MY2011 2.0D Traction Control On Or Off - Subaru Forester Owners Forum
post #1 of 17 (permalink) Old 10-31-2011, 02:29 AM Thread Starter
Holdencars's Avatar
Car Year: MY12
Car Model: 2.0D Premium
Transmission: 6spd Manual
Just got my 2011 2.0D Premium. The only question I have about it is the Traction Control OFF button. When would I use it. I intend to do many beach trips so therefore will hit soft sand. Do I want to TC on or off.
Other posts mention VCD. Is that the same as TC?
MY12 2.0D Premium 6MT
Holdencars is offline
post #2 of 17 (permalink) Old 10-31-2011, 02:48 AM
NSHF's Avatar
Transmission: auto
i find my 2008 is almost useless offroad with traction turned on, especially climbing hills or on the beach. give it a go either way and you will get a good feel of the difference it makes
NSHF is offline
post #3 of 17 (permalink) Old 11-08-2011, 07:47 PM
campisi's Avatar
Car Model: 2.5X Premium, AWP
I just bought a 2011 Forester and asked the salesman under what circumstances would I turn OFF the traction control and he said "if you want to get crazy with it, fishtailing the back end and stuff". I'm thinking, yeah right. That's why Subaru put that feature there. ***?!
campisi is offline
post #4 of 17 (permalink) Old 11-09-2011, 10:32 AM
I was told it is only turned off in a towing situation.
ZapWizard is offline
post #5 of 17 (permalink) Old 11-14-2011, 07:52 PM
campisi's Avatar
Owners manual says it's useful to turn it off
"to facilitate the following opertions:
- a standing start on a steeply sloping road with a snowy, gravel-covered, or otherwise slippery surface.
- extrication of the vehicle when it's wheels are stuck in mud or deep sno
I read the last one as rocking the car to get it moving in that situation. Sounds like I might try just turning it off the next time I get to try out this car in the snow. (in a parking lot till I figger it out!)
campisi is offline
post #6 of 17 (permalink) Old 11-15-2011, 01:56 AM Thread Starter
Holdencars's Avatar
Car Year: MY12
I took an offroad track last weekend and got into a situation where two opposing wheels (front and back) lost traction on uneven ground and were spinning and I couldn't go forward. I let them spin for 5 or 10 seconds then stopped and rolled backwards and tried again and the same thing happened. From what I've seen on Youtube videos of the Forester the traction control was supposed to have locked the spinning wheels and let the wheels with traction drive but it didn't happen. I couldn't turn around so on the third attempt rolled back and took a different angle and got through. Does it need 3 wheels with traction to work?
post #7 of 17 (permalink) Old 11-15-2011, 04:26 PM
RadcomTxx's Avatar
Car Year: 10
Did you turn the VDC system off when on the off road track? If so the traction control that would have helped it attempt to go was also off.
RadcomTxx is offline
post #8 of 17 (permalink) Old 12-12-2011, 02:30 AM Thread Starter
Holdencars's Avatar
Car Year: MY12
VDC was on. Seems all Subaru's suffer when they get two diagonal wheels off the ground and it's a common flaw not yet overcome. Probably the same for any 4x4 unless fitted with diff locks. Subaru could probably fix it with TC/VDC if they wanted to. The lesson learned is either have enough momentum to get at least one back on ground for traction or getting the angle right so two diagonal wheels don't lose traction at the same time.
post #9 of 17 (permalink) Old 12-12-2011, 03:41 PM
simxs's Avatar
Car Model: Forester XS
It is interesting that the electronics didn't help in this situation.
I've found in a similar situation in a Pajero that the traction control didn't help at all when I was gentle with the accelerator and the wheels were only spinning slowly. That is, it needed some revs (maybe 2000+ rpm), clutch fully out and significant wheel-spin before the electronics stepped-in and braked the spinning wheels and got us moving again. It seemed a bit mechanically 'unsympathetic' and threw dust everywhere, but this is how the system is apparently tuned and it needs somewhat aggressive driving to make it work effectively.
Do you remember if you had sustained and significant wheel-spin at the time?
Simon
2002 Forester MY03 XS manual
simxs is offline
post #10 of 17 (permalink) Old 12-12-2011, 09:21 PM Thread Starter
Holdencars's Avatar
Car Year: MY12
I wasn't too enthusiastic on sustaining wheel spin because the surface was rocky and didn't want to chew up the tires. I'd also watched Bluefox's youtube clip beforehand and knew it probably wouldn't do any good. This is good educational watching -
post #11 of 17 (permalink) Old 12-12-2011, 09:41 PM
dpm
Car Model: XC diesel
there's no VDC on BF's car, is there?
2015 SJ XCdiesel CVT
dpm is offline
post #12 of 17 (permalink) Old 12-13-2011, 02:49 AM
RadcomTxx's Avatar
Car Year: 10
nope, in that video he was experimenting with modifying the e-brake to simulate the VDC system.... it didn't work.
post #13 of 17 (permalink) Old 12-13-2011, 04:07 AM
taza's Avatar
Transmission: Dual-Range Manual
If any of you guys are interested ive almost come up with a prototype locker to lock the rear differential in our Subarus. All Subies from the mid 80's till 2011 with R160 standard diffs
With some of us hardcore aussies and our Subies it will cut out the diagnal spin, possibly helping with the standard centre VLSD. But with a locked centre in an L-Series or with DCCD as some of the hardcore offroad Subies have it will be just as good as a real 4x4. It won't stop 1 wheel spin at the front end like BlueFox has/had but on a rock climb or in sand there is a good chance it will make a good improvment.
Thought some of you guys might be interested.
Taza
01 Foz 2.5- D/R, 5" lift, Bullbar, Rearbar, LSD
taza is offline
post #14 of 17 (permalink) Old 12-13-2011, 04:49 AM
Transmission: 5-Speed
i got stuck in mud with my 2011 2.5x with MT. I surprised i couldn't get out with VDC on and i sustained wheelspin for a good amount of time and i couldnt get out. I turned VDC off and i was able to get my self unstuck. So take it for what its worth.
ender is offline
post #15 of 17 (permalink) Old 04-09-2012, 04:38 AM
New User
Car Model: Outback
Transmission: manual
Turn off TC for all wheels slipping
I still need to verify this, since I have not taken the OB to the beach yet, but my understanding is that TC/ATC/VDC works similar to ABS by applying limited braking to the slipping wheel. Normally this is a good idea. But, if the vehicle is on a surface where all wheels are slipping, i.e. ice or sand, the engine starts fighting the brakes. Turn off TC/ATC/VDC and use your driving skills.
At one time, I found a youtube video of someone burning up their clutch on a beach. Presumably TC/ATC/VDC was left on.
Joel_12OB2dot5MT is offline
