Will not start - Help 1998 gt - Subaru Forester Owners Forum
post #1 of 4 (permalink) Old 05-16-2010, 02:11 AM Thread Starter
Car Model: Forester GT
hi
have a 98 forester gt wagon that will turn over but will not start
speedo reads 212000km
if i squirt fuel in the manifold i get it to fire
possible fuel pump or relay
please how would i acess the fuel pump i asume its in the tank?
and how do i identify which is the pump relay as their is three in a row on the rhs kick panel
cheers mike
Super Roo Tours is offline
post #2 of 4 (permalink) Old 05-16-2010, 03:09 AM
Bassmaker's Avatar
Car Model: Forester S Turbo
Hi Mike. If it is the fuel pump, it's not a major job to get at it. There are two oblong hatches, about six by four inches in the boot just behind the rear seats, one on the left and one on the right. The pump is under the larger cover which is on the right/drivers side (UK) and requires a phillps screwdriver, 10mm socket and some thin nose pliers. Sea Scooby did a very nice picture post on the whole job. Put "changing fuel pump" into search and it's about half way down labeled "Changing to Walbro Fuel Pump". As I said it's not difficult but it should be done on less than 1/3 of a tank of fuel otherwise you will get pressure spillage when some of the hoses are released. Most difficult part is wiggling the pump out with it's ganglian attachments, and then back in again along with some petrol spillage from boot to wherever you are going to inspect it, an old T shirt/towel or whatever will be useful. If you can locate the fuel pump relay, turn the ignition off and put your finger on it then turn the ignition on, you should feel it it click if not hear it. If the relay is gone I guess that would be the handiest job for replacement. Also, I'm pretty sure you can hear the fuel pump running with the ignition on before the engine is started, mine's quite loud. Is there a fuse for the fuel circuit under the bonnet? If you need to replace the pump and want to put in a Walbro, check first but I'm pretty sure the 98 uses the 341, mine is a 99 and it uses the 341, NOT the 342. Hope this is of some help.
Bassmaker is offline
post #3 of 4 (permalink) Old 05-16-2010, 02:58 PM Thread Starter
mate
thanks a lot thats a great help as its a start
know i got some idea what to do
cheer smike
post #4 of 4 (permalink) Old 05-17-2010, 04:16 PM Thread Starter
The outcome
just to update
i found the fuel pump, it was located on the rhs behind the seatbelt anchor point of the rear seat- as someone said under that black foam compartment
checked the fuel pump relay which clicked on ignition so took the punt and
replaced the fuel pump
and it fired up
replacement pump i used was a GOSS-p/n GE079
they are made in australia and cost me $150aus
subaru quoted excess of 400
thanks for the forum a valuble resource center that is globle
cheers mike
  Subaru Forester Owners Forum > Technical Forums and Vehicle Assistance > Engine and Exhaust > EJ20 - 2.0L Turbocharged
