crank pulley removal tool ?? - Subaru Forester Owners Forum
post #1 of 14 (permalink) Old 11-30-2009, 11:26 AM Thread Starter
2003suby's Avatar
Car Model: forester XS
I have found two different tools that are listed for this and has two different size pins and a different size spread between the pins .. anyone know what the specs are for 2.5 L sohc N/a tool --
I found one part # of 499977100 -- but can't find the specs
03 foz XS 140K mi
55 chevy panel truck hotrod
2003suby is offline
post #2 of 14 (permalink) Old 11-30-2009, 11:37 AM
Guinness's Avatar
Car Model: s-turbo
I cannot help with the part numbers sorry, but have you already tried to get it off? my pully just 'wobbled' free, with not much effort at all.
Guinness is offline
post #3 of 14 (permalink) Old 11-30-2009, 11:45 AM Thread Starter
2003suby's Avatar
no not yet .. I am pretty sure I can get it removed well enough but my concern was being able to torque it down properly after I am all said and done... I figured on being my first time doing this particular task might as well be safe and have a proper tool for it
03 foz XS 140K mi
2003suby is offline
post #4 of 14 (permalink) Old 11-30-2009, 12:03 PM
Guinness's Avatar
Car Model: s-turbo
OK, sorry I couldn't help, good luck finding the info.
Guinness is offline
post #5 of 14 (permalink) Old 11-30-2009, 12:12 PM
Tuned200's Avatar
Car Model: FSXT / FSTI
Transmission: 6 MT
Feedback Score: 62 reviews
Im not sure what the correct tq setting is. I know with both of my subies, I just tightened it until it was tight. Its a reverse thread bolt IIRC and it will not back out. kinda ghetto, but im sure most everyone has done the same.
2007 Forester STI -
2007 XT Sport 4EAT -
2006 Forester XT -Sold-
2010 Forester X -
Tuned200 is offline
post #6 of 14 (permalink) Old 11-30-2009, 12:23 PM
Guinness's Avatar
Car Model: s-turbo
I pretty much agree with Tuned200, I put mine back in with plenty of thread lock, car in first gear, handbrake on, a nice swift pull on the torque wrench, click click, job done.
Guinness is offline
post #7 of 14 (permalink) Old 11-30-2009, 12:59 PM Thread Starter
2003suby's Avatar
I was kinda thinking that but all I ever see on here is people with stick shift subys and removal with 5th gear and a buddy on the brakes ...
I have an auto trans and can't seem to find any good info from that side ... didn't want to take chances
03 foz XS 140K mi
2003suby is offline
post #8 of 14 (permalink) Old 11-30-2009, 01:01 PM
Tuned200's Avatar
Transmission: 6 MT
My forester is also an auto. You need to "lock" the tq plate. There is a grea t DIY on here that shows how to do the auto.
2007 Forester STI -
2010 Forester X -
Tuned200 is offline
post #9 of 14 (permalink) Old 11-30-2009, 01:08 PM
Guinness's Avatar
Car Model: s-turbo
Yeah you're a bit stuck with an auto, you could always remove the starter motor and lock up the flywheel, I've had to do that before.
As you've said "you don't want to take chances" it's probably best for you to find the right tools for the job.
edit:- beaten to it.
Guinness is offline
post #10 of 14 (permalink) Old 11-30-2009, 01:25 PM Thread Starter
2003suby's Avatar
I just looked at all 5 pages og DIY and couldn't find it -- any idea of the topic name ?
03 foz XS 140K mi
2003suby is offline
post #11 of 14 (permalink) Old 12-01-2009, 06:36 PM
2001 AT here, just had to remove and replace mine here recently and this is how I managed to do it without buying the tool. On removal I used the old belt that was going to be replaced and gripped it with vice grips and spun the motor enough so the vice grips lodged against the bracket for the AC compressor (crappy solo technique). On installation I had to do a little better and realized if I put three 3 inch 3/8 socket wrench extensions in the holes so I could use a long wrench with a cheater bar to prevent the the motor from turning while I could get the bolt torqued to the 130 ft lbs torque it calls for. I had to put the socket on the bolt, slide the wrench in to prevent turning, then attach the 1/2 drive extension on my torque wrench to the socket as the socket wont fit in the gap after the holding wrench is in place. You will need a friend with a little mass or strength for the holding part IMHO. Mine had normal RH threads btw.
The Subaru part number you have is correct for my vehicle, 499977100 , unsure on the specs/cost though.
2011 Premium AWP AT
2001 S AT 115K
wb22rules is offline
post #12 of 14 (permalink) Old 12-02-2009, 02:20 PM
tomlitch's Avatar
Car Model: Forester S
I also stuck a few extensions in there - they fit perfect and put a pry bar in. If you have someone to help you out holding it while you torque it down it works beautifully.
tomlitch is offline
post #13 of 14 (permalink) Old 12-03-2009, 01:07 PM
GregB's Avatar
Car Model: 2.5XS
Heres how I got mine off: Link
'04 2.5XS 4EAT
GregB is offline
post #14 of 14 (permalink) Old 12-03-2009, 05:48 PM
Tuned200's Avatar
Transmission: 6 MT
I jammed my flywheel with 2 long screwdrivers.
2007 Forester STI -
2010 Forester X -
Tuned200 is offline
