Hi Guys,
Have been a member a few months now since I picked up my MY06 XT 5MT. Nothing really happened till now though, and wanna keep a bit of a record so it's time to start a thread.
Picked the car up from Sydney and drove it back to Canberra at 3 o'clock in the morning, and coming from a junk heap VT Commodore auto I had a stupid grin on my face the whole trip! :icon_wink:
After getting stuffed around by the ACT Rego folks for a week or two (normal practice for them apparently), it was registered.
Not too long after I bought it:
Current pic (will try to remember to keep this updated as things change):
...Also, my photography skills got a bit better!
First mod ever was a Kartboy delrin shiftknob with thanks to Entra... Had never heard of Kartboy before getting the Foz!! 🤷
Anyway, this thread will not be action packed like some others on here, but i'll update as stuff happens.
Thanks for looking and comments, criticism, tips etc are all welcome!!
Feb 2013 - Replaced bearings
Feb 2013 - Installed BC Racing BR Coilovers
Feb 2013 - Wheel alignment
Feb 2013 - Blacked out grill
Mar 2013 - Installed Subtle Solutions fender braces
Apr 2013 - Painted stock muffler black
May 2013 - Fitted Hitech diff back
Jun 2013 - TurboXS Stealth Back
Jun 2013 - Kartboy Short Shifter and TiC Holy Shift Kit
Sep 2013 - Installed '06 WRX seats
Jan 2014 - 24mm swaybars and rear strut brace install
Makes it go:
Stock block and 5MT
VF30
Killer B Oil Baffle and Pickup
Tomei timing belt guide
Gates timing belt kit with water pump
Process West TMIC and splitter
Turbosmart Kompact BPV
Injector Dynamics ID1000s
Grimmspeed 3 port
Logpro Silicon - Radiator, SFB and intake
Deutschwerks DW200
Competition Clutch stage 2 with light flywheel (total garbage, to be replaced)
Group N Engine Mounts
Group N Pitting Stopper
TurboXS turbo back 3" stainless exhaust
TCP stainless diff back
eTuned by Steve @ Pullz-On Tuning for 98 and E85
Virtual Dyno = 221kw/436nm on 98 and 248kw/516nm on E85
Makes it stay on the road:
Enkei RPF1 - 18x8 +45
Nitto NT05 - 245/40R18
Whiteline BSF33XZ 24mm Forester front adjustable sway bar
Whtieline BSR37XZ 24mm GDB STI rear adjustable sway bar
Whiteline KBR21-24 GDB STI rear heavy duty sway bar mounts
Whiteline KSB590Q Rear quick release strut tower brace
Subtle Solutions front fender braces
Other cool stuff:
Bugeye STI Scoop
AEM UEGO Wideband/Boost Failsafe Guage logging to Tactrix
Kartboy shortshifter
Kartboy rear shifter stay
Kartboy front shifter stay
Turn in Concepts 5MT linkage bushings
Turn in Concepts pivot bushing
Whiteline W92829 Front gearbox crossmember pad bushings
Shell Helix Ultra 5w-40
Motul Gear 300
Parts to be installed:
STI Foz lateral links (with HID leveller bracket)
STI 06 front control arms (with HID leveller bracket)
STI trailing arm mounts
Group N transmission mount
Kartboy Outrigger comfort
Kartboy trailing arm F & R bushes
Whiteline KSB750 subframe lock bolts
Whiteline KCA313 RCA Kit
Whiteline KCA414 rear camber bolts
Nolathane steering rack bushes
Cusco Mastercylinder Brace
Saiko Michi oil catch cans x 2
Xtreme HD clutch w/ stock flywheel
STI Brembo front calipers
WRX 2 pot rear calipers
WRX rear hub backing plates
Braided lines
BNA Solutions Guage Pod
Speed hut Gauges - oil pressure and water temp
Parts Coming:
KAP Industries fire extinguisher brackets L and R
Need some daily rims to clear Brembos - thinking Work Kiwami 18x8.5 +38 in GTS finish with 245/40R18 random tyres.
Makes it go:
Stock block and 5MT
VF30
Grimmspeed 3 port
Deutschwerks DW200
Other cool stuff:
Bugeye STI Scoop
Motul Gear 300
Braided lines
Parts Coming:
