Hey everyone, this is the new build for The Wandering Foz, continuing where the old thread left off: http://www.subaruforester.org/vbulletin/f115/great-alaskan-tundra-humper-391762/
IMG_3756 by jeremiah stewart, on Flickr
Goal:
I have wanted to race the Baja 1000 since I was a little kid, but a few years ago I came across the Mexican 1000 which is a little more grassroots and easier for a normal guy like me to race in. So that's the goal! I wanted to race in their "Rally Raid AWD" class using my Hotbits coilovers as they were at the max travel for that class, but most years there is nobody in that class. Might as well try to be competitive if i'm entering a race right? So the class I'm shooting for is Score Class 7 or BITD 7200. In the Mexican 1k it'll either be "Heavy Metal Class" or "Pre-run Truck".
For now I will only be focusing on suspension so I can stay on track to be able to take the foz on a roadtrip planned for May 2017. A roll cage and a bunch of safety items will need to be built after the roadtrip unless I have the time to do the rollcage this winter. Shooting to make the race in the spring of 2018, but if the foz is ready sooner than then, then I will enter a domestic race to get my feet wet.
Plan:
p.s. Some of you who have been on this forum for a while might be getting excited because you remember the first person to attempt this kind of build:
http://www.subaruforester.org/vbulletin/f115/project-forestar-2-baja-foz-161097/
Goal:
Plan:
- Dual A-arm front suspension cycling 18-22" of travel
- Dual A-arm rear suspension with toe link (will make sense later - similar to the PPI 015 Toyota) cycling 20-24" of travel
- 32" tires on factory offset wheels to allow for longer arms and more travel while keeping it under the BITD max width of 85"
- Either King or Fox internal bypass coilovers all around
- High compression EG33 unless the length is more than I want to build around, then it'll be an EZ30
- Extended length axles (+8") probably from DSS
