sleeperxt's work in progress - Subaru Forester Owners Forum
 41Likes
post #1 of 1987 (permalink) Old 02-03-2009, 08:33 AM Thread Starter
sleeperxt's Avatar
Car Year: 06
Car Model: forester xt
Transmission: 07 sti 6 speed
Feedback Score: 43 reviews
"Current status" :)
Well I figured I should start a diary of my constant modding. So Ill just save some space for when I have time to fill it in.
The beginning:
2006 Subaru Forester XT, Limited, 5 speed manual transmission, All Weather package
color: Steel gray metallic (my favorite!)
-Stock everything. Immaculate @ 3k miles
Signing the papers to take our baby home. :)
And here is the happy new driver of our new baby. Yup, the forester was purchased for my wife.
The first mod @ 6k, was an OEM steering column boost gauge. I installed it on the right hand side so I could keep track of the boost and rpm more easily.
The next mod @ roughly 9k, was a Bosal shorty downpipe. This is a divorced waste gate design. Because I have an 06 xt I had to use a WRX intermediate ( catt pipe). I also installed a Cobb turbo heat shield to help keep the heat from the little snail contained.
Shortly after was a Perrin Drop in air filter and a Cobb AccessPort V2. For the mods I had Cobb recommended using a OTS Stage2 map. This was a lot of fun!
Its first real winter setup:
First Was the Forester STi Pink spring install.
Comparison of stock rear spring to FSTi Pink
Front wheel gap before
And after
Rear Before
After (Notice the trademark dent on the rear quarter :)
Then came the front Brembos and SS lines
oem 2pots compared to Brembo 4 pots!
Wheels n Tires
-Nexo TS 10's 17x7.5
Bridgestone Graspic studless winter tires 235/45/17
Project "SuperSleeper" will soon be under way!!
Dale a.k.a. GarageXTi and the guys over at MoorePerformance have been putting together a custom setup to meet my fairytale sleeper setup. Below are some of the details:
-Twinscroll rotated uppipe w/merged wastegate flange to a single Tial 44mm ewg and dump tube
-Twinscroll el headers
rotated and internally divided 3" downpipe
-Spearco/esX top mount intercooler heavily modified to a huge side inlet with internal air splitter to evenly divide the charge across the core!
Up to date mod list as of 7/25/12
Engine:
-Cobb AccessPort e-tuned by Clark Turner
-Stock block and heads, untouched
-Blouch 20g td05 pnp’d hot and cold side
-Grimmspeed IWG bracket
-Prodrive 3-port ebcs
-DW 850cc injectors
-TGV deletes. Pnp’d
-Grimmspeed 3mm Phenolic tgv spacers
-Samco silicone turbo inlet. Black
-Samco silicone after MAF hose. Red
-APS 70mm CAI. Wrinkle red
-Cusco catch can. Piped to PCV and Valve cover breathers
-TurboXs tmic. Ported, polished, gasket matched, knife edged. Wrapped in DEI Gold heat reflective tape
-Walbro 255 fuel pump
Group N motor mounts
Group N Pitch stop mount
-Tial 44mm EWG w/14psi spring
-P&L EWG uppipe and dump tube. Pnp’d inlet and outlets. Painted with black exhaust paint, Wrapped in 2” DEI Copper exhaust wrap
-WBR equal length header. Pnp’d inlets and outlet. Came with black heat coating. Have since re-coated it with white exhaust paint and wrapped with 2” DEI Titanium wrap.
-TurboXs Bellmouth down pipe. Newest version with cast bell. Coated with white exhaust paint and wrapped with 2” DEI Copper wrap.
-TurboXs Race pipe interchangeable with High flow cat.
-TurboXs midpipe
-Cobb 3”Axleback exhaust. Forester specific
-Kartboy exhaust hangers
Suspension:
Whiteline 27mm front swaybar
Whiteline 24mm rear swaybar. STi fit
Whiteline Rear Swaybar Mounts. STi fit
Whiteline Ball Joint extender kit
Whiteline Caster bushings for front control arms
Whiteline Steering rack bushings
SuperPro Front control arm bushings
SPT H brace
SPT Front strut tower brace
Whiteline quick release rear strut tower brace
GTspec Fender braces
Cusco rear subframe brace/diffuse mount
SubtleSolutions rear trunk brace
Sti Aluminum front control arms
STi Aluminum Rear Lateral links
Kartboy front and rear endlinks
Kartboy Comfort outrigger bushings
04 STi steering rack
Sti steering u joint
Removed forester 1” front subframe spacer/ installed shorter wrx/STi U bolts
MRT front camber/Caster plates
MRT rear camber plates
Tien Hybrid coilovers:
Tein Forester coilover springs front and back.
Tein rear shocks ment for pillow ball top hats.
Tein 05-07 STi spec lower knuckle brackets
KW rear camber bolts
Drivetrain:
06 STi DCCD 6 speed
06 STi R180 rear diff
06 STi transmission cross member
TiC Cherry blossom Transmission gross member bushings
06 STi rear cross member
06 STi subframe
06 STi Rear diff mount
Kartboy Comfort STi rear diff bushings
Kartboy Lock down bolts
South Bend DXD street clutch
STi steel braided clutch line
ACPT Carbon fiber driveshaft
DCCDPro.com Auto/manual override center diff controller
Transmission fluid 50/50 mix (Motul 600 75/90 and Redline Shock proof)
Rear diff Subaru LSD fluid
06 STi axles, front and rear
06 STi 5x114 hubs/knuckles, front and rear
Brakes:
06 STi Brembo calipers, front and rear (paint is near perfect!)
DBA 4000 slotted rotors, front and rear (05-07 STi spec)
Hawk HPS pads
Goodridge SS brakelines
Cusco Master Cylinder brace
RCE 3” front brake ducts (red)
Interior:
07 FXT head unit w/Aux input
06 STi shifter shroud
06 STi 6 speed shift assembly painted black
06 STi 6 speed shift knob
06-07 WRX limited leather, heated sport seats. (Charcoal gray)
OEM rear cargo nets
Exterior:
02-03 bugeye JDM STi hood scoop
07-08 Forester sports mesh grill (Gloss black surround)
RallyArmor Urethane mud flaps
STi rear diffuser
Wheels:
Which wheels haven I had?! LOL!
Work Emotion 11R-FT 18x10.5, +22 0ffset Satin gray
Dunlop StarSpec 265/35/18
Here's an old mod list as of 1/31/09:
Power Mods:
-COBB AP v2
-VF39-PnP hot side
-STI exhaust manifold and uppipe-PnP( 1/32/09 Changed out for WBR Equal Length Headers and matching up pipe)
-STI intake-manifold gasket mach ported
-TGV deletes
-Grimmspeed Phinolic 3mm thermal spacers
-TXS Top mount intercooler
-Injen CAI
-Samco inlet pipe
-NGK 0ne step colder plugs
-Prodrive Boost Solenoid
-Walboro 255 fuel pump
-Bosal DP ( 1/32/09 Swapped for a Crucial Racing 3" divorced waste gate DP)
-Cobb heat shield
-Perrin High flow catt
-WBR 3" catt back exhaust
-Kartboy hangers
Suspension:
Tein WagonGT coilovers w/EDFC
MRT camber caster plates
Whiteline 24mm swaybars front and rear
Kartboy endlinks front and rear
Whiteline RSB stout mounts
SPT front strut brace
SPT front H brace
Whiteline Q/R rear strut bar
Cusco rear subframe brace w/diffuser kit
Kartboy rear subframe locking bolts
MoBoost LLWS kit
Stoppers:
05 STI Brembo front calipers
The BrakeMan 2 piece front rotors (ultra light!)
07 STI Brembo rear calipers
TWR Brembo rear adapter kit
goodridge ss lines
Hawk HPS pads front and rear
Track rollers:
Enkie RPF-1 18x8 +35 offset
Toyo Proxes R888 235/40/18
This is the original list. Please see newer list for updates and pics. I will have to sort out and update this post.
Suspension
-STi pink Forester springs on stock struts
-STi "Gold"Brembo's up front w/ Brembo rotors and oem STi pads
-Rotora "Baby Blue" bbk in the back w/ slotted rotors and Axis metal matrix pads
-Goodridge ss brake lines
-Whiteline 24mm adjustable FSB
-Whiteline 24mm adjustable RSB
Old Mod list. Read through post for updates
Power Mods
-IHI VF39 (ported n polished hotside)
-STi Headers and uppipe (ported n polished, gasket matched)
-STi top mount intercooler
-Bosal shorty dp
-WRX Catt Pipe
-STi Catt back exhaust.( Back panel of muffler painted black to look like stock XT)
-Perrin drop in air filter
-Cobb Accessport
Exterior
Forester Sports "Gloss Black" Mesh Grill
Winter of 2007/2008
Winter of 2008/2009
Rota Torque 17x8 48 offset
Check out the thread I started to feel better about my "habit of buying wheels" :D.
How many different sets of wheels has your Fozy had?
STR76 likes this.
sleeperxt is offline
post #2 of 1987 (permalink) Old 02-03-2009, 08:33 AM Thread Starter
sleeperxt's Avatar
Car Year: 06
Here's my first auto-X. The Forester's were well represented that day! I only had time for four runs but it was a blast! And hanging out with fourortwowheels was a blast! He is an animal thru the cones! Sorry I don't have any action shots. I used the video camera for that stuff.
The mods I put on the weekend before.
Whiteline Rear strut tower brace w/qr
SPT front strut tower brace and Lower H brace
Perrin WRX stout mounts with some aluminum shims
And the event
Still riding on super comfortable HotBits Street coilovers
Pics clipped from a video
Getting strapped down on the dyno for the first time! With approximately 28k on the clock.
Here are the mods added the night before the dyno:
-TGV deletes
-STI intake manifold (gasket matched and ported)
-Samco silicone turbo inlet pipe
-Injen cold air intake
-NGK 0ne step colder plugs( These were a mistake. I think they cost me a good amount of torque)
Here's the story behind the dyno.
The overnight overhaul!
Engine bay before STi intake manifold and Injen CIA:
Engine bay after:
post #3 of 1987 (permalink) Old 02-03-2009, 08:34 AM Thread Starter
sleeperxt's Avatar
Car Year: 06
Just before the road course event I installed Tein Wagon GT coilovers with MRT front camber/caster plates. I also installed the super handy EDFC system.
Unfortunately I waited till after a nasty winter to take these under hood shots. zIP hate road salt!
Here's where I stuck the controller.
More to come from my VIR road course weekend!
9th Annual Fall Fling - October 18th and 19th, 2008 at Virginia International Raceway
VIR sneak peek
On the second set of wheels :)
Here are some pics of my friends race prepped porsche.
He is the one who invited me to the event
post #4 of 1987 (permalink) Old 02-03-2009, 08:34 AM Thread Starter
sleeperxt's Avatar
Car Year: 06
Here's a pic from the Long Island Forester Meet this winter.
RavSpec/GTSpec meet
The wife and I took a road trip from Long Island NY to Niagra falls in the snow with KUMO SPT summer tires. (Not too smart)
Here's a few shots with 'Duderotomy' on my trip to Niagara falls (Canadian side). He was nice enough to meet up for some pictures and some video gaming. Please excuse the filthy vehicles and fuzzy pictures. It was really cold.
post #5 of 1987 (permalink) Old 02-03-2009, 08:34 AM Thread Starter
sleeperxt's Avatar
Car Year: 06
Mod recently installed:
-Rally Armor Urethane mud flaps. I got them nice and dirty right away. These work great!
-WBR EL header w/Cool It Thermotech Copper header wrap.
Here it is the Wrapped WBR next to the STi manifold
This was a bitter sweet mod. The STi manifold made nice power and had the sweet boxer rumble. But at my wife's request I had to make the exhaust a bit quieter. So an equal length header was the obvious choice to quiet things down without giving up any power. The fit and finish of the WBR headers/up pipe was excellent! But Now There's no rumble,rumble.
-Cusco Master cylinder brace
I had a chance to install this on the fozy. The install on an 06 and newer is a bit more complicated. I had to remove the emissions air pump to get to the origonal brackets. After fitting theCusco MC brace in its place, I noticed that the tensioner bolt was in direct obstruction of the rubber hose that connects to the air pump. So I removed the tensioner bolt, measured the length I would need it to be. After finding the proper length I found the proper die and threaded it onto the bolt before cutting. Then cut the bolt with a hack saw and cleaned it up with a fine grit metal file. After that I unscrewed the die which re-threaded the bolt on its way off. Now I was ready to install it on the bracket. It all went to plan.
After all was said and done, I ended up with a slightly firmer brake under normal light braking and a ferry nice feeling pedal under hard braking. Over all I am verry pleased with the results.
6/13/09:
-Finally got tint. I also installed a 02 03 JDM STI hood scoop and removed the ugly Rota emblems from the center caps. Also tried out some 25mm wheel spacers!!
Now I just need to wash her.
Installed -SRP Racing pedals a while back. They replaced my STi pedals and are
pretty nice.
9/6/09
Installed Rota G-Force in Steel Gray 18x9 et35
11/09
Then bought a pair of G-Forces in gold and installed 07-08 Sports tail lights :) I think these are a better match to my color and style
2/6/10
Installed a stiffer spring in the 44mm EWG, so now it opens at 1 bar. Replaced my defective DW850cc injectors with a new set. Went over my dual catch can setup and replaced the zip ties with hose clams. And installed a DriveShaftShop one piece drive shaft.
Mods waiting to be installed 2/12/09:
-RCE Kool Brake duct kit
*- STi intercooler sprayer
*-Group N pitch stop mount-installed!
*-02/03 JDM STi hood scoop-Painted SGM and installed!
*-WBR FMIC-Decided to sell this before it was ever installed
*-STi motor mounts- installed
*-STi transmission mounts- installed!
While waiting to install my own parts, ive been buisy with friend's forester mods:
BIG Install Day
http://www.subaruforester.org/vbulle...ms-mods-53217/
Galager and Skotcharu - Stage 2
4 Pot Install
STi IC and Rear Sway Bar Install
max6spd just went stage 2
New STi Catback Install
post #6 of 1987 (permalink) Old 02-03-2009, 08:35 AM Thread Starter
sleeperxt's Avatar
Car Year: 06
Winter of 2010
-Blouch 20g td05 8cm turbo ported and polished
-Turbo benie Turbo blanket
-PnL uppipe w/v band flange for EWG Ported and polished, heat painted and copper CoolIt Thermo Tech header wrapped
-Tial 44mm EWG
-TurboXS 4" downpipe heat painted and copper CoolIt Thermo Tech header wrapped
-TurboXS 3" racepipe and midpipe
-Ported and polished throttlebody
-WBR el headers ported and polished
-APS 70mm CAI wrincle red
-Samco after MAF and assored hoses
-DW 850cc injectors
-Cusco duel catch cans. one for valve cover breathers and one for PCV
Some other shots
The Bay:
Special thanks to Zumble for his advice and tech support. Clark Turner for his stellar tuning abilities.
To my dad for his help. And most importantly to my wife for putting up with my neverending modding of her daily driver. I dont know how she lives with me :)
2/6/10
post #7 of 1987 (permalink) Old 02-03-2009, 08:35 AM Thread Starter
sleeperxt's Avatar
Car Year: 06
Dale and the guys over at MoorePerformance have been putting together a custom setup to meet my fairytale sleeper setup. Below are some of the details:
-4" Cold Air Intake with HKS Green filter
And there is more to come! Stay tuned
To make it a true "SuperSleeper" project it utilities a typical tmic located core. Dale has artistic license with the coating colors but I think he is using primarily black with little hints of red. I am planning on re using the stock plastic engine cover and possibly extending it to hide the goodies until I decide to let it show! This of course was inspired by Dales show car and its "think outside the box" theme
Thanks to Dale, Ryan and the rest of the crew at Moore Performance this has become a reality! The pictures speak for themselves.
This is the latest state of modification
Full 06/07 STi drivetrain swap
Read on and see how long and painstaking the road to modification was :)
post #8 of 1987 (permalink) Old 02-03-2009, 01:42 PM
Tuned200's Avatar
Car Model: FSXT / FSTI
Transmission: 6 MT
Feedback Score: 62 reviews
Awesome photos man! nice work
2007 Forester STI -
2007 XT Sport 4EAT -
2006 Forester XT -Sold-
2010 Forester X -
Tuned200 is offline
post #9 of 1987 (permalink) Old 02-03-2009, 01:53 PM Thread Starter
sleeperxt's Avatar
Car Year: 06
Thank you sir.
Now I just have to find some time to fill in all the details and pics.
post #10 of 1987 (permalink) Old 02-03-2009, 01:56 PM
Tuned200's Avatar
Transmission: 6 MT
Originally Posted by sleeperxt View Post
Thank you sir.
Your welcome. I love it, its the same color as my FSXT! Happy modding my friend.
2007 Forester STI -
2010 Forester X -
Tuned200 is offline
post #11 of 1987 (permalink) Old 02-03-2009, 02:32 PM
ɹoʇɐɹǝpoɯ ɹǝdns
Duderotomy's Avatar
Car Model: XT Sport
Feedback Score: 20 reviews
It's about time you started one of these Ken!
Your car looks great in person too...
Duderotomy is offline
post #12 of 1987 (permalink) Old 02-03-2009, 02:42 PM
guroove's Avatar
Feedback Score: 13 reviews
What do you think you should have gone with? I'm still in the parts collecting phase, and don't want to do anything wrong. I was thinking about the Denso Iridiums, but didn't know whether I should go one step colder than stock or not.
guroove is offline
post #13 of 1987 (permalink) Old 02-03-2009, 03:53 PM
fourortwowheels's Avatar
Car Model: FSXT
Transmission: M/T
i love your car ken! such a transformation from the first pic!! better put those r888s to work this season!!
btw in regards to plugs - the stock ones are fine for modest turbo upgrades... its really up to what your tuner likes in the end though....
fourortwowheels is offline
post #14 of 1987 (permalink) Old 02-04-2009, 06:25 AM Thread Starter
sleeperxt's Avatar
Car Year: 06
LOL! I added some Niagara Falls pics. Sorry for the wait. Thanks again for coming out for a mini Forester meet. HAHA. 2 members.
post #15 of 1987 (permalink) Old 02-04-2009, 06:29 AM Thread Starter
sleeperxt's Avatar
Car Year: 06
I should have just kept the stock plugs untill I needed an upgrade.
