a dremmel.
I had the wires custom made for me, i'm not very good at soldering so i left it to a professional.
Here's some pics:
Battery Connection:
Alternator Connection:
Throttle Body Connection:
Throttle Body Connection, close up:
Passenger side Intake Mannifold Connection:
Chassis Connection:
Jarvace is offline   Reply With Quote
Old 11-25-2012, 06:06 PM   #2 (permalink)
Nthads's Avatar
Nice write up! Was poking around the forum the other day looking for grounding solutions.
Nthads is offline   Reply With Quote
Old 11-26-2012, 02:16 AM   #3 (permalink)
link1896's Avatar
Transmission: auto
It's quite amazing the difference it makes. I noticed improved idle and better automatic shifting performance mainly.
link1896 is offline   Reply With Quote
Old 11-27-2012, 06:44 AM   #4 (permalink)
Car Year: '03
Car Model: Fozzy
Transmission: Eat A Taco
I need to do this...
Old 11-27-2012, 07:25 AM   #5 (permalink)
Car Model: 2.5xs
Transmission: dont know how to drive auto
What was your total cost?
EffenBee is offline   Reply With Quote
Old 11-27-2012, 12:09 PM   #6 (permalink)
Car Model: Forester L
Transmission: 5 speed
I also did this to my 2000 L. There was a very noticeable difference. It idled and ran much, much smoother. I made my own wiring setup from 10 or 12 gauge wire, connector eyes and hear shrink, and soldered it all together. Had less than 20 bux in it.
Mizac is offline   Reply With Quote
Old 11-27-2012, 12:44 PM   #7 (permalink)
Gallery: 66
Feedback Score: 46 reviews
That looks like a nice kit, but one thing I would recommend is to reduce the slack in the wires as much as possible. The shorter the individual pieces, the better.
-Silke
04 FXT PP PSM ~ "Subed"
98 Forester S ~ "Slynki"
Old 11-27-2012, 12:56 PM   #8 (permalink)
Nthads's Avatar
does anyone know where to get the high temp woven ribbon cable? iv seen several cars stock using this type of grounding and im thinking it might be a cleaner and less apt to fail from heat and will provide a pretty solid grounding path...yet probably susceptible to corrosion?..... but anyways....any thoughts?
Old 11-27-2012, 01:04 PM   #9 (permalink)
Chilidawg's Avatar
Car Model: forester 2.5xs
From an aesthetic or safety standpoint, I understand. Electrically, I'm puzzled. Electricity travels through wire at slightly less than the speed of light. I believe that the gauge, number of strands of wire in the cable, and quality of the connections would have a more significant effect than length.
Less is better when it comes to resistance in this case.
But you're right, neatness counts.
________
Kent
2004 Black XS
4EAT
Chilidawg is offline   Reply With Quote
Old 11-27-2012, 01:18 PM   #10 (permalink)
Wessneroo's Avatar
Car Model: XT Limited
From a physics standpoint, R = (pL)/A. Resistance equals resistivity times length divided by area. There is a direct relationship between length and resistance.
-Matt
'06 FXT Limited 4EAT CGM - "Roo II"
Wessneroo is offline   Reply With Quote
Old 11-27-2012, 01:53 PM   #11 (permalink)
Nthads's Avatar
with all this being said if you go with something similar to what i was saying with the metal woven ribbon and kept the length short and tight. It would prob have phenomenal conductivity yet resistance would probably be a bit higher than a straight wire but more surface area and wider than a spun wire.... just throwing thoughts out there.....
Old 11-27-2012, 05:01 PM   #12 (permalink)
Transmission: 4 speed auto
Cool How does the expression go?
How does the expression go? Too much of a good thing is sometimes too much! For sure, a properly grounded engine is a necessity. However, remember that some Subarus are waste spark ignition systems. A high voltage spark on one end of the engine should go to the other. Put a nice low resistance ground wire between and you might get a misfire.
Easy Fixer is offline   Reply With Quote
Old 11-27-2012, 05:06 PM   #13 (permalink)
forester06x's Avatar
Car Model: FXB
Wow, that sounds like a pretty big improvement, even stopping the lights dimming is a huge plus in my book. I will have to do this.
5MT Swapped & M62 Supercharged (WIP)-The GolfBall
forester06x is offline   Reply With Quote
Old 11-28-2012, 05:49 AM   #14 (permalink)
Car Year: '03
Car Model: Fozzy
But is the difference in 1-2" of wire, worth even mentioning?
No...
Old 11-28-2012, 06:54 AM   #15 (permalink)
dirtroadrunner's Avatar
Anyone with the grounding kit notice a reduction in the greenish-white powder (corrosion?) buildup around the battery? I have to clean mine every month or two, which is kind of annoying because every other car I've ever owned never had that crap grow on the battery. The terminals are cleaned, greased, etc and I still get it.
I may put together a grounding kit this weekend. My lights dim when I run the power windows all of the time.
dirtroadrunner is offline   Reply With Quote
