Go Back   Subaru Forester Owners Forum > Technical Forums and Vehicle Assistance > Engine and Exhaust > Naturally Aspirated (N/A)
Old 11-23-2007, 03:52 PM   #16 (permalink)
one bad dx is on a distinguished road
Book marked for later, good find Roo.
one bad dx is offline   Reply With Quote
Old 12-17-2007, 12:18 PM   #17 (permalink)
My only questions are....
1. Does anybody make a TB spacer for a MY 1998 Forester with a MAF?
2. What 2nd hand intakes fit a MY 1998 with a MAF?
3. Are there exhausts from other chassis's that are a direct bolt on to the Forester?
Nick.
Old 12-17-2007, 09:03 PM   #18 (permalink)
23-30 meters!
Forester 2.5 XTi's Avatar
Forester 2.5 XTi is on a distinguished road
Hey! Hope things work out in your pursuit of power!
#1... Read here about the TB spacer: Throttle Body Spacer Installed
#2...Hopefully people will back me up on this one, but I think the older GC chassis Impreza 2.5RS intake. I can't remember which years had MAP, and MAF.
#3...Another thing that could come from an older GC chassis Impreza. I believe the 2.5RS OEM would be an upgrade for you. Also note that these Impreza exhausts will be a few inches shorter. I for example have an Impreza STI exhaust and it overlaps just a bit right where the bumper molding begins under the car.
Forester 2.5 XTi is offline   Reply With Quote
Old 12-18-2007, 05:05 AM   #19 (permalink)
Well I've got a decent start, nothing crazy but some Phenolic 8mm intake manifold spacers will help me out in the persuit of Fuel economy + power, ultimately that's my goal for a Daily driver.
I've done alot of research on the TB/spacer but it does not seem to specify if it works with a 98 which has a MAF, Now that I think of it I'd have to assume that any chassis from 96-98 with a 2.5 would deffinetly work as they were the DOHC 2.5's opposed to the revised SOHC found from 99-02(_?_).
So the GC chassis is basically anything from 1993-2001 correct? So pretty much any mid pipe/axle back combo will need a little "tweaking" at the muff shop then? I figured as much as I know the Forester is an overstretched Legacy with some Tuff body lines. So basically any Intake from a OBD-IIa chassis will work and pretty much any exhaust will need some customizing to work.
Thank you very much for the heads up
Nick.
Old 12-18-2007, 08:04 PM   #20 (permalink)
23-30 meters!
GC is the 1993-2001 Impreza. Everything for the exhaust will bolt up, just the factor that it will end about 2 inches shorter. Some people don't care (like me!) you could have a tip welded on, FWIW you could probably buy a tip that uses bolts to tighten on. Also I'm not sure, but you may need extended hangers for the muffler section. The 2 right behind the bumper.
Old 12-19-2007, 01:33 PM   #21 (permalink)
What does FWIW mean? lol.
But 2'' of extension is not bad, it's like $20 bucks at the shop I go through for a quick mod like that.
Old 12-20-2007, 04:59 AM   #22 (permalink)
fujisan's Avatar
fujisan is on a distinguished road
Originally Posted by GIT-R-DONE View Post
for the ecu a pp6 is the best we can get for a N/A http://www.rallitek.com/rapeecu.html
Anyone tried this out? Is the power increase substantial (stage 1 specifically)?
I assume this must void the Foz's warranty?
'07 FX Premium Silver
fujisan is offline   Reply With Quote
Old 02-01-2008, 12:48 AM   #23 (permalink)
tallazzFilipino's Avatar
Gallery: 1
tallazzFilipino is on a distinguished road
after finally being told what "lawl" meant (many years ago), i was finally able to guess all those other chat acronyms. "FWIW" seems to mean: For What It's Worth.
_taF
for every misfortune, there is opportunity.
_romi
tallazzFilipino is offline   Reply With Quote
Old 11-10-2008, 06:15 PM   #24 (permalink)
dions is on a distinguished road
Fantastic read. Gives me some great ideas for my N/A Forester. I just hope my dad doesn't mind me hotting his car...lol
________________________________
White 03' 2.5XS 5spd k&n filter, tint, NGK plugs
dions is offline   Reply With Quote
