Wife went on trip to Mexico and had mud/waterspots everywhere on our WRB forester. I washed it and the mud came off, but the spots didn't. I then tried the claybar, some cleaner wax, and scratch remover on the spots, and even tried by hand and buffing machine. They're just laughing at me...tauntingly...
Anyone know what else I can use to take off water spots? |
I've had really good success on my 2001 Forester using 3M Perfect It II with a wool buffer then following up with Meguire's swirl remover and a good wax after that. I've had to do it twice after the local carwash left really bad water streaks in the paint. I don't know what they use but it doesn't like Subaru Blue Ridge Pearl.
Three Wagon Family! 00 OBS 01 Forester L 03 WRX |
#6 (permalink) | |
#7 (permalink) | |
I cleaner spray bottles labeled with "acetic acid". On day (long ago) the land lady stopped by and said I needed to be careful with that acid or I might get hurt... :) I wish I had some chips handy so I coulda sprayed it on the chips and ate them :) |
#8 (permalink) |
Consumer's Reports tested out scratch removers for surface problems (swirl marks, light scratches, etching). It sounds to me as though your paint surface must have been badly etched by whatever was in the composition of the mud that you got splattered with. It must have been highly acidic. Could it have been near an industrial area?
The one that was the highest rated was the Quixxx brand. It was the only one that was able to even out scratches that you could feel with your finger-nail. You might give it a try. But be very careful with this type of stuff. If you get too vigorous it could wear through the clear coat and cut right through to the paint. You might also test it on an inconspicuous area like in the door jam area. Griff
Griff (The Geezer) Drives a 2009 Forester XS Ltd. |
#10 (permalink) | |
MY07 WRB FSXT MT bobbytuned MY00 SR OBS AT |
#12 (permalink) |
Hey Guys, Keep in mind, not only acid cleans. The problem with swirl marks and such may be due to an acid reaction. Sometimes you may need to use a base like amonia.
If you want to be really carefull, get some ph strips, and put a drop of water on your car, where the marks are, then dip you ph paper, you want to try and balance it out. just a suggestion.
"If you done it, it aint braggin" AWD Believer. |
#13 (permalink) |
update...didnt have vinegar, but did have a buffer and bug/tar remover...I just put some of that liquid on the drops and let the buffer to its job for about 1-2 minutes, wiped with rag and they were gone! Also went to several autoparts stores and only found 3m scratch remover and perfomance finish...so I ran thru both on the whole truck, a little back to black and titanium tire finish...oh so nice! Felt like that tony stewart commercial...LOL...
