('09-'13) Oil Change#2 and 14MM Drain Plug is Junk - Subaru Forester Owners Forum
post #1 of 30 (permalink) Old 10-02-2011, 11:37 AM Thread Starter
AlleyCat's Avatar
Car Model: Forester X 6MT
Transmission: 6-Gear Manual
Just finished installing subaru (Idemitsu) 0w20 oil at 7161 miles for OC#2. This replaces the Mobil 1 0w20 we ran for 5100 miles. The mobil 1 oil came out VERY dirty (see pics). Main gripe is, when removing the drain plug with 14mm 6-point box wrench, the nut rounded off (see pics). I had to put foil over the nut head and hammer a 14mm impact socket to remove it. Many here have complained about the DP bolt, and I had little problem with it at OC#1, but this time it wouldnt budge. I will request a new free DP bolt from our local Subaru dealer. This thing must be made from very mild steel or ??? I will be looking for a more robust replacement and hope Subaru recognises it needs a better one also. I never in over 40 years of professional maintenance had an issue with a drain plug bolt. I was a NIASE MASTER in the 70's and early eighties.
ID:	32900   Click image for larger version
AlleyCat is offline
post #2 of 30 (permalink) Old 10-02-2011, 11:59 AM
dpm
Car Model: XC diesel
surface-drive sockets ftw.
2015 SJ XCdiesel CVT
dpm is offline
post #3 of 30 (permalink) Old 10-02-2011, 12:27 PM
At the risk of starting an argument. ...It is physically impossible to round off a nut using a 6 point socket, unless it slips off.
Using an 18 inch breaker bar and keeping it perpendicular to the plug it can't not work. Don't get me wrong..I have had a socket come off a nut/bolt before. But it was my fault.
adc is offline
post #4 of 30 (permalink) Old 10-02-2011, 12:37 PM
Pleiads' biggest leghumper
joe r's Avatar
Car Year: 04's
Car Model: 2 FXT's.
Feedback Score: 71 reviews
What wrench brand are you using?
joe r
joe r is offline
post #5 of 30 (permalink) Old 10-02-2011, 01:01 PM Thread Starter
AlleyCat's Avatar
This is what I get for making fun of the other guys who rounded off their DP plugs earlier this year It appears to be an undersized 14MM head - if it was 13 MM we could use a 1/2" for a tighter fit. Yes, the wrench did cam off the head as the metal gave way. The wrench was aligned and square with the head. No Problems with my Ford which has a nice built in, recessed kep reusable rubber gasket. Also, no problems with ANY other car and my Subaru EJ253 17mm was fine. Believe me Al, this thing is made out of "pot metal" and the head is too small for the thread size. And I specifically undertourqued it when I did OC#1, this is not the factory install. Also the plug does not thread in all the way by hand - it acts like a tapered pipe thread - but it isnt. I guess all I'm saying is cars need a nice robust drain plug. If I'm having trouble with it, others will too. And have!
AlleyCat is offline
post #6 of 30 (permalink) Old 10-02-2011, 01:08 PM Thread Starter
AlleyCat's Avatar
joe r
I hear you. Use the best quality wrench especially for problem bolts and nuts. I bought a 14mm box 6pt wrench just for this DP given the past thread about guys rounding off the heads. Unfortunately the wrench some off shore Stanley combination. Its not an S-K or Craftsman or Snap-on. I was going to use my snap-on flare nut wrench but I dont have metric (I dont even think they make metric flare nut wrenches).
AlleyCat is offline
post #7 of 30 (permalink) Old 10-02-2011, 01:15 PM
mx_599
Guest
Posts: n/a
I have some from craftsman, just used them on a Jeep rack/pinion
post #8 of 30 (permalink) Old 10-02-2011, 01:15 PM
flstffxe's Avatar
Many automotive drain plugs don't have a standard hex head on them like a bolt. They have a tapered hex IE: it is slightly smaller at the top of the head and as the wrench slides on they get bigger at the base. These heads provide a situation that can start the process of the wrench stripping the head, as the wrench 6pt or 12pt will engage at the base of the hex and the wrench will want to roll off the the plug. Not saying this is what happened, but I have seen many upon many plugs with a tapered hex.
08 X Prem 5mt
flstffxe is offline
post #9 of 30 (permalink) Old 10-02-2011, 01:18 PM
Fast & Dirty
SubieOutlaw's Avatar
Transmission: 4 speed auto
WOW.
I use a wrench not a socket and mine looks brand new after countless changes.
Ditch the socket and use a wrench.
SubieOutlaw is offline
post #10 of 30 (permalink) Old 10-02-2011, 01:22 PM Thread Starter
AlleyCat's Avatar
Well, I bet you have the nice 17mm which works fine. The FB engine's 14mm drain plug looks like a one-time install drum bung plug. At best.
AlleyCat is offline
post #11 of 30 (permalink) Old 10-02-2011, 02:54 PM
I was going to use my snap-on flare nut wrench .
Problem with that though is that it being open on one of the flats it would have deformed.
And if that nut head is papered a bit ..I can see it happening. Yea it looks like it needs a bigger head. Probably a auto parts place will have one. Glad you got it off anyway.
adc is offline
post #12 of 30 (permalink) Old 10-02-2011, 04:05 PM
AWDFTW's Avatar
Car Model: Outback
Replace that with a nice Fumoto valve.
2003 Outback 2.5 AWP.
AWDFTW is offline
post #13 of 30 (permalink) Old 10-02-2011, 07:54 PM
mx_599
Guest
Posts: n/a
I wonder why my valve didn't work out...seems like most people like them a lot
post #14 of 30 (permalink) Old 10-02-2011, 08:45 PM
Lone Ranger's Avatar
Car Model: 2.5X EJ253
Time to start using an oil extractor through the dip tube instead of crawling under and using a wrench.
2009 2.5X, Dark Gray
Lone Ranger is offline
post #15 of 30 (permalink) Old 10-02-2011, 09:37 PM
AWDFTW's Avatar
Car Model: Outback
I like mine a lot, but I need to replace the crush washer they supplied next oil change. It weeps just enough to make the oil pan wet. Not enough to register on the dipstick though.
What problem did you have with yours?
AWDFTW is offline
