thebeephaha's 03 FX AT Mods - Subaru Forester Owners Forum
post #1 of 239 (permalink) Old 12-18-2009, 11:47 PM Thread Starter
thebeephaha's Avatar
Car Model: XTi Cross Sports
Transmission: 4EAT :(
NEW JOURNAL HERE
ID:	30219   Click image for larger version
ID:	30906   Click image for larger version
ID:	30907   Click image for larger version
ID:	30908   Click image for larger version
ID:	30910   Click image for larger version
ID:	30911   Click image for larger version
ID:	30912   Click image for larger version
+ '02 Jaguar X-Type 2.5
Last edited by thebeephaha; 07-03-2013 at 10:22 PM. Reason: Always adding more. Check back now and then.
thebeephaha is offline
post #2 of 239 (permalink) Old 12-18-2009, 11:53 PM
Smooshed FOTY 2011
Blue Fox's Avatar
Car Model: Lifted 2.5 XT
Transmission: 5-Speed MT
Originally Posted by thebeephaha View Post
Also installed some LEDs for my plate but the Subaru housing for it makes the second one point the wrong way! Arrr. I figured out how to do a 180 on the housing to get it the right way, but I gotta open it back up and get some more slack on the wires.
The one on the right is installed backward. When I installed my plate LED's, they both pointed inward (towards the plate). You shouldn't have any problems with the wiring being too short, unless someone before you replaced a bulb, and reinstalled it wrong.
Other than that, looking pretty good. I want more pics though.
2004 XT - RIP
2005 XT - 5MT - 2" LIFT
Blue Fox is offline
post #3 of 239 (permalink) Old 12-19-2009, 12:20 AM Thread Starter
Yea the wiring is too short to spin it around. I gotta get some slack in there. I saw some zip ties so I think that is the culprit.
More pics coming for sure.
post #4 of 239 (permalink) Old 12-19-2009, 08:22 AM
Feedback Score: 41 reviews
Good start to your Member Journal! Since you have the required 15 posts, you can link to a host like Photobucket & post pictures.
My MODding Journal
2.5x_sleeper is online now
post #5 of 239 (permalink) Old 12-20-2009, 01:28 PM Thread Starter
Original 35w 6000k HIDs, now switched out for 35w 5000k Bi-Xenons.
HIDs installed
Beams
Installed some LEDs in the parking lamps. I found the housing was installed wrong by the last owner, cables were so tight I had to really work for slack to turn it the right way.
Fixed the housing by snipping some zip ties and gently pulling. Also added some chrome Forester license plate frames.
Pic of the front plate.
post #6 of 239 (permalink) Old 12-26-2009, 10:51 PM Thread Starter
Installed the OEM tweeters.
post #7 of 239 (permalink) Old 12-26-2009, 11:18 PM Thread Starter
I ordered some relay harnesses on eBay, I modded them quite a bit to serve my purpose just how I wanted. Here is the preliminary install before I get some wire loom and get it all bundled up for extended use. The install took me the better part of the evening as I custom made a lot and modded the relay but I think it turned out pretty well.
EDIT: This relay was replaced with my own design but that was eventually removed and I am no longer using a relay at all. Also, I reconnected the DRL resistor and then disconnected the DRL module.
Overall shot of the engine: (Red wire going across will be put in a protective wire loom soon, I don't want all the heat damaging the wires to the passenger HID.)
Driver HID overview:
Closeup of the HID itself (The spliced wires are for the high beam halogen, I didn't put them on the relay as they were always on for some reason when I did, so I hooked them to the stock harness. Under all of the electrical tape are connectors so I can replace the bulb fairly easily if need be. Just gotta peel the tape and re-tape, no biggie.)
Here is where I stuffed the relay itself
Passenger HID overview
Passenger Relay
Relay Fuses (I think they are 25 amp but I can't remember.)
Disabled the DRLs (I disconnected the resistor and taped off the end of the cable and zip tied it so it wasn't floating around.)
Fixed broken ground cable
post #8 of 239 (permalink) Old 12-27-2009, 10:08 AM
Your Member Journal is coming along nicely! I didn't do a Journal on the '03X, now my son's Forester. On the positive side, those MODs have been done to my new '07 FSXT that I moved on to in July & I did start a Member Journal.
My MODding Journal
post #9 of 239 (permalink) Old 12-27-2009, 02:10 PM Thread Starter
Thanks! Slow but steady progress.
Question for the other car electronic buffs, do my relays look OK? Not too "ghetto" since I did a lot of modifications myself?
Tests last night show the HIDs are getting much better power, ie no flicker, and they warm up faster, I'm just worried about longevity/safety. I was really careful about putting electrical tape over any spice or connector with an open end, but I wish I had some of those waterproof connectors. Didn't see them at my local auto parts store.
post #10 of 239 (permalink) Old 12-27-2009, 03:21 PM
Since you asked...
I make sure any wiring I do in the engine compartment is waterproofed, since it's going to get wet in there.
IMO, the relays should be mounted vertically with the wiring connected from below. If you used a socket, I'd fill the connectors with dielectric grease before plugging it together. This will prevent any water from getting to the connection.
I'm not a fan of electrical tape, except for temporary use. In my experience, the adhesive will release as it ages. I prefer shrink tubing, filling any splice with dielectric grease before shrinking to get a waterproof seal.
My MODding Journal
post #11 of 239 (permalink) Old 12-28-2009, 09:16 PM Thread Starter
Dashboard dual din pod installed, currently waiting for my new Nav unit to put in. Will take out the clock, not needed, and take out the stock deck and fill the space with another storage pod like the one below it.
post #12 of 239 (permalink) Old 12-28-2009, 09:20 PM
Looking good! You have everything looking like it's part of the factory wiring.
My MODding Journal
post #13 of 239 (permalink) Old 01-01-2010, 11:22 PM Thread Starter
Main photos!
7/2/10: Front lip, Hella Optilux 2500
6/30/10: Skid plate installed!
6/30/10: Latest shot of the engine bay.
5/31/10: Hella Supertones
5/11/10: Importology Grille
4/27/10: Window Tint
Went to West Seattle and shot on the first really beautiful day this year:
EDIT! High definition background pics found here: Wallpaper photography - post and contribute!!
Others:
post #14 of 239 (permalink) Old 01-01-2010, 11:26 PM Thread Starter
Installed the new Optima Red Top 35 8020-164 battery, this baby has so much more starting power than my old Energizer.
post #15 of 239 (permalink) Old 01-01-2010, 11:34 PM Thread Starter
First off, I apologize, I didn't take installation pictures. It was cold, I was tired, and I just wanted to get my nav unit it in. I worked on it from about 2PM to 7:30PM and got it all in and working perfectly. I will take internal wiring pics when I have to connect my rear view camera and a few other odds and ends. I got a few tiny scape marks on the dash from prying it open but I think I can smooth them out. The hardest part was the stupid vent and heat controls. My back and neck still hurt from disconnecting and reconnecting those servos. Works out really nice in the pod, don't have to look down anymore to do stuff on the stereo, much safer where it is now up high.
I also bought a second DIN storage pod so I have two now in the original deck location. The top one holds my iPod and has the cable routed in it via a hole I cut in the back. The bottom one holds a USB connection for a flash drive and the AUX input connectors.
Mix from cell phone pics & D300 for now:
Here it is!!! (For reference, scroll up a ways to see the pre-install how it looked.)
iPod:
USB
Nav:
iPod/USB:
Eject:
DVD: (OMG this is so dangerous! lol)
Notes:
  • Gotta get a wire to the engine speed sensor for more accurate GPS readings but have no idea where that is located. PROBLEM SOLVED
  • Reverse wire and rear view camera not hooked up yet.
  • Connected parking break cable to common ground per instructions from fellow AVN4430 owners online to enable full function all the time.
  • There is a second connector taped back on the stock harness, what is it??? See pic below: PROBLEM SOLVED
