Red FWD light - Subaru Forester Owners Forum
post #1 of 17 (permalink) Old 11-13-2007, 03:11 AM Thread Starter
Red FWD light
I test drove a 2004 Forester X and loved it. However the red FWD light on the speedometer never went out for the test. The drive was 20 miles round trip to my mechanic to have it checked out, and he never mentioned it being a problem, and I forgot to ask about it. Later I became more concerned about it as red lights are usualy never good. I have never owned a Subaru before having had SAABs since 1972, so I have no resources ( but this forum) to help me. Also the road conditions were clear and dry.
I left a deposit with the dealer but am I looking at major problems.
DNash is offline
post #2 of 17 (permalink) Old 11-13-2007, 03:39 AM
Mr. September 2008
Oddnoggins's Avatar
Car Model: Legacy
It sounds like you're in Front Wheel Drive mode, which is usually only used when you have an irregular size spare on, which is only the Automatic transmission if I understand it correctly.
check your AWD fuse?
Oddnoggins is offline
post #3 of 17 (permalink) Old 11-13-2007, 03:45 AM
Mr. September 2008
Oddnoggins's Avatar
Car Model: Legacy
More specifically, I think you would not want a fuse in that slot, so pull it and see if the light goes away after restarting the car?
what size fuse to use to disengage awd
post #4 of 17 (permalink) Old 11-13-2007, 04:01 AM
nds
Originally Posted by DNash View Post
I test drove a 2004 Forester X and loved it. However the red FWD light on the speedometer never went out for the test. .
That light is usually on only if someone has installed a fuse in a special slot to lock out the rear wheel drive and convert to front-wheel drive only. This option is provided in case you have a spare tire that is not very close in size to other tires and have to use it. The recommendation is to put the spare on the back and lock out rear wheel drive until matching tires can again be installed. As this may tell you, the Subaru is sensitive to having four matching tires with about the same amount of wear.
nds is offline
post #5 of 17 (permalink) Old 11-13-2007, 07:01 AM
brickhoss's Avatar
Car Model: 411whpFXT
Damn, I wish I was a fuse away from converting to RWD... That would be awesome!
brickhoss is offline
post #6 of 17 (permalink) Old 11-13-2007, 07:26 AM
sahunt's Avatar
I would be concerned that the AWD system might have a fault, and some unscrupulous person has inserted the FWD fuse to mask that fault. Could even be a previous owner. I would either walk away from the car completely, or at least get that FWD fuse taken out and go for a LONG test drive. Also have your mechanic re-check the car at his own expense as he really should have noticed the warning light!
If the FWD fuse has not been inserted then you will want to get some proper diagnostic work done, or risk buying a 2WD Forester!
-- Steve
MY2005 2.0 XT, 4EAT
MY2003 Seat Leon Cupra, 6MT
sahunt is offline
post #7 of 17 (permalink) Old 11-13-2007, 08:42 AM
Feedback Score: 53 reviews
-- Steve
+1
Buyer beware...
~ Silke ~
'04 FXT 4EAT PSM - "Subed Up"
'98 S 4EAT DBP - "Slynki"
pleiad7 is offline
post #8 of 17 (permalink) Old 11-13-2007, 11:18 AM
funkymonkey1002's Avatar
Car Model: 2.5 XT
Take the fwd fuse out and do some low speed tight turns and see if theres any hopping. Also, does the car currently have all the same tires on it?
funkymonkey1002 is offline
post #9 of 17 (permalink) Old 11-13-2007, 09:08 PM
Graham's Avatar
Car Model: Sport XT
Originally Posted by pleiad7 View Post
+1
Buyer beware...
+2
Something very fishy there. I'd also suggest that mechanics who ignore red lights are well worth staying a million miles away from.
Graham is offline
post #10 of 17 (permalink) Old 11-14-2007, 03:28 AM Thread Starter
First I would like to thank those who replied to my post. I told the dealer why the deal was in doubt, he has until noon today to explain the FWD light. The car was advertised one week earlier with new tires then when we saw it, very used tires were on it and the new tires was removed from the ad, so they must have been doing something in that area. I am thinking of a no charge extended warranty on the AWD, six months or a year or just voiding the deal.
Worst case, if the FWD was set to mask a problem with the AWD, and the AWD needed to be totaly replaced, what would the cost be ?
I asked three Forester owners at work yesterday about the FWD light and none knew about it ! But this forum gave me the answers I needed within minutes. Thanks again.
DNash is offline
post #11 of 17 (permalink) Old 11-14-2007, 06:05 AM
huck_this's Avatar
Car Model: SOLD!
^ Bring it to a garage that have experience with working with Subaru's.
Also does the A/T Oil temp light flash when you start it up? That's how how you can find out if its giving you a fault code.
Read this http://endwrench.com/images/pdfs/4EAatPh2Win04.pdf
This may clear up some questions.
Gary
huck_this is offline
post #12 of 17 (permalink) Old 11-14-2007, 09:08 AM
Graham's Avatar
Car Model: Sport XT
Well, for a start it would not need to be totally replaced since it is using a large part of it to work in FWD mode. Also, the rear axle is probably OK (especially if it has an open diff - does the one you are looking at have the premium package?) so it is likely to only involve a few parts in the main transmission. That said though, it won't be inexpensive to fix - even if it is only a solenoid which has failed, labour charges are going to add up (in fact, if that fuse has been in for any great length of time, it may have fried something anyway and be incapable of operating in AWD mode).
Personally, I'd pass on this car. There should be plenty of non-suspect Foresters around without having to deal with this one. We'd love to have you as a fellow Forester owner, but we'd hate it to be an expensive headache for you!
Graham is offline
post #13 of 17 (permalink) Old 11-15-2007, 06:42 AM
huck_this's Avatar
Car Model: SOLD!
^+1
post #14 of 17 (permalink) Old 11-15-2007, 05:31 PM Thread Starter
I voided the deal because I could not get an answer as to WHY the fuse was in there. It was a very ugly exchange with the dealer. A sad situation.
Much thanks again to this forum for the quick and accurate information that prevented me from losing scarce money an a defective car.
I am still sold on Foresters and am looking at a 2003 tomorrow. I am interested how it drives in AWD.
DNash is offline
post #15 of 17 (permalink) Old 11-15-2007, 05:41 PM
Kevin's Avatar
Car Year: MY03
Good decision! Good luck with the next one
Kevin is offline
