arrite here it is. This is the last time she was stock. Pulled right into the garage for the full make-over
Surgery included: Wheels/tires -Drag DR-31 17x9 +38 offset (sold) -Hankook Ventus V-12 EVO K-110 245/45-17 (sold) -Rota D-force 18x9.5 +40 offset -Dunlop SP600 (stock 2010 STi tires) 245/40-18 -Mach V Awesome gunmetal 17x9 +42 offset (pending) -Dunlop Direzza ZII 245/45-17 (pending) Chassis/suspension/steering **Front subframe spacer delete - corrects suspension geometry on Foresters when lowering to Impreza levels** --WRX pitchstop --WRX driveshaft --WRX steering u-joint --WRX SPT short shifter --WRX subframe studs --WRX transmission crossmember **Rear WRX STi subframe and outrigger conversion to correct lowered suspension geometry (4/27/13) --WRX STi rear subframe --WRX STi outrigger and differential carrier -Whiteline RCA kit KCA313 -Whiteline ALK KCA362 -2002-2003 WRX fitment KYB AGX struts -2002-2003 WRX fitment H&R Sport Springs -2002-2003 Impreza top hats (fronts are same between 03 and 04 but rears are different...) -1/4" (~5mm) Saggy Butt Spacers from Paranoid Fabrications -1/4" (~5mm) Front strut top Spacers from Paranoid Fabrications -04 STi steering rack -Whiteline steering rack bushings KSR202 -05 STi Aluminum front lower control arms with free castor mod -6mm extra castor spacers http://forums.nasioc.com/forums/show....php?t=1900666 -05 STi aluminum rear lateral links (DONE 4/25/12) -Perrin 22mm adjustable swaybars front AND rear with included stout mounts (needed for strength and lowered mounting position for Impreza suspension) -RalliTEK front and rear Heavy Duty endlinks -Rear subframe lock bolts Kartboy KB-066 "Botox" bolts -Ingalls camber bolts front and rear -Ebay front strut tower brace -DIY quick release rear strut tower bar -GTSpec fender braces -GTSpec H-brace "ladder" bar front under-subframe brace (awaiting install) -Alignment: the silver bear gets serious Interior -ProSport 52mm green/white Premium Boost gauge with peak/hold/warning -2002 WRX front seats -Alpine IVA-NAV-1 touchscreen Bluetooth/Navigation/DVD headunit -35% tint front two windows, 20% all rear windows Engine/power **266 whp / 301 wtq** EFI Logics dyno tuned. Dyno graph and video on post #76 -VF39 -STi TMIC -Perrin catless up-pipe -COBB 3" catted Down-pipe with 2.5" reduction cut off to be FULL 3" Turbo-back -SurewinProducts V2 catback exhaust (02-07 WRX/STI High Performance Stainless Steel Catback) -XL extended Kartboy exhaust hangers -Turbo oil feed line and AVCS banjo bolt screen removal -Walbro 255 fuel pump -GrimmSpeed EBCS -Spectre (autozone) high flow air filter -Mishimoto Aluminum Performance Radiator (MMRAD-FXT-04) -Airbox snorkus delete Brakes -1-1/16" (STi) brake master cylinder -GrimmSpeed Brake Master Cylinder brace -06 STi front Brembos powder coated red with White decals -DBA 5654 slotted STi front rotors, two-piece w/ alloy hats -Brembo GT kit rear calipers with adapters and adapter cross-drilled rotors (stock STi size outer dia., Forester inner drum/parking brake dia.) -StopTech steel braided lines -Hawk HPS pads Exterior -02-03 STi hoodscoop (painted Urban Grey Metallic) -Factory roof spoiler also in Urban Grey Metallic (to pick up on the c-pillar, mirrors, mid-trunk panel, scoop, grill and wheel color) -Yellow fog light bulbs: Hella H71070662 - Hella Optilux Extreme XY Light Bulbs - Overview - SummitRacing.com -Yellow Lamin-X fog overlays -The $50 DIY Hood Strut -Headlights: Bi-Xenon Morimoto Mini Stage III kit (H1) with 6000k color bulbs. Projector retrofit. http://www.theretrofitsource.com/pro...roducts_id=227 Thule roof rack -460 Podium foot pack -4005 fit kit -LB50 load bars -872XT 44 inch fairing -517 Peloton fork mount bike carriers (QTY 2) -835PRO Hull-a-Port Pro kayak carrier -835XTR Hull-a-Port kayak carrier -91724 Universal Flat Top ski/snowboard carrier
my build journal: the silver bear Last edited by sooblover; 05-04-2013 at 10:14 AM. |
woops almost forgot to get this one in there...
176hp / 203tq please excuse my commentary. I was a bit uninformed at the time... The official results here:
2004 sti steering rack new from subaru with Whiteline poly steering rack bushings. This install was a little bit of a b**ch because lying on your back bench-pressing the rack into place (with a helper of course to guide and help slide things into place) AND those lines accessed from the rear side - passenger are very hard to reach...especially for RE-installing them. Loosening several line brackets to get play in the lines and a helper (my GF) was absolutely necessary as was a set of crowsfeet wrenches, extensions, and flex joints. I could have done without pouring the fluid on my shoulder... but my brain was feeling flatulant. But I had barely any problems with the power steering pump screaming. I moved the steering rack back and forth (car on jackstands) for a long while BEFORE starting the engine while adding fluid. AND when I did start it, I did not move the rack. Just on then off 4 seconds later followed by more engine-off wheel spinning, fluid adding THEN let it sit for a while. Then ran the engine and spun the wheel slowly back and forth. Added more fluid. A couple small squeals then all was good. The front end went back together reverse of removal with 22mm adjustable Perrin front sway bar, 2002 Impreza KYB AGX struts and H&R Sport springs. I left the RCA kit install to my trusted Subaru Tech cuz my dumb-a** broke the head off the lower ball-joint retaining bolt in the knuckle. I feel bad laying this on him as he said it was a super b**ch to drill out. But thats done now... So I think that sums up the front... Last edited by sooblover; 02-06-2013 at 05:23 AM. |
#6 (permalink) |
The rear 2002 Impreza KYB AGXs with H&R Sports (for 2002-2003) fit fine on the 2004 FXT chassis. The difference is in the top of the spring. The 2002-2003 spring coils stay constant in diameter all the way to the top, so the top hat spring seat is wider. The 2004 - on spring tapers to a smaller diameter and the top hat spring seat is therefore smaller. I'm pretty sure I could have used a 2004-on spring with matching top hats on the 2002-2003 struts. But I didnt try it so can't 100% confirm. BUT the wider (and triangular) top hats fit fine in the strut towers in place of the smaller (and "D" shaped) stock ones... I'm making my own LLWS out of steel "L" beam and U-bolts. Just cutting the beam to about 2 inch pieces then drilling holes for the U-bolts and one hole for the endlink bolt. Just trying to copy Whitelines KBR16 part... Kartboy subframe lock bolts are going in as well. Camber bolts are also going in the rear top holes for the struts. |
#8 (permalink) |
It does rub verrrrry slightly. Small fender lip roll and more negative camber and maybe 1/4" saggy butt spacer (Paranoid Fabrications) will eliminate this... Edit: Took all my car parts, tools, and full size spare out of the rear and it sits sliiiightly higher now. Also got the alignment done with a little bit more camber and I think the rubbing has gone away. Might not have to roll the lip. We'll see when I have another heavy load/people in the car... Last edited by sooblover; 06-17-2011 at 07:58 AM. |
#9 (permalink) |
Looking good! I'd love to do the STI rack on mine but budget cuts are keeping the upgrades on standby. What sort of power upgrades are you planning?
- 2001 FS(5MT) 2004 FXT(5MT) 2004 SV1KSK4(6MT) |
#10 (permalink) |
none yet. So far its the most powerful car i've owned. Got a catback going on but for now that will be it... Maybe... ;)
#11 (permalink) |
BTW, can a MOD let me know if this is not cool to do my whole journal with videos? Havent seen many other people do it this way, not sure if theres a reason for that...
#12 (permalink) |
Car Year: 08
Car Model: fxt
I think its really cool that you're doing it in videos. Kudos on that: its different and refreshing. Most don't do this because vids take up much more space on the host sites and take much longer to upload.
Also congrats on the good progress. Looks like you planned everything fairly well and just executing everything without any major glitches. If you need some 1/4" saggy butt spacers let me know, I've got some for sale(coincidentally the same paranoyd fabrications ones you mentioned).
08 FXT Sport - 388/373 00 Miata turbo - 307/287 |
#13 (permalink) |
/\ thanks so much for the kind words! I'll continue the video documentation then...
Yea the progress has gone well. Really though its thanks to everyone on this site with their extreme friendliness, knowledge base, and passion for the cars. Without this site, I dont think I would have even bought a FOZ, but now I can't think of another car I'd rather have (at the moment lol). SF.org has provided me with the information to do 6 months worth of research before I turned one bolt on the car to be sure I set the car up exactly the way I wanted it. Fircrest's build was a huge inspiration to me for stance, exhaust and wheels. Thanks dude! StanT, Duderotomy, SQC146, sleeperXT, Abacall, fourortwowheels all deserve mention for advice, encouragement, knowledge/information, and inspiration. Of course there are many others. OK stay tuned more to come...! Last edited by sooblover; 06-23-2011 at 04:48 AM. |
