Subaru Forester Fog Light LED Bulbs! HP, XP, XML2 models! Plug & Play Install! - Page 4 - Subaru Forester Owners Forum
 6Likes
post #46 of 75 (permalink) Old 02-02-2015, 07:21 AM Thread Starter
Supporting Vendor
Diode Dynamics's Avatar
Car Year: 2013
Car Model: Scion
Originally Posted by Xdub View Post
I've all parts ready to order but the housings. Any chance that these will be available with a yellow output? I drive in some serious blizzard and fog conditions so I need true yellow, for performance not looks. Seems putting a yellow filter on is mostly for looks.
Our XP80's will provide 510 lumens of total output (measured). Here's an example of the color:
We will have a yellow XML2 option soon (1,420 lumens / measured)
Nick C.
Experts in Forester Lighting
(314) 205-3033
Diode Dynamics is offline
post #47 of 75 (permalink) Old 02-02-2015, 07:49 AM
Xdub's Avatar
Car Year: 15
Thanks Nick, I think I'd like to go that route. Now to just find the best housings to use with your bulbs.
Xdub is offline
post #48 of 75 (permalink) Old 02-03-2015, 07:06 AM Thread Starter
Supporting Vendor
Car Year: 2013
Car Model: Scion
DEPO makes nice OEM-quality replacements FWIW. We often recommend them for customers looking to add housings.
Nick C.
(314) 205-3033
post #49 of 75 (permalink) Old 04-21-2015, 07:30 AM Thread Starter
Supporting Vendor
Car Year: 2013
Car Model: Scion
Here's a recent comparison on a 2015 Subaru XV Crosstrek
Nick C.
(314) 205-3033
post #50 of 75 (permalink) Old 06-16-2015, 05:12 AM Thread Starter
Supporting Vendor
Car Year: 2013
Car Model: Scion
NEW! LUXEON LED Fog Lamp Replacement Housing!
OEM-grade fog lamp housing that utilizes LED technology. It's a direct replacement for direct replacement for Subaru Part # 89210094, fits Subaru Forester, 2014-2015*. It replaces the entire factory fog lamp housing.
LUXEON LED Fog Lamps (Type A) - LUXEON Universal - Headlights, Foglights - Assemblies - Lighting
Feel free to give us a call for more information: (314) 205-3033
Thanks,
Nick C.
(314) 205-3033
post #51 of 75 (permalink) Old 07-22-2015, 10:49 AM Thread Starter
Supporting Vendor
Car Year: 2013
Car Model: Scion
Diode Dynamics is pleased to announce a new color for our popular XML2 fog light -YELLOW (3000K)! The XML2 utilizes genuine CREE XML2 components, for a true, measured output of 1,420 lumens. 100% plug-and-play. Sizes available include 9005, 9006, H8, H10, H11, H16, and PSX24W.
Nick C.
(314) 205-3033
post #52 of 75 (permalink) Old 08-23-2015, 06:48 AM
Car Model: Forester XT Ltd Tech
So the Luxeon housings are lower output than the XLM2s? 600 lm/each vs 1410 lm/each?
Canadian_XT is offline
post #53 of 75 (permalink) Old 08-24-2015, 05:47 AM Thread Starter
Supporting Vendor
Car Year: 2013
Car Model: Scion
The Luxeon housings produce less lumen output, but the output pattern itself is more usable thanks to the design of the optics.
The wide output and sharp cutoff are what make the Luxeons ideal for the fog light location
Nick C.
(314) 205-3033
post #54 of 75 (permalink) Old 10-28-2015, 05:28 AM
For clarification, as asked by Canadian_XT, the XML2s are 1410 per bulb? What is their output pattern and cut off in the OEM housing? Do you have a diagram/graphic or angles/degrees? Anything to clarify how the light is projected out or the OEM fog housing?
COBiker is offline
post #55 of 75 (permalink) Old 10-28-2015, 05:35 AM Thread Starter
Supporting Vendor
Car Year: 2013
Car Model: Scion
The XML2s are indeed 1,410 lumens per bulb (measured)
They produce significantly more lumen output than the factory halogen bulbs, but utilize the factory reflector fog light housings quite well.
I don't have a graphic or diagram on file with the angle or degrees of the Subaru Forester's factory housing, but it's worth noting that fog lights are an auxiliary location, mounted low on the vehicle, and will not create significant glare for other drivers on the road. Especially not as much as an HID conversion kit.
If you are looking for a technical spec-sheet with our measurements of the H11 XML2, please send an email: contact@diodedynamics.com and we can provide you with more information from our engineering team.
We also offer a complete LED replacement housing, which replaces the entire factory fog light housing. (currently out of stock).
Thank you!
Nick C.
(314) 205-3033
post #56 of 75 (permalink) Old 10-28-2015, 08:05 PM
Thanks Nick for the information. I guess I'll wait for black Friday to load up on interior and exterior LEDs. Since I haven't found any before and after shots of the yellow (3000k) XML2 in XT OEM fogs, I guess I'll have to take some shots and post them in December.
COBiker is offline
post #57 of 75 (permalink) Old 10-29-2015, 05:35 AM Thread Starter
Supporting Vendor
Car Year: 2013
Car Model: Scion
We haven't had a chance to take comparisons in the XT yet, but here's a few recent comparisons in the XV and a 2014 WRX:
Please note: the WRX's housings were cracked, so it affected the output pattern a bit
Nick C.
(314) 205-3033
post #58 of 75 (permalink) Old 10-29-2015, 05:44 AM
FXTerrific's Avatar
Car Model: XT Touring
are the XP80 yellows in stock for 06-13 fozzie?
trying to convince myself to jump for the XML2 yellow, but really only need the XP.
either way, ill take a ton of accurate 09-13 spec shots and send them over.
Moore Performance
Import Image Racing
TurbotekTuning
Ground Control
FXTerrific is offline
post #59 of 75 (permalink) Old 10-29-2015, 05:46 AM Thread Starter
Supporting Vendor
Car Year: 2013
Car Model: Scion
The XP80s are out of stock at the moment. We are making some improvements to the design.
The XP80's produce 510 lumens vs. XML2 which produces 1,420 lumens (measured)
We also offer a Yellow halogen replacement from Putco
Nick C.
(314) 205-3033
post #60 of 75 (permalink) Old 10-29-2015, 05:52 AM
FXTerrific's Avatar
Nick C.
thanks. im going to go with the XML2s i think anyway. might as well if im looking for a difference from the Nokya yellows i have now. just "mehhh...." performance (imo, best (color wise) of the halogens ive tried).
Moore Performance
Import Image Racing
TurbotekTuning
Ground Control
  Subaru Forester Owners Forum > Supporting Vendors Specials > Diode Dynamics
