Trevor's 2005 Aspen White Forester XT with a side of 2000 2.5RS Coupe
The following is a journal to document my Aspen White Forester XT
Car Details:
2005 Forester XT
Aspen White
5MT
117,000 miles
Backstory:
Picked the car up with 93k miles from a guy in Orange County. I believe I'm the 3rd owner. Car was originally in MA and spent 70k miles of its life there before it was transplanted to Washington state, and then finally to CA. 70k miles in MA definitely left it's mark, but not nearly as bad as some cars. Mostly just made me cuss more often, and throw more tools than I had to when swapping parts out. Read on to see!
Goals for the Forester were to create an OEM+ wagon that handled like an STi. I've always had a thing for wagons, and have wanted a FXT for quite some time. The car is pretty much where I want it now aside from a a few little things that will be addressed as time goes on. I also own a 2000 RS coupe that I plan to do a full STI swap on. My journal on the RS can be found over on RS25.com here: Trevor's 2000 RS Coupe Project - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Mod List:
Engine/Exhaust/Cooling:
-E-Tuned by Stephen Clark @ iAP
-Cobb Accessport v3
-Cobb Catted Downpipe
-Invidia G200
-Grimmspeed TMIC splitter modified to work with sub frame spacer removal
-Koyo VH13026 aluminum radiator
-Mishimoto radiator hoses
-Gates timing belt kit w/ race belt
-Tomei timing belt guide
-Killer B oil pickup tube
-Killer B baffle
-IAG AOS Street Edition
-NGK LFR7AIX one step colder plugs
-Walbro 255 fuel pump
-STI Exhaust Manifold Runners DEI Titanium wrapped
-Grimmspeed STI Crosspipe Thermal coated and DEI Titanium wrapped
-Grimmspeed Coated catless uppipe DEI Titanium wrapped
-04-07 STI Intercooler
-VF48
-DW850cc Sidefeed Injectors
-Grimmspeed 3-Port EBCS
-TGV Deletes
-Grimmspeed 3mm phenolic intake spacers
-Perrin 2.4" turbo inlet
-PTP Turbo blanket
-Group N Engine Mounts
-Grimmspeed hood struts
-Custom CNC water jet cut aluminum radiator shroud
-Custom CNC water jet cut aluminum alternator shroud
Suspension/Brakes/Handling:
-18x7.5" +48 FSTI wheels
-Hankook Ventus V12 Evo2 225/45/18
-KYB AGX Struts
-Group N front and rear top hats
-05 STI Prodrive Red Springs
-Scooby921 strut spacers
-07 STI Aluminum LCAs
-TIC FCAR Bushings in Forester ALK
-Whiteline #52837 FCAF Bushings
-Whiteline RCA Kit
-06 STI steering rack
-STI solid steering u-joint
-Sub frame spacer delete
-Spec C Ver9 front subframe
-STI rear subframe
-Whiteline rear subframe Locking Bolts
-STI rear diff carrier
-Whiteline Steering Rack Bushings
-Whiteline 24mm Adjustable FSB
-Rallitek Front endlinks
-STI Rear Swaybar Mounts
-Whiteline 22mm RSB
-Rallitek Rear Endlinks
-STI trailing arm brackets
-STI Aluminum Lateral Links w/ TiC Race bushings
-TIC Race Trailing Arm Front and Rear Bushings
-STI "SJ" Brake booster and 1 1/16" MC
-Grimmspeed Master Cylinder Brace
-Brembo GD STi front calipers
-Brembo GD STi rear calipers
-DBA 4000 T3 slotted front rotors
-DBA 4000 T3 slotted rear rotors with big parking brake drum
-Stoptech Performance street pads
-Goodridge SST braided brake lines
-Whiteline quick release rear strut tower bar
Interior:
-Pioneer AVH-X3600BHS
-Pioneer GM-D8604 Amplifier
-Focal ISS-165 6.75" component speakers
-Polk DB-522 5.25" rear speakers
-JL Audio 10W0v3-4 10" subwoofer
-Sea-Scooby Style Sub box in rear quarter panel
-05 STI Steering wheel
-Omori 45mm Digital Boost Gauge (mounted on steering column)
-BNA Solutions triple gauge pod
-Solid Mod vent pod
-AEM Oil Pressure Gauge
-AEM Oil Temp Gauge
-AEM Water Temp Gauge
-AEM AFR Gauge
-04 WRX heated seats
-DIY "JDM" Hazard
-Plasti Dip HVAC Panel
-Subtle Solutions black vinyl HVAC overlays
-JDM HID leveling switch
-FastWRX aluminum dead pedal
-GD WRX Pedal set
-Noico dampening interior
-Ensolite on all panels and hatch
Transmission:
-Stock 5MT
-Group N 5MT Mount
-Group N Pitch Stopper
-WRX specific SPT short Shifter
-WRX specific driveshaft
-WRX specific transmission crossmember
-Kartboy Front and Rear Shifter Bushings
-Kartboy front crossmember bushings
-Exedy 15802HD Stage 1 Clutch
Exterior:
-JDM FSTi front bumper
-JDM FSTi front lip
-JDM FSTi front grille and headlight surrounds
-JDM FSTi HIDs
-JDM FSTi hood
-JDM FSTi front fenders w/ side markers
-JDM FSTi side skirts
-JDM FSTi rear bumper
-JDM FSTi rear spats
-06-08 smooth lower door panels
-OEM Spoiler
-JDM FSTi Scoop
-Paint matched rear hatch waste garnish
-5% Tint all rear windows
-GD STI Side Mirrors
-Paint matched wiper fluid sprayers
-Paint matched C-pillars
-Cobb rear wiper delete
Parts to be Installed and things to do
-Wire test mode connectors to switch
-Wire wideband to TGV input for logging
-Grimmspeed heat shield
-Install Kartboy front end links
-Repaint gauge pod
-Sound deaden
-New speakers and amp
-Sea-Scooby Sub box
-Replace top hats with all Group N
-Install rear strut brace bar
-Install WRX pedal set
-Install black silicone throttle body coupler
-Install new window gussets
-Wire JDM side markers
-Wire HID leveler switch
Future Mod Plans
-Grimmspeed 3" downpipe
-ID1000 top feed injectors
-EL headers
-Volk ZE40s/CE-28N
-JDM v7 or FSTi front seats
-FSTi door scuff plates
-FSTi optional side skirts
-Fender braces
-DAMD steering wheel
-JDM rear wagon STi seats or JDM rear FSTi seats
-FSTi Gauge Cluster
-Full 5x114 6 speed swap
-IAG built block
-Flex Fuel
Day 1
11/27/17
I hit a dear on the way home in the Forester, and was sure the car would be totaled. It wasn't, and I was able to use the money from insurance to install the FSTi front, skirts, rear spats, rear bumper and JDM HID headlights. Something I longed to do, but never thought it would be in the cards. So, here we are!
Current 5/18:
Car Details:
2005 Forester XT
Aspen White
5MT
117,000 miles
Backstory:
Mod List:
-Cobb Accessport v3
-Invidia G200
-Killer B baffle
-VF48
-TGV Deletes
-PTP Turbo blanket
-KYB AGX Struts
-Whiteline RCA Kit
-STI rear subframe
-Whiteline 22mm RSB
Interior:
-Solid Mod vent pod
-AEM Oil Temp Gauge
-AEM AFR Gauge
-DIY "JDM" Hazard
-GD WRX Pedal set
Transmission:
-Stock 5MT
-Group N 5MT Mount
Exterior:
-JDM FSTi front lip
-JDM FSTi HIDs
-JDM FSTi hood
-OEM Spoiler
-JDM FSTi Scoop
-Repaint gauge pod
-Sound deaden
-Sea-Scooby Sub box
Future Mod Plans
-EL headers
-Volk ZE40s/CE-28N
-Fender braces
-FSTi Gauge Cluster
-IAG built block
-Flex Fuel
Day 1
11/27/17
Current 5/18:
