Accomplishments so far:
Engine Mods:
-stage 2 built block from awdtuning, dallas tx.
+JE Pistons
+heat treated nitride coated crank
+manly H beam rods
+acr race bearings
-grimmspeed ceramic uppipe (rallysportdirect.com)
-Tuned via Rom Raider myself
-GRIMMSPEED manual boost controller www.grimmspeed.com
-back to stock TD04
-Top Mount intercooler process west style (Fast motorsports) (turbotektuning.com)
-back to stock header
-2015 Sti Sedan Catback
-AEM Cold air intake
-Perrin turbo inlet
-2 Oil Catch Cans
-Deleted BPV return line back to intake.
-wrx engine mounts
-QTP Electric Exhaust Cutout
Suspension mods:
-Anderson Design Fabrication 2" lift with trailing arm extensions.
Drivetrain mods:
-6 speed sti transmission
-DCCD pro controller
-limited slip r180 rear diff
-sti axles
-sti driveshafts
-clutchmasters 6 puck fx400 clutch
-kartboy shifter bushing
-kartboy short throw shifter
-turn in concepts shifter linkage bushing.
-Drive Shaft Shop 08+STI Aluminum Driveshaft (58 inches)
- killer b delrin matte shift knob
Comfort/Utility mods:
-BFG TA KO2 IN 265 65 16
-53" crossbars(amazon.com)
Supporting Mods:
-smy gauge cluster
-wrx gauges(ebay)
Style/look mods:
-lamin-x gunsmoke rear tail tint (lamin-x.com)
-SPARCO Terra Corsa 16"
-Sports Grille
Brakes:
-Stoptech Street Performance Pads (rallysportdirect.com)
Engine Mods:
+JE Pistons
+manly H beam rods
+acr race bearings
-back to stock TD04
-Perrin turbo inlet
-2 Oil Catch Cans
-wrx engine mounts
Suspension mods:
Drivetrain mods:
-sti axles
-sti driveshafts
Supporting Mods:
-smy gauge cluster
-wrx gauges(ebay)
Style/look mods:
-Sports Grille
Brakes:
